eclipseflight7
Hydraulic Pressure Resonance Suppressor
Wed Jan 18, 2006 1:43 pm
What is it? All I know is that it goes in a 747, somewhere...
Holy sh*ts and burritos.
SFOMB67
RE: Hydraulic Pressure Resonance Suppressor
Wed Jan 18, 2006 2:36 pm
Don't know for sure, but I'd guess it's located on the engine, just downstream of the eng hyd pump. Removes pulsation generated by the pump.
joness0154
Wed Jan 18, 2006 4:04 pm
Are you talking about the accumulator?
I don't have an attitude problem. You have a perception problem
troubleshooter
Wed Jan 18, 2006 4:20 pm
This job sucks!!! I love this job!!!
SFOMB67
Wed Jan 18, 2006 6:46 pm
Quoting Joness0154 (Reply 2):
No. I remember an item attached to the pressure line off the EDP on 762 engines, with JT9-7R4's. About 5" dia x 4" that I believe was supposed to dampen surges from the pump. Don't remember it on the 763's though, but it's been a few years. This sounds like a similar item.
PhilSquares
Wed Jan 18, 2006 8:00 pm
Quoting Sfomb67 (Reply 4):
Sounds like the description of a hydraulic accumulator.
Fly fast, live slow
Wed Jan 18, 2006 8:17 pm
I think you are talking about the Hydraulic Damper assy mounted on Some EDPs of Abex version mounted on the Pump.
regds
MEL
charliecossie
Wed Jan 18, 2006 11:14 pm
Known as a "ripple damper".
Additional to the accumulator.
Doesn't have to be mounted at the pump.
Dougloid
Thu Jan 19, 2006 12:43 am
Quoting Charliecossie (Reply 7):
Or a "snubber". Ever have a water hammer in your residential supply? Same thing in hydraulic systems unless you install a snubber. An accumulator which is permanently connected does the same thing but there are systems that don't utilize an accumulator.
Okie
Thu Jan 19, 2006 2:08 am
Pulsation Damper would be the correct term. Generally used in high pressure pump applications to decrease vibrations induced into the system, hydraulic in this case, generated by the pump as each piston/vane/gearoter discharges into the high pressure side of the system and causes vibration.
While somewhat similar to an accumulator the devices are pretty much "tuned" for lack of a better word for the frequency/quantity of fluid discharged by each piston/vane/gearoter displacement and pressure of the system. They do not store pressurized fluid like an accumulator for later or short term demands that exceed the pump capacity.
A friend of mines dad was in that business for years and built Pulsation Dampers for all types of hydraulic and pump applications from small 3 gpm hydraulic pumps that would fit in the palm of your hand to some mongo units used in oil field pumps for offshore production that were 36" in diameter and 10 feet long.
Okie
Thu Jan 19, 2006 2:40 am
One type.
regds
MEL
SFOMB67
Thu Jan 19, 2006 4:33 am
So I take it that this pulsation damper is the same thing as a pressure resonance suppressor ?
Okie
Thu Jan 19, 2006 5:27 am
Quoting Sfomb67 (Reply 11):
I would say close enough Sfomb67
I am not familiar with aircraft pump speeds and designs but a typical industrial application using a standard NEMA 1750 rpm motor and a 9 piston pump you are looking at 15,750 pulses/min or 262.5 pulses/sec. for frequency. Pressure, frequency, line size and volume of piston/vane displacement is calculated for a proper fit of a pulsation damper. Most designs I have seen are mounted directly to the pump or within a very short distance of the pump. The two most popular designs I have seen were "inline" similar to what Troubleshooter linked or a "right angle" design that mount directly to the pump discharge. The design that HAWK21M has a picture of I have only seen in "system" pulsation damping where you are dampening very low frequency applications, opening and closing of valves in the hydraulic system although they would probably work to some degree for pump dampening.
Okie
eclipseflight7
Thu Jan 19, 2006 6:58 am
Freaking amazing what you guys know.
Thanks.
Users browsing this forum: CosmicCruiser, rufete and 12 guests
