lnglive1011yyz
Wing Differences 737 Classic To 737NG
Tue Dec 13, 2005 10:10 am
Can anyone here speak to or point me in the direction on the differences between the 737 Classic wing to the 737NG wing?
In specific, I'm looking for the technical aspects of the wing, as well as what helps allow the NG to fly at higher altitudes..
Any help would be appreciated!
1011yyz
Pack your bags, we're going on a sympathy trip!
SlamClick
RE: Wing Differences 737 Classic To 737NG
Tue Dec 13, 2005 11:26 am
For starters the span is about 18 feet longer on the NG. Since the overall planform shape is rather similar the wing area is substantially larger. As to airfoil section differences and highlift devices differences, I'll let my ignorance rule and shut up now.
saab2000
Tue Dec 13, 2005 11:36 am
I cannot speak to the design of the wing, but I do know some pilots who flew the 737-700 right when it came out. They were qualified on the -300 and on the -700. They loved the -700 and said that it had better handling qualities at slow speed and at high speed. That is vague, but I know that the plane I fly does not really like to fly slow and so I sort of know what he means.
I think that computer modeling of fluid dynamics allowed Boeing to make a better all-around wing.
But like SlamClick will now say I have said enough. I just know that pilots who have flown both say that the new one is better from a pilot's perspective.
smrtrthnu
dw747400
Tue Dec 13, 2005 12:52 pm
I believe the triple-slotted flaps of the original wing were replaced with double-slotted flaps. This reduces weight, maintenance, and flow noise. I’d imagine more powerful engines and the larger wing makes up for any loss in lift.
CFI--Certfied Freakin Idiot
brettdespain
Tue Dec 13, 2005 2:27 pm
The 737 classic wing has a leading edge "cuff" that added maneuvering at low speeds. The NG doesn't have that cuff. Also the NG has a true supercritical airfoil that is very similar in design to the 777's wing. Also, the NG wing is swept back a few more degrees and doesn't have the double swept "cranked wing" that was seen on the 737 classic design and the 727 as well.
Yes, the wing is longer, however aileron placment is the same, the added wing dimension is outboard of the aileron.
The flaps are double slotted now and extend further aft and down. Another interesting bit of trivia is that the most outboard leading edge slat panel is not anti-iced. Thus Boeing has restricted the NG from holding in icing conditions with the flaps extended.
As a side note, the NG is so aerodynamically slippery that you have to plan your descents well in advance as it does not slow down rapidly. The wing is very effecient. Last week on a flight from SLC to DCA we had a payload of 145 pax, flying at FL370 at .80 mach and our fuel flow was just over 5,600 pounds per hour. A similiar flight in a 727 at the same speed would have yielded a fuel flow of about 9,000 pounds per hour.
As to how it flies..... Smile  Smile  Smile  Smile
V1...Rotate.
aeroweanie
Tue Dec 13, 2005 2:45 pm
The 737 Initial wing was designed for the gross weights that the 737-200 started life at. By the time the aircraft had grown to the Adv models, the wing was overloaded. At cruise, it was flying at a higher lift coefficient than it was designed for, which increased drag.
On the 737 Classic, a new leading edge was added outboard of the engine, that increased chord by 4%. The new leading edge helped abit, allowing the Classics to grow to the highest GW -400, but they were still cruising at high lift coefficients and they were slow (Mcruise=.74 on a good day).
The wing of the 737 NG is much larger (both chord and span), decreasing the wing lift coefficient, plus the airfoil has been redesigned to have a higher drag divergence Mach number. For this reason, the NG can cruise faster and climb higher.
