emrecan
Max. Cruising Altitude For Extra-long Flights
Fri Nov 25, 2005 10:16 pm
Hi everyone.
I am curious about the maximum cruising altitude for the long range flights. I mean 15-16 hrs flights. (SIN-LAX or SYD-LAX or SIN-JFK).
thnx for the replies
[Edited 2005-11-25 14:17:55]
cedarjet
RE: Max. Cruising Altitude For Extra-long Flights
Fri Nov 25, 2005 10:48 pm
Even on the longest of flights, they don't tend to go any higher than 39,000 feet. If the aircraft is right on it's max takeoff weight, they might spend more of the flight lower, ie 28,000 feet initial cruise, then a step climb as fuel burns off. I remember early 747-100s used to start the cruise at 25,000 feet (and people say the A340 is underpowered! haha!). The highest I've ever flown on a conventional airliner is 41,000 feet, but not necessarily on the longest flights. I remember hitting FL410 flying from London to Charlotte NC on a 767-200. I don't remember going above FL390 on any of the proper-longhaul flights I regularly do (eg LAX-SYD, NRT-LHR et al).
The exception is the 747SP. I spoke to the cockpit crew of the Iranair SP that took many of us a.netters around Cologne last year, and the captain said the 747SP is the most capable aircraft ever built - range, endurance, max altitude, speed etc. They were ferrying the SP empty back to Teheran, and had filed a cruise altitude of 43,000 feet. No other airliner can do that, no way.
emrecan
Fri Nov 25, 2005 10:53 pm
43,000 feet wowwwww
They were looking the world from the top  Smile
BBJII
Fri Nov 25, 2005 11:04 pm
Quoting Cedarjet (Reply 1):
Concorde could i think its was 55000,60000ft?...but now it flies at 000000ft  Sad
 wave
Remember: The Bird Hit You, You Didn't Hit The Bird.....
Art at ISP
Sat Nov 26, 2005 2:08 am
I recall once or twice on UA 767-200's being at 430 for the last leg of a transcon. It was likely due to winds, but it happened at least twice that I can remember.
SlamClick
Sat Nov 26, 2005 2:20 am
The B-767 is limited to 43,100 feet so it can cruise at FL430. (I suppose that depends on the local atmospheric pressure along the route, though that seems far-fetched.)
julesmusician
Sat Nov 26, 2005 2:54 am
I remember a flight I did on the flight deck of a 757. I specifically requested whether in the flight from London Heathrow to Edinburgh all of 1hr or so we could top 40,000. The captain said he would give it a go but it would be close. As we tagged the autopilot up to 40,000 we touched it for about two minutes before starting the descent. Probably cost BA considerable more fuel, but oil was cheaper then  Smile
J
African Civil Aviation Commission president "You don't want to fly out as a passenger and come back as cargo."
Mr.BA
Sat Nov 26, 2005 9:55 am
It's possible for airliners to cruise at very altittudes if theya re relatively light, usually close to the end of the trip nearing the destination. I've also seen on flight trackers SQ B747s crossing the atlantic at FL 390 climibng to FL 430 when closing in on the eastern US coast.
Boeing747 万岁!
star_world
Sat Nov 26, 2005 10:07 am
Quoting Julesmusician (Reply 6):
Hmmm I presume this was in a BA simulator rather than a real aircraft. BA captains don't just "give it a go" to reach altitudes that someone in the jumpseat requests....!
doug_or
Mon Nov 28, 2005 1:11 am
Quoting SlamClick (Reply 5):
why would local baro settings matter above transition alt?
When in doubt, one B pump off
SlamClick
Mon Nov 28, 2005 2:53 am
Quoting Doug_Or (Reply 9):
Well, as I indicated I consider it a little far-fetched but a possible problem. Because local baro settings are considered to affect the pressures at heights above the surface* On the other hand the type certificate limitation of 43,100 feet is expressed in altitude, not flight level.
So, presumablly when flying at FL430 if the air mass pressure in the region was very high, you might be higher than 43,100 feet absolute while indicating an even 43. It would not create a collision hazard because all aircraft would be flying with the 1013MB reference, but you might be flying at an absolute height greater than permitted by the type certificate.
Again, unlikely to cause you a problem, but theoretically against the rules.
* See the AIM, Section 7-2-2 regarding Lowest Usable Flight Levels with local altimeter settings lower than 29.93"hg (1013.2MB)
LY777
Mon Nov 28, 2005 3:07 am
most of the time, when I travell, we cruise at 37'000 feet
capt_smith
Mon Nov 28, 2005 1:13 pm
I was playing around with a GPS unit while flying WN from CMH to TPA and I swear the altitude I saw displayed after we reached cruise, was FL410. This varied a little, but stayed in that range for most of the flight. The funny thing is, I THOUGHT the capt. had mentioned reaching 39,000 f t. all the while I was seeing 41,000. Surely my GPS could not have been off that much. Can anyone explain what might have been going on?
CaptOveur
Mon Nov 28, 2005 2:09 pm
Quoting Capt_smith (Reply 12):
Pressure Alt was probably 39,000.. Actual Altitude could have been 41,000. As far as the Altimeter knew the airplane was at 39,000
Things were better when it was two guys in a dorm room.
Users browsing this forum: Alias1024, CALTECH, Caryjack and 1 guest
