777DadandJr
Stall Vs. Super Stall
Fri Dec 16, 2005 3:30 am
Can someone explain the difference between the two?
Also, what is the effect of the "T-tail" design, relating to the super stall condition?
Thanks in advance!
Russ wave
My glass is neither 1/2 empty nor 1/2 full, rather, the glass itself is twice as big as it should be.
ArmitageShanks
RE: Stall Vs. Super Stall
Fri Dec 16, 2005 3:34 am
Check this out. All the info you need!!
http://en.wikipedia.org/wiki/Deep_stall
usnseallt82
Fri Dec 16, 2005 3:45 am
Quoting 777DadandJr (Thread starter):
The most practical explanation...........recovery v. crash.
Crye me a river
Fri Dec 16, 2005 4:16 am
"Ordinary" stall:
- Airflow over the wing is disrupted such that it loses lift. Contrary to common belief, this can happen at any speed (high G turn can make a plane stall) but is more common at low speed.
"Deep" or "Super" stall:
- When a plane in a stall condition has a T-tail the stabilizer can fall into the jetwash of the wing. Thus there is no airflow over the stabilizer, and no stabilizer authority. This makes recovery tricky at best.
Compressor stall:
- When airflow through the engine compressor is disrupted. In many ways the same as a wing stall but for engine compressor blades.
777DadandJr
Fri Dec 16, 2005 4:59 am
Thanks for the info guys!
Very helpful.
Russ Big grin
