jamesbuk
Seat Pitch?
Fri Feb 03, 2006 6:03 am
HI guys and gals
I hope this is the right forum to post in but anyway, i often hear people on here saying "yeh there real comfortable they have 38" seat pitch" so what is it? where do you measure the distance? etc
so any ideas guys and gals?
Many thanks
Rgds --James--
You cant have your cake and eat it... What the hells the point in having it then!!!
FredT
RE: Seat Pitch?
Fri Feb 03, 2006 6:08 am
The distance between the same point on two seats. It is common to use one of the seat track attachment points as the reference point for the chairs. If one seat has the front left seat track attachment point at station 500 (assuming stations measured in inches) and the seat behind has the front left seat track attachment point at station 531, you have a seat pitch of 31".
Fred
L-188
RE: Seat Pitch?
Fri Feb 03, 2006 7:14 am
Quoting Jamesbuk (Thread starter):
Fred beat me to it.
The other way I gotten the spacing correct when doing re-configs on Metros, would be to count out the number of "spaces" in the coin-track the seats mount to, and then make sure I had the same number of spaces between seats.
RE: Seat Pitch?
Fri Feb 03, 2006 5:15 pm
Over here We calculate from the Front seat mount position of the forward seat to the Front mount position of the rear seat.
regds
MEL
Matt72033
RE: Seat Pitch?
Fri Feb 03, 2006 5:55 pm
Quoting FredT (Reply 1):
so that means that seat pitch isnt an accurate measure of legroom.....you could have a seat pitch of 31" and 38" and still have the same legroom because the overall seat size of the 38" pitch is bigger.....if you see what i mean!.........the seats can be mounted 38" from each other, but if the seats bigger, it'll be closer to the one in front!
EMBQA
RE: Seat Pitch?
Fri Feb 03, 2006 6:25 pm
The Weight and Balance Manuals traditionally show you to measure from the front face of the front seat leg to the front face of the seat leg of the next seat leg.
Whiskeyflyer
RE: Seat Pitch?
Fri Feb 03, 2006 8:06 pm
on a standard seat rail there are holes, to mount the seat bases. The distance between the mid point of each hole is one inch (so if flying a carrier that has not out the seat rail track covers in place properly, you can count holes, if your are so inclined or bored)
FredT
RE: Seat Pitch?
Sat Feb 04, 2006 3:03 am
Quoting Matt72033 (Reply 4):
Correct, but as it is the distance between the the front of your seat back to the seat back in front of you that matters, when it comes to the crucial leg room, it is really only the thickness of the seat backs which has any effect. That does not tend to vary much.
There was that Italian (?) seat manufacturer which tried to launch mesh style seats though. That would have added an inch or two of leg room for the same pitch! Nice IMO, I'm 6' and will never fly long-haul (or anywhere at all, preferably) in an aircraft configured to 29" pitch.
Fred
jamesbuk
RE: Seat Pitch?
Sat Feb 04, 2006 3:18 am
HI guys and gals
Thanks so much for clearing that one up for me but some of you are saying its seat back to seat back and some are saying its the runners so does it matter or is there a definite correct answer?
Rgds --James--
Matt72033
RE: Seat Pitch?
Sat Feb 04, 2006 3:37 am
Quoting FredT (Reply 7):
knowhow you feel there! i'm 6ft4 and 38" pitch is just about comfertable! lol i flew BA economy from LHR to DFW not so long ago! that was hell!
FredT
RE: Seat Pitch?
Sat Feb 04, 2006 4:16 am
Quoting Jamesbuk (Reply 8):
If you read again, I think you will find that "some people" include me in both cases, and that there is actually no conflict at all between the statements.  Smile
tu114
RE: Seat Pitch?
Sat Feb 04, 2006 4:17 am
It's irrelevant. Assuming the two seats are identical then the distance between the same point on each seat will be the same.
Jetlagged
RE: Seat Pitch?
Sat Feb 04, 2006 4:38 am
On charter airlines you'll find you have a much thinner, harder seat so they give you just enough legroom on minimal pitch. Also the seats are narrower, so you might get 2-4-2 seating on a 767. One reason I would never fly long haul on an inclusive tour airline. I'd prefer to pay more and fly scheduled. I flew from the UK to Turkey on holiday in an Excel 767 last year, four hours jammed into a tiny, hard seat. Awful. And the same to look forward to on the way back.  boxedin
Just as important is how high the bottom of the seat in front of you is, and whether there is any IFE equipment there. That affects whether you can stretch your legs out. If there is a footrest fitted to the seat in front it will actually make this worse. Also putting anything in the seat pocket will limit your legroom.
jamesbuk
RE: Seat Pitch?