Here is an overlay I created of the 737-200 (black), 737-300 (blue) and 737-700 (magenta) where you can see the differences. This drawing was made using the .dwg files available on the Boeing website.
http://i4.photobucket.com/albums/y120/Aeroweanie/Overlay.jpg
A little comparison (info from airliners.net):
Initial model wing area: 980 feet^2
737-100 MTOW: 110,000 lbs Wing loading: 112 lbs/feet^2
737-200 MTOW: 129,500 lbs Wing loading: 132 lbs/feet^2
Classic model wing area: 1135 feet^2
737-300 MTOW: 138,500 lbs Wing loading: 122 lbs/feet^2
737-400 MTOW: 150,000 lbs Wing loading: 132 lbs/feet^2
737-500 MTOW: 133,500 lbs Wing loading: 117 lbs/feet^2
NG model wing area: 1344 feet^2
737-600 MTOW: 143,500 lbs Wing loading: 107 lbs/feet^2
737-700 MTOW: 154,500 lbs Wing loading: 115 lbs/feet^2
737-800 MTOW: 174,200 lbs Wing loading: 129 lbs/feet^2
737-900 MTOW: 174,200 lbs Wing loading: 129 lbs/feet^2
See how the wing loading on the Initial and Classic models got really high, while the NG started out lower, allowing more room for growth?
[Edited 2005-12-13 07:06:25]
Grbld
Tue Dec 13, 2005 7:37 pm
Nice overlay and data AeroWeanie!
The flap system on the 737NG is a great improvement, it was copied from the 757 flap system.
Quoting Brettdespain (Reply 4):
Brett, those engines I love on the NG, beside all the ancient clutter and stuff Boeing left on that plane. They're quiet and state of the art (although you still have to manually turn the igniters on all the time, aargh!). But I was amazed even more when riding the jumpseat with some colleages on a 772ER. At FL370 with a GW of 230T (kilos, almost full load) it was burning just 2800 kilos of fuel per hour per engine. Later, checking this on an NG with our full load and 60T gross weight, we we're burning 1200 kg/hr per engine. So the 777 weighed almost 4 times as much and used barely 2.5 times as much fuel. Excellent! So I see it's just a tad more than that 727!
Grbld
brettdespain
Tue Dec 13, 2005 9:45 pm
Hey Grbld,
That 772ER you rode jumpseat on - what engines were those: Pratt, GE or Rolls? It's an amazing aircraft! I have yet to fly on one. The effeciencies offered in the 787 should be even more amazing.
Brett
V1...Rotate.
Grbld
Tue Dec 13, 2005 10:28 pm
It's a KLM 772ER so I think they're GE90s? I don't keep track of all the other engines  Smile
Grbld
Wed Dec 14, 2005 5:00 am
Quoting AeroWeanie (Reply 5):
Nice Effort Aeroweanie.
The Exterior NG Wing to Fuselage Taper is very streamline compared to that of the Classics.
regds
MEL
lnglive1011yyz
Fri Dec 16, 2005 9:50 am
Thanks everyone for your information..
Aeroweanie, what a fantastic response.. Thanks!
1011yyz
GQfluffy
Fri Dec 16, 2005 5:14 pm
LoL. You do realize that the 727 has three engines designed in the 60's that may eat a bit more fuel. And that the 727's wing was one of marvel, and is still considered an advanced design.
This isn't where I parked my car...
Thrust
Sat Dec 17, 2005 11:28 am
The triple-slotted flaps of the wing were indeed replaced by double-slotted flaps. In addition, the new wing is considerably greater in span than the old one. To go even further, the engines of the NG are quieter, more fuel efficient, yet produce more thrust than the engines of the 737 classic.
Fly one thing; Fly it well
nonfirm
Sun Dec 18, 2005 5:57 pm
Some other changes were the addition of the frangible fitting just under the lip of the wheel wells to prevent gear retraction due to and inbd tire blow out the air cond sys is all different closer to the 200 series also the acm's require no oil also the apu compartment has no more bath tub covering the apu the hole above the apu exhaust provides cooling air for the compartment the brake of the a/c are no longer held on with 10 bolts they are a floating brake like the MD-80 also the Eng cowl are made of sheetmetal again instead of comp's.these are just a few of the other changes.
Users browsing this forum: EricAY05 and 2 guests
