Tg 747-300
MOCA, When To Use?
Wed Nov 23, 2005 10:36 am
Hi,
I have a little question regarding MOCA's vs MEA.
To my understanding: If for a given sector of an airway ( Victor and Colored) both a MEA and MOCA is provided, the MOCA will provide the required 1000 or 2000 obstacle clearance ( terrain dependent) and nav coverage within 22 nm of navaid,while the MEA will provide obstacle/terrain clearance as well as both com and nav coverage (with some exceptions)
I also understand that ATC can not assign you a MOCA if you're not within 22 nm of navaid.
So when is the MOCA actually used? In case of com failure? Or if your flying along an airway on your own (no atc)
tg 747-300
intentionally left blank
jspitfire
RE: MOCA, When To Use?
Wed Nov 23, 2005 12:23 pm
The way I understand it is ATC will clear you to the MOCA in an emergency. So for example if you need to get out of icing conditions or if you have an engine failure. I think they will also clear you to the MOCA if you are trying to get into an airport that doesn't have an instrument approach. They will let you go down for a few minutes and see if you can get into VMC conditions and proceed to your airport.
This is what I've learned in training, so someone correct me if I'm wrong.
Jason
pilottim747
Fri Nov 25, 2005 9:09 am
When flying using RNAV (area navigation). You aren't using ground navigation aids like VORs and NDBs so you don't need navigation coverage but you need obstruction clearance.
pilottim747
Aviation Photographers & Enthusiasts--Coordinate your life.
hamad130
Fri Nov 25, 2005 8:12 pm
HI ALL
actually I Agree with my friend JASON . moca used at airfield without IAP because if u have IAP u can descend to minimum safe altitude or min sector alt
which is inside 25 NM from navaid .
By the way we have also MORA & GRADE MORA ( we use it in emergency or when we want to descend with radar coverage)
thank u all
HAMAD
( A GOOD PILOT IS ALWAYS LEARNING )
spudsmac
Thu Feb 09, 2012 7:19 pm
I still have some questions about the MOCA after reading this. As I understand it, the MOCA guarantees obstacle clearance and also reception within 22 miles of the navaid. What about when the MOCA is more than 22 miles from the navaid. What then? I don't know what to tell my students and none of the other instructors seem to be able to give me a good answer.
http://skyvector.com/?ll=33.85385688...11.33461408690313&chart=405&zoom=3
There are plenty of examples in the link from skyvector. Take V528 for example, in a small piston aircraft, you would not normally be able to fly the published MEA of 16000, but if you were allowed to fly the MOCA, then you would be able to fly it. I feel like a rookie at the moment.
[Edited 2012-02-09 11:41:37]
JETPILOT
Fri Feb 10, 2012 12:55 am
In case of comm failure you fly the MOCA, MEA or last assinged whichever is higher.
Mir
Fri Feb 10, 2012 4:42 am
Quoting Tg 747-300 (Thread starter):
ATC, as I understand it, doesn't really care about MOCAs except for in instances where they have no radar. Where there is radar coverage available, they have Minimum Vectoring Altitudes which are often lower than the MEA or MOCA, since they only have to account for localized obstacles, and radar coverage, not obstacles or navaid coverage along a full section of airway. If you're under radar coverage, ATC can assign you altitudes as low as their MVA. That said, if I were in mountainous terrain, I'd feel a bit iffy about accepting such a clearance if it were a ways below the MOCA.
Quoting spudsmac (Reply 4):
Then you're guaranteed terrain clearance but not navaid reception. This presents no problem when navigating by GPS (though there are such things as GPS MOCAs, which may be higher than the regular MOCAs - don't ask me about how that makes sense, because I haven't a clue), so you can file any altitude at or above the MOCA that observes the regular altitude rules for flight plans. However, there are a couple of things to consider:
1) If you happen to be using an RNAV system dependent on VORs for its position, I wouldn't trust the MOCA - fly at or above the MEA.
2) I wouldn't fly an airway whose MEA I could not climb to if needed, unless conditions were VMC along the way. If my GPS quits on me, I'm going to need to use the VORs again, and that means getting up to the MEA. By happy coincidence, the places where the MEAs are going to be highest are around mountainous terrain, where you really want to be able to get guaranteed navaid reception if you need it so that you don't fly into something hard and unforgiving. If it's VMC, then no problem - just climb as best you can, hope the navaids work properly, and see and avoid terrain.
