United787
What Are These Called?
Sat Jan 21, 2006 8:52 am
What is the red "tape" for? and what do you call those things that the red tape is attached to? and what are those things for? I noticed that Airbus planes seem to have more of them.
Photo © Kazim Alikhan - t.dot photography
corey07850
RE: What Are These Called?
Sat Jan 21, 2006 9:14 am
Not sure what teh tape is for, but the "things" are called flap fairings (also called "canoe" fairings)... They essentially make the equipment that moves the flaps more aerodynamic.
SlamClick
Sat Jan 21, 2006 9:16 am
The tape is on the flap track or flap actuator fairings. Often called "canoe fairings" because they form a body under and aft of the wing that resembles an aluminum canoe.
What the tape is for?
Don't know. Maybe the FAA is onboard. Always seems to result in a lot of red tape!
Someone from maintenance will show up with the answer for that.
dl757md
Sat Jan 21, 2006 9:33 am
The red tape is most likely high visibility marking to assist ground crew who are operating equipment around the aircraft in avoiding contacting and damaging the fairings which are lower than the rest of the wing.
DL757Md
Goldenshield
Sat Jan 21, 2006 10:29 am
Quoting Dl757md (Reply 3):
The closest thing that could get near touching it are catering trucks, and the fueler. Belt loaders usually don't go that high up on the fuselage.
nonfirm
Sat Jan 21, 2006 10:35 am
Quoting Goldenshield (Reply 4):
but the do sometimes pass along the back of the flaps with the baggage carts
Goldenshield
Sat Jan 21, 2006 1:14 pm
Quoting Nonfirm (Reply 5):
They aren't an issue with the A320. The carts can go right under the wing outboard of the engine. Also, belt loaders don't tow baggage carts, as that's the tug's job. The belt loader is to be kept at it's lowest position until the driver positions it at the cargo door.
Now, the 737, and MD-80, yeah, that would be of concern.
SFOMB67
Sat Jan 21, 2006 1:32 pm
It appears it's a reflective tape, to seen at nite, but usually the flaps are retracted at the terminal area, so it wouldn't be too visible. What airline is this?
Sat Jan 21, 2006 2:18 pm
Flap track Fairings.They give an Aerodynamic covering to the TE Flap mechanism on the Wing.
The Tape is a reflective tape that helps being noticed when light falls on it to avoid impact.
regds
MEL
mandala499
Sat Jan 21, 2006 6:30 pm
For the deicing guys maybe ?
Mandala499
nonfirm
Sat Jan 21, 2006 7:22 pm
Quoting Goldenshield (Reply 6):
sorry there i meant to say the ground crew
Sat Jan 21, 2006 11:55 pm
Quoting Sfomb67 (Reply 7):
Normally the Trailing Edge cone area is covered red.
regds
MEL
don81603
Sun Jan 22, 2006 1:05 am
Quoting SlamClick (Reply 2):
 groans
Eagles may soar, but weasels don't get sucked into jet engines.
Okie
Sun Jan 22, 2006 1:48 am
The FAA does not mind cutting red tape as long as it is lengthwise.
Okie
Fly2HMO
Sun Jan 22, 2006 3:41 am
It's a more affordable version of duct tape  Wink
grandtheftaero
Sun Jan 22, 2006 4:35 am
An interesting fact about flap track fairings is that in addition to reducing profile drag (as would be expected) they also reduce transonic wave drag by brining the area distribution of the aircraft closer to ideal.
Source: http://www.aerospaceweb.org/question/aerodynamics/q0240.shtml
--Shane
320tech
Sun Jan 22, 2006 4:47 am
The tape is reflective. It's intended to mark the flap fairings at night, so that pallet loaders don't hit the fairings. Belt loaders aren't as much of a concern, since the wings are relatively high. Does it happen anyway? Of course.
The bowser (fuelling truck) doesn't go behind the wing, so it's not for them. De-icers, I'm not sure where they park when doing A320's.
The primary function of the design engineer is to make things difficult for the manufacturer and impossible for the AME.