Sat Feb 04, 2006 6:53 am
Quoting Tu114 (Reply 11):
Lol i realised that a while after i had posted and i personally classed my self a plonker.
Quoting FredT (Reply 10):
FredT
I agree with you now that i have gone back and read the posts again and drew a lil diagram to help my inferior brain understand.
Rgds --James--
EMBQA
RE: Seat Pitch?
Sat Feb 04, 2006 6:27 pm
All I can tell you is what is in the manuals.. not a guess but fact. Seat leg to seat leg.
RE: Seat Pitch?
Sat Feb 04, 2006 9:15 pm
A partially related question.Is the Dimensions of Seats build for a particular class of a particular model Aircraft standard or can it vary.
What Im trying to say Does the Pitch being similiar but the Seat base vary.
regds
MEL
musang
RE: Seat Pitch?
Sat May 09, 2015 3:33 pm
Quoting Whiskeyflyer (Reply 6):
About the "coin track" into which the seats fit -
am I correct in thinking (1) the holes are universally at 1 inch spacing, as an industry standard? And (2) The seat therefore has to positioned at a multiple of 1 inch spacing variation, i.e. fractions of an inch are not possible?
Would this mean that in for example a 30 row cabin with 31 inch pitch, all the rows would have to be placed one inch closer in order to create enough space to insert an extra row, and they'd then all be 30 inch pitch?
I agree with FredT, base of spine position to ahead of the knee is a more helpful and relevant measure of seat space.
Regards - musang
Cipango
RE: Seat Pitch?
Sun May 10, 2015 12:25 am
Quoting musang (Reply 16):
Regards - musang
Talk about resurrecting a very old thread!
Let's fly! Unless it's on a CRJ 200, then I'll stay down here.
Viscount724
RE: Seat Pitch?
Sun May 10, 2015 1:27 am
Quoting Cipango (Reply 17):
I often wonder how people even find a 7-year-old thread like this to resurrect it.
In any case, as already mentioned, seat pitch and legroom are not the same thing. You can reduce seat pitch and increse legroom if the new seats have thinner seat backs, which is very common these days.
KLM replaced the old bulky seats on their Fokker 70s a year or two ago with new lightweight seats with slightly less pitch (except in the forward few rows used for their European business class product where I think the pitch increased slightly). Even the rows with the reduced pitch have noticeably more legroom than with the old seats. The difference is quite surprising. The old seats were more comfortable but your knees were almost jammed into the seatback in front which isn't the case with the new seats where there's plenty of room.
rwessel
RE: Seat Pitch?
Sun May 10, 2015 5:44 am
That's still an interesting question. The seat track is pretty fixed (and you'd be hard pressed to make the standard holes closer together without running out of material, and replacing it would probably be a pretty big undertaking, certification-wise), but the seat is usually attached to that rail with a clip of sorts. Other (non-aircraft) applications with similar systems often have "offset" sized clips that allow you to mount something at fractional positions, or simply have several possible attachment points on the connecting piece (in this case this would be on the seat).
If it's possible on aircraft, I have no idea.
larshjort
RE: Seat Pitch?
Sun May 10, 2015 7:22 am
The seats a have worked with can only sit in one position, so every change has to be in 1 inch increments.
I have some old Lufthansa business seats at home. They are installed by in serting the legs in the seat rail, the seat is then moved forward half a hole and then is locked in place by a bracket on the aft legs. To move/remove the seats is just 2 small screws.
This is how all aircraft seats I have worked with are installed. It is quick to install and remove the seats but you can only do it at 1 inch increments
http://www.ancra.com/aircraft/images/header_fittings.jpg
/Lars
139, 306, 319, 320, 321, 332, 34A, AN2, AT4, AT5, AT7, 733, 735, 73G, 738, 739, 146, AR1, BH2, CN1, CR2, DH1, DH3, DH4,
musang
RE: Seat Pitch?
Sun May 10, 2015 9:14 am
Quoting Viscount724 (Reply 18):
Search function! If I had started a new thread, someone would have said "already covered - try the search function….".
Anyway, thanks for replies, got exactly the info I wanted.
Regards - musang
Users browsing this forum: Okcflyer, sdf880 and 2 guests
