Afolts Card - B752 Fire Detection System.
Tue Dec 20, 2005 1:19 am
Anyone having a picture of an Automatic Fire and Overheat Logic and Test System [AFOLTS] detection card in the B752 Fire Detection system.
regds
MEL
Tristarsteve
RE: Afolts Card - B752 Fire Detection System.
Tue Dec 20, 2005 4:35 am
The things you think up to ask questions about!
It is a printed circuit card that slots into a box. They slide in and out easily and are interchangeable. Looks like any computor card.
Wed Dec 21, 2005 12:22 am
Quoting TristarSteve (Reply 1):
Since our B752SFs arn't due until June 2006.I wanted to see the Card in question.Hoping someone had a pic. Smile
regds
MEL
Tristarsteve
Wed Dec 21, 2005 1:27 am
You have picked a good aircraft. I like the B757. It has enough BITE to make it easy to troubleshoot, but not too much electronics to make it hard. There is no CMC, you have to go to all the boxes to do BITE, and they are all over the place. Fwd Equip, Fwd freight and Aft freight on some B757. An being a well developed aircraft it has a good MEL.
I see a couple every day.
Wed Dec 21, 2005 1:52 pm
Hows the RB211s compared to the P&W 2040 Mx wise.
regds
MEL
fr8mech
Thu Dec 22, 2005 10:13 am
Quoting HAWK21M (Reply 4):
We have more suging problems with the RB211, but it's a stout engine. Very little trouble with FOD damage. The pnuematic system on the PW leaves a little to be determined, but the engine is OK. I believe the numbers will say the RB is more reliable.
Thu Dec 22, 2005 7:34 pm
Quoting Fr8Mech (Reply 5):
Any stats available.
regds
MEL
fr8mech
Fri Dec 23, 2005 12:35 pm
The only stats I have is my experience. I have never, not once, had to blend blades on an RB211, Blending blades on a PW is routine work.
MD11Engineer
Fri Dec 23, 2005 2:50 pm
The PW2040 used to have some issues with the 10th and 11th stage HPC stator vanes (cracks) and the 5th stage LPT blades (blade clashing, rotor blades against moved stator segments), but due to mods carried out during engine overhauls (replacement of the offending stator segments with a redesigned version and replacement of the 5th stage LPT stators with a redesigned version), the problems have been fixed. Up to the mods, regular boroscope inspections (a bitch especially on the 11th stage HPC, since there is no normal boroscope access to this zone, you've got to go in from the 12th stage and carefully thread the probe through the 12th stage rotor and stator with a high risk of getting stuck, happened to me once, the tip of the probe tore off when I tried to remove it, resulting in an unscheduled engine change. But I've heard this is a regular incidence in these inspections, so I never had any problem with the airline about it) were mandatory to catch the cracks and blade clashing as early as possible and to pull the engine if necessary.
AFAIK, the RB211 gives a better performance in hot and high situations, but the PW2040 is a bit cheaper.
Jan
Fri Dec 23, 2005 11:59 pm
Quoting MD11Engineer (Reply 8):
Damn.  Sad Wasn't there anyway to extract it out.Mechanical fingers.What were you thinking that night at home.
regds
MEL
fr8mech
Sat Dec 24, 2005 8:52 am
Quoting HAWK21M (Reply 9):
Damn. Wasn't there anyway to extract it out.Mechanical fingers.What were you thinking that night at home.
regds
We've had it happen a couple of times. I found the T5 inspection harder to do than any in the compressir. You need to snake in between 2 stator sets and then look at the base for eveidence of clashing. Luckily you only need to do it at 2 points (180 deg) on the engine.
MD11Engineer
Sat Dec 24, 2005 3:54 pm
I actually found the T5 inspection quite easy. You'll need a guide tube to deflect the boroscope probe aft and a real thin boroscope (I used an old Machida 4mm boroscope without camera). Then it is a piece of cake. Just don't forget to count the sets of blades and vanes you pass through to be shure that you are looking at the correct stage.
In the case of the torn off probe, maintenance control told me not to worry, since I wasn't the first person to whom it happened.
A few days after the engine change we had a specialist in from Pratt & Whitney, who opened a bleed duct and used another boroscope with an attached mechanical finger to recover the boroscope tip. We wrote the engine servicable and used it as a spare (we always had one engine for each aircraft type based on the station in stock, after all we were the European main base back then).
Jan
Sat Dec 24, 2005 10:07 pm
Quoting MD11Engineer (Reply 11):
Ok great.It was Extracted.I presumed it had to be sent for Overhaul to be dismantled sectionwise to retrieve the probe.
regds
MEL
Users browsing this forum: TZTriStar500 and 22 guests
