thyengine
Fan Blade Tip Clearance
Thu Dec 15, 2005 11:19 pm
You know, in ESM's (Engine Shop Manual) are Fan blade tip clearance limits(min,max). This tip clearance gives different performance resullts (EGT,EPR..etc.) between test cell and on-wing.
Could anybody make a comment what the result would be both in test cell and on-wing If we either adjust the clearance to min or max?
fr8mech
RE: Fan Blade Tip Clearance
Fri Dec 16, 2005 10:01 am
Greater tip clearance results in reduced engine efficiency due to the air escaping between the tip and shroud.
A clearance closer to the minimum will increase efficiency but depending on how close the tolerance is, may run the chance of fan lade rub. This may be a simple rub on the abraidable lining or cause an unacceptable vibration condition.
liedetectors
Fri Dec 16, 2005 1:06 pm
Quoting Fr8Mech (Reply 1):
This correct. One way they get around this is for the tips to actually slice into a foam like material to better seal around the tips. I was skeptical at first but when i saw this in person i was made a believer. Another techique is to determine how much the blade will expand due to thermal expansion and design the casing to expand as well to avoid the casing deterioration.
I do believe the engine makers use a combination of both, thus when the blade expand they slice into the foam to make a good interference to prevent air leakage.
If it was said by us, then it must be true.
2H4
Fri Dec 16, 2005 1:14 pm
Quoting Thyengine (Thread starter):
What variables account for the difference between performance results on-wing and off-wing?
2H4
Intentionally Left Blank
thyengine
Fri Dec 16, 2005 10:11 pm
Quoting 2H4 (Reply 3):
What variables? We can just take on EGTM for the whole performance variables...
manzoori
Mon Dec 19, 2005 12:33 am
Carcass bending due to G loading primarily.
On a testbed the engine is very static whereas on wing at the end of the take-off run when the pilot pulls back on the stick, the rotation of the aircraft an hence the pylon introduces all sorts of G and gyroscopic loads into the engine carcass which will result in some degree of deformation. This can lead to increased tip rubs.
hth
Rez
 Big grin
Flightlineimages DOT Com Photographer & Web Editor. RR Turbines Specialist
2H4
Mon Dec 19, 2005 2:13 am
Quoting Manzoori (Reply 5):
Ahhhhh....thanks, Manzoori! It seems so obvious now...
2H4
Users browsing this forum: Google [Bot] and 17 guests