ReidYYZ
Sun Jan 22, 2006 4:53 am
Thier called vortex genera... sorry, right answer for the wrong "what's this?" question.
Tristarsteve
Sun Jan 22, 2006 6:15 am
The red tape is an indication of the flap extension. The pilot can look out the pax window and see where the flaps are. This works because the flaps move mainly rearwards on a screwjack, while the canoe flap fairing is pivoted at the front and moves down. It must be there if there is a flap indication failure in the flight deck. I remember it long ago on TriStars, but have not seen it lately.
As a matter of interest if you look out the window of a TriStar (if you are lucky enough to be flying in one) you will see a small pin come out of the upper wing surface when the undercarriage is down. It is a manual indication. They don't have them nowadays, rely on duplicated sensors instaed.
320tech
Sun Jan 22, 2006 6:34 am
Is the pilot standing on the wingtip when he does this? Because the tape goes all the way around. It's to prevent the fairings from being struck by vehicles on the ground.
Sun Jan 22, 2006 6:39 am
Quoting Tristarsteve (Reply 18):
MD-11s have an equivalent little pin.
ReidYYZ
Sun Jan 22, 2006 8:42 am
What you are talking about is can be seen here:
Photo © Norman Walesch
The mark on the flap track support box is yellow marked "flap" and the # gradients are marked on the flap surface itself (not visible until flap deployed)
And
Quoting 320tech (Reply 16):
pallet loaders
as seen here:
Photo © Thomas millard
dl757md
Sun Jan 22, 2006 11:49 am
Fuelers and catering trucks have been known to impact flap track fairings.
This may be true with the flaps retracted, but it IS an issue when mtc has the flaps extended for whatever reason and ground personnel who are used to having the clearance you stated, drive under the wing only to experience a very rude awakening. I've seen it happen on the 757 which has a higher wing than the A320. The stripes ARE there for as a visibility aid for the ground crews.
DL757Md
MX757
Sun Jan 22, 2006 3:00 pm
Quoting Okie (Reply 13):
Quoting FLY2HMO (Reply 14):
 rotfl   rotfl   rotfl   rotfl   rotfl   rotfl   rotfl   rotfl   rotfl
Is it broke...? Yeah I'll fix it.
Mon Jan 23, 2006 1:35 am
Quoting Dl757md (Reply 22):
The Door Frame is a particular target of Catering trucks.
regds
MEL
United787
Mon Jan 23, 2006 8:18 am
Thank you all for your answers to my questions.
planefreakaa
Wed Jan 25, 2006 12:35 am
The red tape is there so that the ground crews can see the canoe fairings when the flaps are lowered
they are sometimes lowered for maintenance reasons, and you wouldn't believe how complacent some people get in their jobs, and would just run into them assuming that they were up.
AC320tech
Mon Jul 31, 2006 7:52 am
Sorry for bringing up a dead thread.
You have to look at on a Airline to Airline basis. AC uses Containerized cargo on the 320 and 321 with the LD-3-45's. AC was going to use it on the 319, but AC Cargo did not want the containerized system. Since AC uses containers, it need belt loaders to do this.
In the early days of the 320's in AC's fleet many employees driving the loader would accidentally run into the canoe farrings and bust them right off causing delays. In turn, AC put red tape around all of them. You will not see this tape on the Left side of the aircraft, only on the right. You will also not find them on the A321 or A319 in AC's fleet.
KLM has orange blurbs on the end of there farrings on the 747-400M's.
474218
Mon Jul 31, 2006 8:16 am
You are correct. The red tape is a warning for the cargo loaders. You will only notice it on the Right Hand flap fairings, because that is where the cargo door is. See the attached photo:
Photo © Airwim
Mon Jul 31, 2006 10:27 pm
Quoting AC320tech (Reply 27):
Interesting Point.Makes sense.
Thanks.
regds
MEL
Users browsing this forum: 7673mech, Baidu [Spider], XAM2175 and 2 guests
