UAL Bagsmasher
CRJ-200 Technical Help
Mon Jan 16, 2006 6:17 am
Here's a scenario for all you CRJ mechs. See if you can figure out what's wrong.
Aircraft in question takes a dump upon start attempt of #2 engine. Crew write-up was as follows: During #2 engine start, received no N2 rotation, no oil pressure, no lightoff.
MX changed the start valve and it checked good, but did not fix original write-ups. Cannon plugs were cleaned for the oil pressure transducer as well as all the harness connectors(blue, red, and yellow). No fix. #2 engine oil sump chip detector light was illuminated. Some debris noted on chip detector. Debris was cleaned and light reset.
I took the turnover from there. Upon examining the #2 engine, I found the ATS leaking oil, and the oil inside the ATS looking like molasses. It was blueish in color and looked like it was severely contaminated. I changed the ATS after conferring with MC. Ops check good (dry motoring), but original problems still present. N2 reading on EICAS stays at zero, and no oil pressure while motoring. N1 was normal, ITT was normal (ambient temp), and rotation was physically observed out at the engine. After two dry motorings, the chip detector was lit again. Some small flakes were found this time. I had a hunch something was eating itself in the AGB at this point.
As for the no lightoff problem, I did some digging in the MDC. I found the #2 engine fuel SOV failed several times in the last few weeks. Sure enough, I found the SOV was failed closed, even though EICAS showed it functioning normally. This explains the no lightoff which occured with the crew, as the engine wasn't getting any fuel. They are in the process of changing out the SOV actuator as we speak (not fun). However, the lack of oil pressure and N2 still remain at the present time. G.E. is not sure what's going on. We are baffled as the three writeups appear to have little in common with each other, except that they all involve #2 engine. We were leaning toward changing the N2 alternator and the oil pressure transducer, but we ran out of time. The aircraft is still AOG. Has anyone ever seen these symptoms on a CF34-3B1? Beside the DCUs, what is common to oil pressure and N2? The aircraft has been dead for 3 days now at an outstation. Thanks!
[Edited 2006-01-15 22:22:20]
ilikeyyc
RE: CRJ-200 Technical Help
Mon Jan 16, 2006 8:24 am
As a new crj mech (and I do C checks, not line mx), I don't know very much, but let me take a stab in the dark:
Something has broken on the N2 shaft that physically prevents N2 from turning. It is causing wear on the N1 shaft therefore producing metal. A larger chunk of metal has worked its way through the oil return line and is either clogging the line, or physically preventing the oil pump from turning.
again, shot in the dark. let me know what you find out!
Quoting UAL Bagsmasher (Thread starter):
at an outstation
I assume there is no engine change equipment at this outstation then!
Fighting Absurdity with Absurdity!
charliecossie
Mon Jan 16, 2006 8:51 am
'Ang on a minute.....
The MCD was contaminated. It was cleaned. Two dry motors later, it's contaminated again.
There's a clue, Watson.
Unless these chip detector lights come on every 5 minutes and the debris wasn't actually metal.....
Tg 747-300
Mon Jan 16, 2006 10:00 am
Sorry, I'm not helping you out with a possible solution, but was wondering if somebody would be kind enough to explain a few abbreviations.
MCD = ?
ATS = ?
AGB = ?
DCU = Digital Control Unit ?
SOV = Shut Off Valve ?
tg 747-300
intentionally left blank
Jetlagged
Mon Jan 16, 2006 10:25 am
Quoting Ilikeyyc (Reply 1):
If N2 is actually not turning, N1 will not turn either (it will only turn due to airflow induced by N2 rotation). Sounds more like an accessory drive failure which should be driving the oil pump and the N2 rpm transducer. If it also drives the fuel control unit pump that might explain the lack of a light off.
ilikeyyc
Mon Jan 16, 2006 10:51 am
Quoting Jetlagged (Reply 4):
I hate to show that I know so little, but I am new to the airplane, and 90% of my work is on the airframe. But I am learning something new all of the time. Anyway, 'Bagsmasher said that the fuel SOV failed in the off position, so that is what caused the failed light off.
