julesmusician
Slowair Airline - The Idea And The Questions.
Mon Nov 28, 2005 11:50 pm
Questions for those with a technical mind:
Suppose you operate "slowair" which instead of doing what every other airline does, this one slows down i.e. lets say on a London to Tokyo flight instead of around 12 hours they slow down and do a 14hr flight instead. This should save considerable fuel, and soon the companies financial sheets will show that they are using less fuel, and it is costing less. If the fuel costs are lower, then the fares can drop, and people will have to choice to pay less but add a few hours on their long haul flights.
The question is would this work and what would the technical problems be associated with it?
J
African Civil Aviation Commission president "You don't want to fly out as a passenger and come back as cargo."
PhilSquares
RE: Slowair Airline - The Idea And The Questions.
Mon Nov 28, 2005 11:54 pm
Quoting Julesmusician (Thread starter):
You wouldn't fit in with other traffic in the route structure. Generally, all the traffic is flying around the same MN. Or part of the ATC clearance is a MN to ensure separation.
Fly fast, live slow
julesmusician
Tue Nov 29, 2005 12:06 am
Yes but surely if you flight plan it in and say "i want my speed to be this" during the cruise ATC will factor it in?
PhilSquares
Tue Nov 29, 2005 12:21 am
No, they're not going to slow everyone else down to accomodate one aircraft. What would happen in your case is you'd be assigned a less than optimum (read lower) altitude. Your fuel burn would be even higher then and you'd lose more money!
Fly fast, live slow
greasespot
Also flying slower would not save fuel. It could actually cost more.
Airplanes tend to fly at or near design optimum. Any faster or much slower drag shoots up.. ...meaning more fuel burned.
Also if you fly slower you lose engine efficiency at altitudes.
GS
Sometimes all you can do is look them in the eye and ask " how much did your mom drink when she was pregnant with you?"
mandala499
Tue Nov 29, 2005 1:52 am
Cost Indexing... Aircraft Cost / Fuel Cost...
Anyways, happens often when SQ used to operate the 310s between CGK and SIN... over the delivery in SIN, a little exchange of words about Mach Numbers... when the 310 filed for the same FL only 5 - 10 mins ahead of a 777 going the same way, someone has to be given a different altitude, or the slower one to go behind the faster one.
I'm sure Phil and his employer doesn't wanna be held up on SIN-Europe on the same flight level and behind an A310 to India/ME... Either the 310 gets a different altitude to let faster traffic through at their levels, or the faster one gets a shortcut around a dogleg (gotta love hearing SQ744/777s requesting direct PARDI out of CGK to skip MES and BTH or fellow SIN bound traffic on the same flight level but at a much slower speed)... or someone gets a deviation to let traffic through or overtake slower traffic...
Slow everyone down and eventually traffic could clog up to the next FIR! And yes, theoretically it can happen!... (eg: the first time the Taliban affected my life when they took over Afghanistan... our poor 767 can't file the higher altitude it wanted going BKK-CPH due to the Afghan airspace being closed and 744s filling up the air routes all the way to the Persian Gulf... imagine if we were to go in front of 30 744s on the same flight level... by the time we reached the Arabian Peninsula, the backlog could be all the way to the Indian FIRs! J/K  Smile (Joke the crew made during cruise)
Mandala499
Oryx
Tue Nov 29, 2005 3:11 am
A totally different matter would be if it was possible to optimize aircraft to a lower cruising speed and if that could give you an improvement in fuel consumption. Additionally fuel efficiency is only one point in the economics. Delivering more seatmiles per hour with the same airfraime is another.
MrChips
Tue Nov 29, 2005 5:22 am
Not true at all.
Most aircraft have a very specific speed at which they achieve optimal fuel economy. Flying faster or slower than that speed will increase fuel consumption over a given flight.
Most modern airliners are optimized for flight somewhere between 0.76 Mach and 0.85 Mach; of course, it varies by type, but for the most part, speeds are very close to each other.
Furthermore, the airlines have what is known as a "cost index" for each flight. This is entered into the FMS prior to the flight (or is entered into the flight planning software at dispatch), and plays a major role in determining altitudes and cruise speeds for the flight. Any deviation from the pre-determined parameters will increase the cost of the trip to the airline.
Time...to un-pimp...ze auto!
Users browsing this forum: flight152 and 1 guest