Quoting jetpilot (Reply 5):
Not quite correct. If you don't need the navigation coverage provided by the MEA (if you have GPS, for instance), you can fly at the MOCA if that is higher than any altitude you were assigned or have been told to expect - you don't have to go all the way up to the MEA.
-Mir
KELPkid
Fri Feb 10, 2012 4:55 am
MOCA is supposed to be for emergencies, but I've had to use it in real life when ATC rerouted my flight onto a different airway than I'd planned over the Cascades on a warm summer day, we just couldn't climb up to the MEA's on time. I advised ATC, and they were OK with it. We did get up to the MEA/ATC assigned altitude, just not before crossing the navaids/segment fixes
Mir
Fri Feb 10, 2012 5:04 am
Quoting KELPkid (Reply 7):
I'm interested in where you heard this, because 91.177(a)(1) makes it seem like it's perfectly fine for you to operate down to the MOCA as part of normal operations, provided you have appropriate navigation signals.
-Mir
jgarrido
Fri Feb 10, 2012 6:25 am
As a controller I've never had a need to know MOCA's. Now I haven't been doing this forever(10 years) and I haven't seen/done everything, but that's just my experience. For area's with radar I have MVA's and for those without radar I have MIA's. On occasion I've needed to know the MRA with a non-RNAV equipped aircraft and an airport where I wasn't able to vector to final, but that's about it.
n829th
Wed Dec 19, 2012 6:29 pm
I'm looking to see if I'm able to fly MOCA to avoid Oxygen requirements. I'm flying a PA-34-200T from KIWA to U42 and do not have oxygen on board. The MEA on V257 in 14,500 for a large part on the leg, but the MOCA is 11,200. I can easily fly 12,000 and stay legal. That is if I'm able to fly that leg at or just above MOCA, but under MEA.
KELPkid
Wed Dec 19, 2012 9:01 pm
Quoting n829th (Reply 10):
I don't know if it would be legal to flight plan that. The FAA's computers will kick out the flight plan if you don't file for at least the MEA. If you do file a flight plan at that altitude, then you have to carry supplemental O2 on board   FBO's used to rent the bottles, but it's been a long time since I've seen one that did.
Woodreau
Thu Dec 20, 2012 3:25 am
I use the MOCA when we've been cleared direct thru mountainous terrain and we're no longer on our filed routing (which is just about all the time)
So we're flying anywhere from FL360-410. Once we're cleared direct and not on flight plan routing all of the drift down decision points and planned enroute alternates from the dispatch release aren't valid anymore. So I use the MOCA as the lowest altitude I can go to if I need to do an emergency descent due to cabin depressurization. And I compare whether the MOCA is below my final driftdown cruise altitude to make sure I can stay above MOCA in the event of engine failure/OEI enroute.
That's just to give me a safe number until I can get a lower safe number from ATC or some other official number. I've never needed to use it in real life, but I keep it in the back of my mind as we're going direct over mountainous areas.
Mir
Thu Dec 20, 2012 11:25 am
Normally, you'd be fine doing that (assuming you weren't reliant on VOR navigation). There's nothing wrong with filing for above MOCA but below ME. Except that the problem in this case is that your route passes over the Grand Canyon SFRA, and you're not allowed to fly below 14,500' MSL on that airway in that area, thus the MEA - the MOCA listed is, in this case, for emergency purposes only.
You've got two alternatives. One would be either routing over V208 from GCN to PGA, then V293 to BCE and rejoining V257. The other would be to go from DRK via V562 to PGS, V235 to MMM, then V21 all the way to FFU (or DTA, depending on how you were planning on approaching U42). The first option is about 520nm, and the second option is about 510nm (in comparison to your original route of 470nm).
The third alternative would be to just go VFR and use the Dragon Corridor, which would allow you to cut across the canyon at 11,500 following fairly close to V257, then go direct to BCE to rejoin your airways. You'd get the benefit of seeing the canyon from above as well. However, I say this just from looking at the charts - I have no local knowledge of flying around the Grand Canyon, and I would seek out the opinion of someone who does before committing to that route.
-Mir
Users browsing this forum: Faro, groundbird and 2 guests
