LMP737
Carbon Brakes On The 737NG
Tue Jan 31, 2006 1:26 am
Starting in 2008 Boeing is going to offer carbon brakes on the 737NG. The brakes will be supplied Goodrich and Messier-Bugatti. Total weight savings is going to be around 700lbs.
As someone who has changed 737NG brakes all I can say is, why didn't they do this when they launched the program? After all, Boeing spent a lot of money updating everything else.
http://www.boeing.com/news/releases/2006/q1/060130a_nr.html
2H4
RE: Carbon Brakes On The 737NG
Tue Jan 31, 2006 1:36 am
Quoting LMP737 (Thread starter):
Perhaps the brakes weren't ready from a technical or certification standpoint.
2H4
Intentionally Left Blank
jush
Tue Jan 31, 2006 1:38 am
Sorry just to inform you it's already being discussed here
Boeing To Offer Carbon Brakes On B737NG (by WINGS Jan 30 2006 in Civil Aviation)
There is one problem with airbus. Though their products are engineering marvels they lack passion, completely.
LMP737
Tue Jan 31, 2006 3:16 am
Quoting Jush (Reply 2):
The link does not work.
MrChips
Tue Jan 31, 2006 4:48 am
Doesn't matter anyways...this is Tech/Ops, where the discussion will take an entirely different course to Civil Aviation. So even though it might be interesting to get the opinions of the unwashed masses in Civ Av, chances are much better that you will get REAL answers here.
Time...to un-pimp...ze auto!
MX757
Tue Jan 31, 2006 8:17 pm
700 pounds in weight savings and they last twice as long as the current steel brakes. Now that's impressive!  Wink
Quoting MrChips (Reply 4):
MR.Chips,
Welcome to my RU list. Well said!  thumbsup
I always wonder why the aviation guru "JerkAmerica" never posts in the Tech/OPs forum?  stirthepot
Is it broke...? Yeah I'll fix it.
jush
Tue Jan 31, 2006 8:41 pm
Alright then, I just thought the first thread wins the race as it already had answers. But then again it's A.net there is no sense here. And moving another thread isn't possible, heh.
Regds
jush
rsbj
Tue Jan 31, 2006 10:38 pm
I'm wondering how 700 pounds can be saved when the brakes don't weigh that much in the first place. I've seen maintenance change them during one of my walk-around's, and two guys easily pulled them off the spindle and place them on a cart. Perhaps there are much more extensive weight savings elsewhere.
Thoughts?
I fly really fast and take a lot of chances.
Tue Jan 31, 2006 11:04 pm
Finally.It was well overdue on the B737.
350kgs is a lot of Saving considering the Number of B737NGs flying & the Hrs flown.
regds
MEL
Tue Jan 31, 2006 11:25 pm
Dont know, think they have been on the 320 for over a decade. Made by the same people.
Seems over the top to me, the number seems overstated. 80 kg a wheel is a lot of mass, carbon brakes still require hydraulics and discs to work.
2H4
Wed Feb 01, 2006 12:13 am
Quoting Zeke (Reply 9):
Yeah, but if I'm not mistaken, the discs are the parts being converted to carbon. And aren't these the heaviest components in the brake assemblies?
2H4
futureualpilot
Wed Feb 01, 2006 12:15 am
Quoting Rsbj (Reply 7):
Perhaps the new brakes allow for the removal of components that formerly were needed for the "old" style brakes? Just my .02
Life is better when you surf.
LMP737
I've heard "commonality" with the classic 737 used as a reason. Although I'm not sure how common the brakes on later model classic are compared with NG brakes since I have never worked on classics. Anyway guess what I'm getting at is the Boeing put all that money into changing the 737 they should have just taken that extra step and put carbon brakes on it.
It's actually pretty accurate. I've worked on both the MD-80 and MD-90. The MD-80 uses steel brakes while the MD-90 uses carbon brakes. On the 90 two guys can easily lift the brake by hand onto the gear. On the 80 unless you want your spine to look like a question mark you had better use a cheery picker.
