f.pier
ILS IIIb And Cat. I Approaching?
Wed Nov 30, 2005 12:57 am
Look at this NOTAM
B6869/05 NOTAMN
Q) LIMM/QFAXX/IV/NBO/A/000/999/4525N01019E001
A) LIPO B) 0512010500 C) PERM
E) ACFT SPECIAL PROC FOR LOW VIS CONDITIONS. LOW VIS PROC (LVP)
ENCLOSED TO AIRPORT CIVIL AVIATION AUTHORITY ORDINANCE NR
143/2005 WILL BE APPLIED DURING CAT II, IIIA IIIB AND LVTO
(LOW VIS TKOF) OPS. PILOT WILL BE INFORM WHEN LVP ARE AT Macedonian Airlines (Greece)">IN FORCE
BY RADIOTELEPHONY. MNM USED BY THE OPERATORS MUST BE ACCEPTED
BY APPRPRIATE CIV AVIATION AUTHORITY AND CAN'T BE LESS THAN
RVR 100M. TWY A IS PROVIDED WITH 6 IHP (INTERMEDIATE HOLDING
POSITION) FM A6 TO A1 FM TWY AB TO TWY AA.
IHP REPORTING IS MANDATORY AT Macedonian Airlines (Greece)">IN VIS 2 AND VIS 3 CONDITION
FOR DEP: FOLLOW-ME PRECEDES ACFT FM PARKING STAND TO A3
IHP THROUGH TWY E OR D, THEN ACFT WILL REPORT A2, A1, HOLDING
POIT 32 WITH A MNM SEPARATION OF 1 EMPTY SECTION BTN
SUBSEQUENT TFC.
FOR ARR: ACFT VACATE RWY32 AT TWY AB THEN IT WILL REPORT AT IHP
A6, A5, A4 WITH A MNM SEPARATION OF 1 EMPTY SECTION BTN
SUBSEQUENT TFC.
FM A4 FOLLOW-ME WILL GUIDE ACFT TO PARKING STAND.
WITH RVR LESS THAN 150M ONLY 1 MOV AT TIME IS ALLOWED.
DURING LOW VIS PROC PAPI SYSTEM WILL BE SWITCHED OFF.
REF AIP AGA 2-11.3.2, 2-11.3.3 AND 2-11.5
B6868/05 NOTAMN
E) INSTR CAT I, II AND III OPS ARE ALLOWED UNDER CONDITIONS INCLUDED
AT Macedonian Airlines (Greece)">IN LOW VIS PROC APPROVED BY AIRPORT CIV AVIATION AUTHORITY ORDINANCE
NR 143/2005. THE OPS MUST BE AT Macedonian Airlines (Greece)">IN COMPLIANCE WITH PUBLISHED APPROACH
PROCEDURES AND RELEVANT NOTAM.
REF AIP AGA 2-11.3.2/3 AND 2-11.5
B6867/05 NOTAMN
E) LVTO (LOW VISIBILITY TKOF) OPS ARE ALLOWED UNDER CONDITIONS
INCLUDED AT Macedonian Airlines (Greece)">IN LOW VISIBILITY PROC APPROVED BY AIRPORT CIV AVIATION
AUTHORITY ORDINANCE NR 143-2005.
REF AIP AGA 2-11.3.3 AND 2-11.5
What do I understand form these NOTAMS? That, starting since dec the 1st, this airport will work with ILS cat. IIIB.
But... is it possible that, because of the SMR missing, only ILS cat. 1 approaching are allowed?
What does it mean to have cat I approaching? That this airport will always work Cat. I until the SMR will be installed?
Thank You.
[Edited 2005-11-29 16:57:47]
CosmicCruiser
RE: ILS IIIb And Cat. I Approaching?
Wed Nov 30, 2005 6:57 am
Looks to me like it's just a NOTAM regarding Low Vis taxi routes and procedures. It states that it is effective under CATII, IIIA&B and Low Vis T/O. It also says it CAN include CATI as well.
Users browsing this forum: BobbyPSP, N353SK and 2 guests
