zarniwoop
When To Start Turning?
Fri Dec 09, 2005 6:19 pm
I was wondering.....
How do you know when to start a turn?
For example when you are cruising and you are coming up to a waypoint and you need to make a turn at the waypoint to take a different jetway. How far from the waypoint do you start your turn to intercept the different course?
Would it be any different when you are flying slow on an instrument approach?
I guess it is not hard to judge in a small light aircraft but in a large airliner travalling at M0.8 you have to think about it a bit more?
Is it all based on a standard 2 minute turn?
Thanks in advance......
Pihero
RE: When To Start Turning?
Fri Dec 09, 2005 8:46 pm
Quoting Zarniwoop (Thread starter):
A "rate one" turn as it is (still ? ) called would call for a bank angle roughly equal to 15% of the ground speed. For passengers' comfort, airliners restrict this bank angle to 30°.At cruising speed of 500kt, the rate one will be achieved with an angle of 75°, which is above the design load factor.
The turn anticipation can be computed. A rate one turn and for a course change of 90°, it is worth 20 sec of flight :A combat airplane at 480kt would start turning some 3 Nm before the waypoint.An airliner under autopilot, restricted to 25° of bank woult start at 9 Nm.
Note that they won't fly over the waypoint.
Contrail designer
joness0154
Fri Dec 09, 2005 11:49 pm
Quoting Pihero (Reply 1):
It depends. Some approaches (GPS comes to mind) have waypoints specified that you must fly over.
Well, flying IFR you don't want rate of turn outside the standard rate. But the faster the aircraft, the slower the rate of turn
Small slower aircraft have 2 minute turns
A lot of military aircraft have 4 minute turns, so that bank angle isn't overly excessive.
I don't have an attitude problem. You have a perception problem
Pihero
Sat Dec 10, 2005 1:12 am
Quoting Joness0154 (Reply 2):
You're right but see the question. It has to do with anticipating the course change.
Contrail designer
joness0154
Sat Dec 10, 2005 1:19 am
Quoting Pihero (Reply 3):
Yeah, I understand now, sorry I misread it the first time.
CosmicCruiser
Sat Dec 10, 2005 2:09 am
In most modern jets the FMS has computed the turn and won't exceed 25 deg of bank. Unless the specific waypoint is a mandatory flyover point the turn will "undershoot" the waypoint so as not to "overshoot" wide on the airway, assuming a large change in course heading.
Sat Dec 10, 2005 2:50 am
Follow the flight director.
Depends on how you program the FMC/FMGC, still follow the flight director.
Users browsing this forum: lightsaber and 1 guest
