julesmusician
Boeing 737/747 Sequence Of Pre Landing Events
Wed Jan 11, 2006 5:39 am
Morning all,
Having been playing flight sim for a while I am getting myself into a total confusion.... If you are landing at an airport and air traffic control say "make straight in 27R or whatever" how would you set the approach? I see two ways - either you can get the autopilot to fly a GPS approach and then let it take you to the ILS or you can fly a NAV approach, but this is where I am getting into a mix:
The sequence I usually use is :
(1) set the autopilot to a height and then let the GPS setting of the autopilot take me to the ILS. However if I arm the APP switch mode for the autopilot and the height hold is set on the autopilot it won't switch off the hold part and although it follows the directional course it sticks to the same height and will not descend down the ILS.
is this how it is done in real life or should I be using the NAV function of the autopilot before i even get to the ILS?
AND the second question is - if flying down the ILS once the APP side of the autopilot is working and not doing an autolanding what would be the usual height of switching off the autopilot and finishing the landing?
Thanks  Smile
J
African Civil Aviation Commission president "You don't want to fly out as a passenger and come back as cargo."
David L
RE: Boeing 737/747 Sequence Of Pre Landing Events
Wed Jan 11, 2006 5:53 am
Quoting Julesmusician (Thread starter):
Wouldn't ATC have given you a vector to the ILS before that? My understanding of "make straight in" is that I'd stay on the heading they'd given me until I'd captured the localiser and then I'd be free to turn on to it. I'd be interested to see what the real flyers say.
julesmusician
Wed Jan 11, 2006 5:57 am
i think flight sim is very rare as of course most airports will vector you right up to the ILS, but in flight sim you can be a long way off and the voice just says "make straight in"....
David L
Wed Jan 11, 2006 6:30 am
Quoting Julesmusician (Reply 2):
OK, I haven't experienced that.  Smile
MDorBust
Wed Jan 11, 2006 6:43 am
Silly game.
You are flying IFR category flights under VFR flight rules.
"Straight in" means that your approach is cleared without performing a standard pattern (Downwind, Base, Final). Just go for the final.
You shouldn't be getting a vector to the ILS since you shouldn't be useing an ILS approach.
I believe that most current version of MSFS will give you vectors all the way onto the ILS IF you are actually flying an IFR flight plan.
"I KICKED BURNING TERRORIST SO HARD IN BALLS THAT I TORE A TENDON" - Alex McIlveen
bri2k1
Wed Jan 11, 2006 6:54 am
Not to debate the merits of FS, but it's not that silly if you think about it. If someone had the desire and capabilities to fly around in a 737 under VFR, they could, and they might even get cleared to make straight in to a runway. Obviously, most people are going to want to be in Class A airspace with a jet, so they'll be on an IFR flight plan, and while they might get cleared for a visual approach, that can't happen until the runway is in sight, so they'll probably get vectored around a little -- which can also happen in FS, at least, version 2002. They speak a little slowly and formally, but it's got a hint of realism.
Whether you're in a simulator or the real world, "make straight in" would imply a visual approach, since an instrument approach would begin at the culmination of a STAR or ATC vectors to the localizer. You wouldn't be using a localizer for a visual approach. (Of course, you could, but it's not part of the visual approach.)
If you set up an IFR flight plan in FS, you won't get told to "make straight in" unless you choose the visual approach once you are close to the field.
You're the chief pilot of your own airline in FS, so you can choose when to turn off the autopilot. It's much more challenging (fun) to hand-fly it though. If you can actually fly it well, go back and add IMC and crosswinds.
Position and hold
David L
Wed Jan 11, 2006 9:07 am
Quoting Bri2k1 (Reply 5):
I can see where the confusion lies. I wasn't thinking specifically about VFR since I get the "make straight in" when I'm IFR in FS. Maybe a discrepancy in FS then? I certainly don't hear that instruction very often on my scanner but I'm in the UK. Come to think of it, it's more common to hear an aircraft vectored to the ILS with the addition of "close the localiser from the left/right, report established" so I guess the clearance to join the ILS is implicit. That instruction doesn't seem to be used in FS - maybe it's a non-US thing?
[Edited 2006-01-11 01:08:19]
[Edited 2006-01-11 01:15:39]
DColeMAN
Wed Jan 11, 2006 9:14 am
Quoting MDorBust (Reply 4):
Correct.
You need to be just below the height at which you start to descend down the glideslope, shortly before establishing it. This is usually no higher than 2500ft (2000ft to be safe). It will start descend down it if you follow this method correctly, honest Smile
I take it you mean when landing in poor visibility? If so, I believe you are able to disconnect the A/P once you have the airport/approach lights in sight.
Dale
Topless Women Drink 4 Free
DColeMAN
Wed Jan 11, 2006 9:19 am
Quoting David L (Reply 6):
No, the ATC in FS is just $hite Wink
David L
Wed Jan 11, 2006 9:23 am
Are you using an FS aircraft with a "GPS/NAV" switch? If so, I think this may be more of an FS (i.e. Hobby Discussions) thing.
AmericanAirFan
Wed Jan 11, 2006 9:27 am
As far as ATC goes try hopping online with VATSIM. I don't know much about real world flying but I know that FS can't compare completely. Also why use the GPS? Just set the HDG switch and once you're about to cross the localizer disengage the HDG switch and engage the APP switch for ILS.
