keta
Asymmetric Flap Fairings On A380?
Mon Nov 21, 2005 6:24 pm
Hello,
While regarding this picture:
Photo © Jan Kertzscher
I noticed that the inner right-wing flap track fairing is shorter than the one in the left wing. You can even see a grey-painted area, more or less what the left-wing fairing covers. In other pictures it is also seen:
Photo © Kok Chwee SIM
Photo © JKSC
Photo © John Farrington - FlightLineImages
Photo © Daniel Alaerts - AirTeamImages
Do you know why are the fairings asymmetric? I would expect both wings to be symmetrical? I haven't noticed that in other planes.
Where there's a will, there's a way
RE: Asymmetric Flap Fairings On A380?
Mon Nov 21, 2005 7:23 pm
They look the same to me. The angles are tricky though so it's hard to be sure.
Mon Nov 21, 2005 8:29 pm
Fantastic Observation!  bigthumbsup
I think Keta is referring to the Wing mounted part of the Fairing & not the Movable Aft part of the Fairing.
The Inboard RH side Fixed portion of the Fairing is Shorter in length compared to the Inboard LH Side Fixed Portion of the Fairing.
Probably it covers some component.
I too would be Interested to Know the reason.
regds
MEL
keta
Mon Nov 21, 2005 10:13 pm
Quoting HAWK21M (Reply 2):
Yes that's what I meant. I think it's quite visible. Sorry if I wasn't clear.  Smile
Dakar
Mon Nov 21, 2005 11:40 pm
I see it now too. Weird. Hopefully there is an answer, it would be interesting to find out why.
Nick
Pihero
Tue Nov 22, 2005 12:34 am
An amazing piece of observation !
I see two reasons :
1/-the aerodynamic integration between the wing-engine pylon-flaps hasn't been frozen and AI is still comparing data from both sides, or
2/- the left fairing covers the EH actuator AI has been talking about for about four years. It could be the explanation as all three flying prototypes have it.
Contrail designer
oly720man
Tue Nov 22, 2005 1:26 am
Looking at the paint under the starboard wing in this picture
it looks like the yellow/green primer isn't used over the area that would be covered by the bigger fairing.
cymro
Tue Nov 22, 2005 5:45 am
Quoting Pihero (Reply 5):
The right hand is shorter by design and is the same on all aircraft produced so far.
Mir
Tue Nov 22, 2005 10:42 pm
It's a missile launcher.
signed,
LetsRoll911.org
But seriously,
What's an EH actuator?
-Mir
EI747SYDNEY
Tue Nov 22, 2005 11:28 pm
I tought my eyes were playing tricks with me for a while, then I seen it too.
Well spotted  bigthumbsup
Rob  wave
''Live life on the edge, Live each and every day like it's your last, Hell you only live once''
Pihero
Tue Nov 22, 2005 11:34 pm
Better than my explanation,
3.1. What is an EHA?
A conventional actuator is connected to the central hydraulic system of the aircraft through pipes running from the aircraft’s hydraulic bay. It includes a servovalve which directs the hydraulic pressure (provided by the aircraft’s hydraulic pumps) to move the actuator shaft which is connected to the corresponding control surface (aileron, elevator, rudder, spoiler).
The EHA is connected to the aircraft’s electrical network (and not to the hydraulic system). It has a self contained electrical hydraulic pump, reservoir and accumulator which generate the hydraulic power required to move the same actuator shaft connected to the control surface. Therefore, the EHA is a real hydraulic actuator since the power to move the actuator shaft is hydraulic; however, since the hydraulic system is self-contained, it only requires electrical power from the aircraft’s network to operate.
EHA will allow to decentralize hydraulic system architectures. Kilometers of hydraulic pipes, pumps, reservoirs and accumulators which generate hydraulic power in a central location and then distribute this energy throughout the aircraft will be replaced by electrical wires and compact actuators which produce the energy required near the place where it is needed.
Contrail designer
keta
Wed Nov 23, 2005 1:54 am
Quoting Cymro (Reply 7):
So far - does that mean all production planes will be like this, or is it only for the first few frames? And by design - with what purpose? That's what we'd like to know.
Is the A380 going to use EHA for all actuators? Is it now only in one flap track?
Wed Nov 23, 2005 2:02 am
Any Official data on the EH Actuator from Airbus.
regds
MEL
Wed Nov 23, 2005 1:14 pm
Ok I see it too now. The time we spend poring over minutiae...
knoxibus
Wed Nov 23, 2005 9:21 pm
Very good observation.
The Ram Air Turbine, according to my A380 General Familiarization training course documents, is located inside the left-hand side flap inner fairing.
That would explain the difference in size (proportional to the size of the A/C, I would say).
I actually looked in the structures chapter and normaly for symmetry purposes, the right side should have the same fairing.
I hope this answers the question, but I actually don't know if it corresponds to the exact reason why.
Reply #5 assumptions might still be part of it.
No matter what anybody tells you, words and ideas can change the world.
Thu Nov 24, 2005 12:29 pm
Quoting Knoxibus (Reply 14):
Do you have access to the AMM on the A380.Maybe you could look it up or ask someone about it.
regds
MEL
Thu Nov 24, 2005 9:24 pm
cymro
Fri Nov 25, 2005 7:28 pm
Quoting Keta (Reply 11):
All so far at least upto msn 018 and don't see any change soon.
I don't know 100% for what purpose I just know it is designed different.
Fri Nov 25, 2005 10:46 pm
Anyone working in Airbus Industries out here.Maybe we could get some data.
regds
MEL
keta
Sun Nov 27, 2005 3:16 am
Thanks Knoxibus, that's probably the answer! But still, why didn't they design the right-wing fairing the same as the left one? I mean, doesn't that make aerodynamic differences between both wings?
Quoting Zeke (Reply 16):
They look even in this shot http://www.jetphotos.net/viewphoto.p...32349
Hehe actually the left one looks bigger to me. Anyway, it's difficult to tell something from that pic, it's just too small.
Quoting Cymro (Reply 17):
Thanks for your info Cymro  Smile
Matt72033
Sun Nov 27, 2005 4:11 am
thats what i was going to suggest.....i remembered reading the 340 RAT was stowed in a flap track fairing and was wondeirng if they did the same on the 380!
Users browsing this forum: IAHFLYR and 1 guest