LMP737
Wed Feb 01, 2006 12:21 am
Thoughts?
It can be done. However if you want to avoid injury using "mechanical aids" is the best route. See my above post for further info.
Okie
Wed Feb 01, 2006 2:58 am
700 lbs is a significant amount of weight to be hauling around day in and day out.
I would suspect the major issue about putting carbon brakes on the 737 has been cost. The price of using carbon brakes has come down as the technology has evolved, add in less fuel in a high fuel cost environment, less Mx, then the technology becomes more attractive.
While not exactly related to aircraft I can tell you that in the last 15 years the cost of using carbon brakes in racing applications has come down more than 50% as the technology has evolved. Parts that cost $3,000 each 15 years ago are now in the $1250 range.
Okie
LMP737
Wed Feb 01, 2006 9:03 am
Okie:
I would imagine keeping costs down during the R&D of the 737NG was an issue. Which is kind of odd though when you look at the money Boeing spent on the program. Nickles and dimes I guess.
rolfen
Wed Feb 01, 2006 9:49 am
Thoughts?
From what I know carbon has a much higer resistance to heat and does not loose it's braking properties at high temperatures. This might mean that fewer brake discs will be needed on the plane, hence the big weight saving.
rolf
Wed Feb 01, 2006 2:03 pm
Quoting Rolfen (Reply 16):
Added by the longer life.
regds
MEL
jonathan-l
Wed Feb 01, 2006 7:16 pm
When the A300B4 switched from steel to carbon brakes, weight savings ranged from 500 to 600kg per aircraft!
LONGisland89
Fri Feb 17, 2006 11:57 am
Aren't the current brakes on the 737 series made of magnesium or is it some other kind of alloy?
avioniker
Sat Feb 18, 2006 1:44 am
Quoting LONGisland89 (Reply 19):
The current brakes are steel.
Magnesium would make for some very impressive pyrotechnics when the plane is approaching the gate.
One other big advantage to using carbon (sepcarb) brakes is that they are more effective as they grow hotter.
The certification costs on the NG weighed against the commonality issues were extremely high. Boeing chose to spread them over a number of years allowing them to use other manufacturers' data in the process. They saved millions doing it that way.
 Smile
amtrosie
Sun Feb 19, 2006 3:24 am
Quoting LMP737 (Reply 12):
I have worked all the "classics" and I know there are diferent P/N's for the various series.
As to the weight savings, not only are the carbon disks lighter and with less heat build-up, but with the reduced heating of the brake disks the housings can be re-designed. The stress on them is phoenominal. Almost every brake I have sent for overhaul has a housing problem, cracking or other, almost all related to heat retention.
bravogolf
Sun Feb 19, 2006 5:24 am
I was still confused if the disks themselves are carbon. I went to the Goodrich site. They had a picture that looked like carbon disks but no definate explination. I then went to the http://www.messier-bugatti.com site. Moving around this site there is much information on their carbon brakes. Yes the rotors are carbon and the regitered trademark is Sepcarb. ALSO the site has a link to information that the 787 will have electric brakes. Both the rotors and stators will be made of carbon and activated by an electric motor.
[Edited 2006-02-18 21:26:28]
[Edited 2006-02-18 21:28:56]
phollingsworth
Sun Feb 19, 2006 9:25 am
I seem to remember the reason that the 737NGs have steel brakes is because a certain launch customer required them. There are a number of proposed improvements that were not made at the request of this customer. It is kind of amazing what a launch customer can force a manufacturer to do. Take for instance the 777 style flight deck and cabin on the 767-400
Sun Feb 19, 2006 12:53 pm
Quoting Phollingsworth (Reply 23):
This was long overdue.Any link to a sketch of this particular B737NG Brake.
regds
MEL
troubleshooter
Sun Feb 19, 2006 3:08 pm
Quoting HAWK21M (Reply 24):
Here it is: http://www.goodrich.com/Feature/SingleStory/0,1285,78,00.html
This job sucks!!! I love this job!!!
Users browsing this forum: aemoreira1981 and 24 guests