"American 1881 Cleared For Takeoff One Seven Left"
David L
Wed Jan 11, 2006 9:49 am
Julesmusician: Which aircraft are you flying in FS?
David L
Wed Jan 11, 2006 7:31 pm
Quoting David L (Reply 11):
By that I mean are you using the default FS 737 and 747 or add-ons?
The default 737 and 747 don't have proper Flight Management Systems, just GPS and radio navigation, and they're mutually exclusive. You need to use GPS or Heading mode to get yourself to the localiser. When you pick up the localiser, you need to make sure your GPS/NAV switch is set to NAV and use LOC and APP modes as appropriate. In reality, the later Boeings certainly don't have an FS-style GPS/NAV switch and I'm pretty sure the older ones don't, either.
For how it's done in the real world, see the earlier discussion, Approach Mode On Autopilot - Questions (by Julesmusician Nov 2 2005 in Tech Ops) and assume you're in HDG or LNAV mode prior to interception.
I still suspect this is more of an FS question. As suggested before, you really should take a look at the PMDG 737NG and 744 offerings. They're far closer to the real thing and you have the hydraulic, pneumatic and electrical systems, as well as the full FMS with FMC. I can't bear the default aircraft since I got my hands on those.  Smile
Wed Jan 11, 2006 10:21 pm
There are many servers online which allow FS to be played with ATC handled by other players. This should give a more realistic experience.
PhilSquares
Wed Jan 11, 2006 10:47 pm
Shouldn't this be in a different forum? Certainly not here!!!
Fly fast, live slow
bri2k1
Wed Jan 11, 2006 11:11 pm
Quoting PhilSquares (Reply 14):
I struggled with that, too, but the original poster appears to want to use your knowledge to simluate flight as realistically as possible. You should be flattered  Smile I know it's much more fun to fly the Class D full-motion simluators with a type-rated pilot or instructor than just a few friends for the same reason.
Position and hold
David L
Wed Jan 11, 2006 11:47 pm
My thoughts, too. I think the problem centres around a switch which appears in FS but not in real 737s and 747s.
PhilSquares
Thu Jan 12, 2006 12:24 am
Quoting Bri2k1 (Reply 15):
First of all, I don't even have FS, do I can't even begin to talk about how to use "real" procedures to fly FS.
Secondly, the entire scenario is really tough to follow. If you're cleared a "straight in" that's a visual approach. You turn the flight directors off and fly the aircraft. I don't care if it's a 744 or a J-3, it all works the same.
For an ILS, in the real aircraft there is no "GPS setting". If you have the autopilot in CMD and arm the approach, when you intercept the GS it will descend down along the GS, so I again, I don't know how FS works, so I can't even begin to discuss it.
That's why this thread belongs in another forum!
Fly fast, live slow
bri2k1
Thu Jan 12, 2006 1:39 am
I see what you mean. I was interpreting "fly a GPS approach" the wrong way. I thought the poster was referring to a published approach procedure using GPS. I see now it's more likely the poster entered the airport as a direct waypoint in the on-board GPS of the default FS plane and used that to navigate automatically to the airport. If that's the case, you're certainly correct in that it is highly unrealistic and would get better answers in a flight simulation forum.
Position and hold
David L
Thu Jan 12, 2006 2:06 am
... Although I did learn from this thread that a "straight in" is for a visual approach only. I guess Uncle Bill got that wrong in FS.  Smile
julesmusician
Thu Jan 12, 2006 7:44 am
I am not sure I agree, I am trying to find out how it is done in real life - that is the technical side of each stage to compare with how it is simulated and to compare the differences in real life and sim.
There may be total differences between FS and real life. The 737 and 747 on flight sim allow you to navigate in two ways on the autopilot. They can use a predefined route course plotted on the Garmin GPS going from waypoint to waypoint. You can then ask it to fly you on GPS an approach on any runway into an airport and it will set you right up on finals. There is no radio beacons involved until reaching ILS.
The key point here is if you are going to a quiet airport if ATC can tell you to make your own way to the ILS by your own navigation equipment or are they always going to vector you every time? It seems that if there are no other aircraft around there is no earthly reason why a pilot cannot decide how they want to approach the ILS and make there own turns etc..using their "in house" equipment.
However it appears that maybe GPS navigation to finals is never done in real life...and if you are navigating on your own to an airfield finals it is still done on radio beacons...
J
PhilSquares
Thu Jan 12, 2006 8:16 am
Quoting Julesmusician (Reply 20):
It doesn't happen like that in real life. You might be vectored to a IAF (Initial Approach Fix) and then fly the entire procedure. It could be an arc, a procedure turn, or a series of intermediate fixes to the to the course. But, most likely it will be radar vectors, since that normally provides for the most efficient arrival rate.
It's not uncommon once you see the field, especially in the US, where the controllers will ask you if you "have the field in sight" If you reply in the affirmative, then you're cleared for a "visual". If you don't want to that just reply Negative and you will receive the IFR approach clearance.
There is no such thing on the 744. So, telling you how it's done really won't make any difference. Again, comparing FS to the real world is pretty meaningless in the "tech" forum. Especially, when we're talking about non-existent features.
Fly fast, live slow
Users browsing this forum: mpgunner, SuperSeb and 1 guest
