tigermoth
QNE, QNH, QFE
Fri Nov 25, 2005 9:51 pm
I know they are altimeter settings but can someone explain what they mean and when they are used? Many thanks
Tristarsteve
RE: QNE, QNH, QFE
Fri Nov 25, 2005 10:07 pm
QNE Height above sea level at standard setting 1013
QFE Height above airfield
QNH Height above sea level.
Type QNE into google and there is a good description in the third ref.
julesmusician
RE: QNE, QNH, QFE
Fri Nov 25, 2005 10:26 pm
Basically the codes were meant to mean:
QFieldElevation
QNauticalHeight
QNauticalEquivalent
African Civil Aviation Commission president "You don't want to fly out as a passenger and come back as cargo."
CosmicCruiser
RE: QNE, QNH, QFE
Fri Nov 25, 2005 11:15 pm
Another gouge that I saw in Professional Pilot magazine many years ago:
Q oceaNHeight
Q Feet above Earth
Q staNdardprEssure
PW4084
RE: QNE, QNH, QFE
Fri Nov 25, 2005 11:39 pm
Here's another way of remembering these:
QNE = EASY, always 29.92
QNH = HARD, as in the ground is very hard... so set your altimeter properly.
QFE = simply field elevation
PW4084
tigermoth
RE: QNE, QNH, QFE
Sat Nov 26, 2005 4:03 pm
Thank you all for your replies. Its not really what each of the Q codes mean that i am unclear about, but solving problems related to Q codes (in ground school) that I cannot seem to understand..for example, how do I go about solving this quiz: (I hope I got it right)
"An a/c is flying at FL85 and is cleared to descend to 3500 feet on QNH 1000, but the pilot finds his altimeter stuck. To what height must he descend?"
Thanks / Tigermoth
FredT
RE: QNE, QNH, QFE
Sat Nov 26, 2005 6:45 pm
And how will he know, with his altimeter stuck?  Wink
Let us, for the sake of the discussion, assume that it is instead the altimeter setting (Kohlsmann) mechanism which has stuck.
First off, he should descend to a height of 3,500 feet ASL. That is what they tell him to do. How to actually go about this will become a bit tricky though, as he cannot change his altimeter setting which means his altimeter will misread.
1 hPa is approx equal to 30' of altitude.
If you increase the reference pressure (Kohlsmann setting), the difference between your current (lower) ambient pressure and the reference pressure increases. Your indicated altitude increases.
In the example given, you will be flying at an altimeter setting of 1013 when you should have 1000. This means your altimeter will overread by (1013-1000)*30 feet, or 390 feet. Descend to 3500+390=3890 feet of altitude.
Another way to think about it is "altimeter setting down, altitude down". Picture yourself at your intended 3,500 feet at the correct QNH of 1000. How would you get to your actual QNH of 1013? You'd increase QNH - alas, increase the indicated altitude.
noelg
RE: QNE, QNH, QFE
Mon Nov 28, 2005 6:48 am
Quoting PW4084 (Reply 4):
Unless you're anywhere outside of the USA. It's 1013 everywhere else!  Smile
I always remember by:
QNH: QNationalHeight
QFE: QFieldElevation
Warped logic in the NationalHeight but in my mind it means "Not the airfield height, the height of everything else"!  Smile
tigermoth
RE: QNE, QNH, QFE
Mon Nov 28, 2005 9:37 pm
Thank you Fred and Noel for your replies, getting clearer now.
Users browsing this forum: cvgComair, flyDTW1992 and 2 guests
