cancidas
Premier's Hybrid Deicing System
Mon Nov 28, 2005 10:00 am
anyone ever get the chance to use premier's hybrid deicing system? it uses both forced air at a high pressure mixed with glycol to deice the airplane. they say that there are certain times where the air is enough to sufficiently clean the airplane. air is then mixed with the glycol in the nozzle before being sprayed on the airplane in an effort to reduce the amount of fluids used per application. has anyone here been lucky enough to use this system? what's it like. does it live up to the good reports?
more info on premier's site: http://www.premier-deicers.com/mt43i21hdse.html
we use a more traditional truck at my station, this one: http://www.premier-deicers.com/mt18.html
"...cannot the kingdom of salvation take me home."
pilotpip
RE: Premier's Hybrid Deicing System
Mon Nov 28, 2005 11:00 am
FX has some at STL. The mechanics, who do the deicing here, are not big fans of the compressed air. They think it isn't as efficient with snow and is worthless when it comes to ice. They end up using a stream of straight type II to deice and use just as much anyway. However, they do enjoy the enclosed cab.
DMI
Mon Nov 28, 2005 4:03 pm
Quoting Pilotpip (Reply 1):
Why do you say Mechanics doing de-icing.Are they a part of Mx.
regds
MEL
pilotpip
Mon Nov 28, 2005 4:58 pm
They have a small op with only two DC-10s nightly. Rather than pull employees from the sort and loading (which is a pretty efficient job and everybody already has a task) they have the mechanics do it. By the time the aircraft is ready to be deiced the mechanics have completed their daily check and assuming nothing's wrong, they're sitting around.
DMI
DC8FriendShip
Tue Nov 29, 2005 1:30 am
I know United has some in DEN, but as far as I know, they like them. I would love to at least try one out.
Come fly the Friendly Skies of United
cancidas
Sat Dec 03, 2005 9:39 am
i would love to get my hadns on one and just play with it for a day... just to see what it's like.
understandably, it seems like ice might ose a problem for the design of that truck.
Sat Dec 03, 2005 11:43 am
Quoting Pilotpip (Reply 3):
Are they provided training prior to be put on De-Icing duty.
regds
MEL
MissedApproach
Sun Dec 04, 2005 9:10 am
Here's a link I bumped into, USN testing the Premier system in Maine:
http://www.lakehurst.navy.mil/p2/servlet/DocServletPrint?wDID=343
We have two of the FMC AirFirst systems here. If we just have a half inch of light snow they sometimes clear planes with just air.
Can you hear me now?
pilotpip
Sun Dec 04, 2005 1:10 pm
MEL,
They're provided with reccurent training every year.
One of the big problems they have with the system here at STL (using the FMC AirFirst trucks) is that the snow is often wet and heavy. Apparently the airport has the third highest consumption of runway deicing fluid nationwide because of the nature of our snow. Unless it's bitter cold outside sweepers are virtually useless here.
DMI
Sun Dec 04, 2005 6:28 pm
Quoting Pilotpip (Reply 8):
And how is this Fluid delivered at the Airports.
How is it heated prior to use.
regds
MEL
pilotpip
Sun Dec 04, 2005 7:30 pm
Spray trucks. I'm pretty sure that the stuff (For the life of me I can't remember what the chemical name is, it will come back to me as soon as the ramp freezes and I start cussing about the landlord not using it on our ramp)they use on the runways isn't heated. There are three large tanks that are used to store the stuff.
DMI
ntspelich
Fri Dec 09, 2005 1:26 am
Forced air trucks are horrible. They're incredibly slow, you don't have the spray control you do in a bucket with a hose. We had one at BWI but it's out of comission and on its way to some other station after we complained about it so much.
United 717 heavy, you're facing the wrong way. Any chance you can powerback to get off of my deice pad?
cancidas
Wed Jan 25, 2006 9:30 am
the purchace of the FMC trucks sounds like a definite desk decision made without any research having been done into the nature of thier operation.
qm001
Wed Feb 15, 2006 6:21 pm
Hello all,
Forced air is a great concept, but like most concepts practically its a disaster as how would you determine hold over time using forced air. I have found in general that forced air actually uses more fluid that usual in most cases.
In principle the same is applicable for the infrared de-icing, at the end of the day, it takes longer than a full de-icing, and secondly, you would have to spray in any form of precipitation anyway.
Such concepts are great for small out of the way airports, but for major hubs, would cause major delays.
Thanks and brgds,
QM001 (167 Air Malawi)
I wish there was still a flying boat service on the African Lakes!
KBGRbillT
Thu Feb 16, 2006 1:32 pm
Quoting HAWK21M (Reply 9):
Glycol is delivered to airports usually by tankers over the road or rail cars. It is heated in each individual deicing truck by fluid heaters.
Quoting Pilotpip (Reply 10):
It's called Urea, but I think that everyone else is talking about A/C deicing not runway deicing.
Quoting Ntspelich (Reply 11):
Once you get proficient with a joystick controlled boom it is virtually as fast as a hand held hose, at least on the FMC Airfirst trucks.
I think the design of the Airfirst system was intended to remove large amounts of light loose snow real fast instead of using gallon upon gallon of glycol to wash the saturated pink snow of the surfaces. When used for this reason it is extremely fast and effective. I don't believe that it was intended to be effective on wet and heavy snow.
Quoting QM001 (Reply 13):
Explain how using forced air to remove as much frozen contamination as possible before applying deicing fluid would result in using more fluid than without the forced air. It doesn't add up, at the very most it would require the same amount of fluid to remove the same amount of contamination.
ORDsnowman
Tue Feb 21, 2006 6:06 am
Lets clear up a bit of this info....
Quoting KBGRbillT (Reply 14):
Actually, there are deicing operations in North America and other parts of the world where the fluid is heated in a central tank and distributed to each truck at a temp of 85C.
define virtually????? There is only one truck manufacturer in the world that this is true and that manufacturer is not FMC (or Premier, or Global)......
The original discussion began with fluid injected into the forced air, with that i will answer,
Heat breaks the bond between the aircraft and the adhering frozen precipitation. When the equipment manufacturer injects fluid into the forced air the fluid cools very quickly after it leaves the nozzle. Cool deicing fluid is not very effective and has an extremely short time before it refreezes during periods of active falling freezing precipitation.
cancidas
Tue Feb 21, 2006 7:22 am
ORDsnowman, what manufacturer are you talking about?
ORDsnowman
Wed Feb 22, 2006 6:57 am
L-188
Wed Feb 22, 2006 7:22 am
I don't know of anybody here in Alaska that uses air, save for the US Air Force.
Up here though that forced air system would probably make a lot more sense, since we tend to get a lot more very cold fluffy snow.
Where I worked we used to send our ramper out with a leaf blower and a ladder to get powder off the wings of our aircraft.
Users browsing this forum: 77west, AAairplane, Mani87 and 1 guest