So that leaves me with the questions of where is the N2 rpm transducer? If the MCD contains metal after a cleaning and 2 dry motors, does that mean that the oil is flowing? If so then the oil pump is working?
Mon Jan 16, 2006 4:27 pm
Quoting Tg 747-300 (Reply 3):
MCD = ?
ATS = ?
AGB = ?
MCD = Magnetic Chip Detector.
ATS = Air Turbine Starter.
AGB = Accessory Gear Box.
regds
MEL
UAL Bagsmasher
Mon Jan 16, 2006 9:13 pm
The N2 alternator on the #2 engine is mounted on the lower inboard side of the accessory gearbox. You can gain access by removing one of the green accoustical liner panels in the bypass duct. It is attached to the blue harness back there. I am going to make a call and see if they have found anything yet. I'm curious now.  Wink
Tg 747-300
Tue Jan 17, 2006 7:11 am
Sorry for my limited knowledge, but I'm trying to get a better picture of how a jet egnine is working/constructed.
Lets see if I get this right. N1 is the speed of the LP compressor while
N2 is HP speed. Both are located on different drive shafts. N1 is driven by LP turbine (rearmost turbine spool) while N2 is driven by HP rurbine (first turbine spool).
So what you are saying is that if the HP turbine isn't turning, the LP turbine will be stuck too.
Wouldn't there still be some kind of airflow through the HP section creating atleast some LP movment and thus N1 readings.
Also isn't the AGB connected through some kind of drive shaft that will break if the AGB messes up in order to prevent damage to the engine turbine shafts.
Hope I didn't confuse you or myself to much in this post
BTW: Thanks Hawk21M for the explanations.
Is the MDC some kind of a digitla engine logbook?
tg 747-300
Jetlagged
Tue Jan 17, 2006 12:12 pm
Quoting Tg 747-300 (Reply 8):
Yes, if for some reason the HP spool is seized, the starter motor cannot turn it, so there is no airflow induced through the engine, so the LP spool will not turn either.
The LP spool isn't stuck. It can turn independently due to windmilling for example. However the air turbine starter only acts on the HP spool. It has no direct effect on the LP spool.
Perhaps you were imagining starter air being blown onto the HP and LP turbines directly?
The fact that the LP spool was seen to turn normally shows that there was normal N2 rpm during the dry crank, even though there was no N2 indication on EICAS.
Tg 747-300
Tue Jan 17, 2006 1:02 pm
Thanks, I think i forgot that we are talking about the start sequence here. I for some reason was assuming the airflow from combustion etc. to be present, and thus found it a bit strange what you were saying about stuck turbines etc.
Also Its very easy to forget that bleed air is acting on the start engine, and not on the "main engine" it self.
tg 747-300
UAL Bagsmasher
Thu Jan 19, 2006 4:57 am
Well, the verdict is in. The next crew of mech's who were sent to the outstation were instructed to drain the engine oil. After draining it into a clean container, a layer of powdery metal was seen coating the oil's surface. A new engine is currently enroute and should be changed sometime tomarrow. Apparently the AGB ate itself resulting in the loss of N2 indication and oil pressure. Thanks for the responses!
ballpeeen
Thu Jan 19, 2006 7:49 am
I am soooo glad I turned down that road trip...
Did they ever get that thing back in the hangar?
Thu Jan 19, 2006 12:12 pm
Quoting UAL Bagsmasher (Reply 11):
Will be awaiting the Report from the Engine overhaul shop.This is Interesting.
regds
MEL
UAL Bagsmasher
Sat Jan 21, 2006 6:18 pm
Ballpeeen, yes, I hear they got the hangar back a couple days later. FYI, the same aircraft is now dead again in PHL with a nosegear door master caution problem. When it rains it pours I guess.
ballpeeen
Mon Jan 23, 2006 3:49 pm
Did you hear about our little fire here in IAD?
UAL Bagsmasher
Thu Jan 26, 2006 4:10 am
Ballpeeen LOL Yeah...something about the static inverter roasting itself and the associated wiring. Haha, those guys just got back to town yesterday after 2 or 3 days on their road trip. At least someone is making OTSmile
Users browsing this forum: jonboy and 1 guest
