CM767
Differences Between 737-700 And 737-800 Wings
Fri Feb 03, 2006 7:00 am
With the Launch of the 737-700ER I began to dig on info on the 737 series and accepted that there are two wings for the NG family, until now I have noticed that in the specifications on the Boeing site all models have the same wingspan.
Could some one please point out what are the differences between the wings of the 700 and 800.
Thanks a lot.
But The Best Thing God Has Created Is A New Day
DfwRevolution
RE: Differences Between 737-700 And 737-800 Wings
Fri Feb 03, 2006 7:09 am
Quoting CM767 (Thread starter):
The differences are not related to wingspan, profile, etc, but to the wing structure.
The 738 has additional reinforcements to strenghten the wing for lifting higher gross weights. The 73G does not need this extra weight, so two relativly common wings are produced. The BBJ and now 737-700ER apply the -800 wing reinforcement on the -700 fuselage.
It's possible we may see an even stronger "third" wing for the 737NG. The wing reinforcements applied to the 737-900ER and 737-MMA could be incorperated to the 738, the so-called "737-800ERX."
Fri Feb 03, 2006 5:15 pm
Quoting DfwRevolution (Reply 1):
Any details on where the Reinforcements were added on the Wing.
regds
MEL
CM767
Fri Feb 03, 2006 9:50 pm
Thanks for the reply DfwRewevolution.
I believe that the ER, even that is not revolutionary since really is just is a BBJ, will serve well airlines that max out the 700 in terms of payload.
Sinlock
Fri Feb 03, 2006 11:43 pm
Quoting HAWK21M (Reply 2):
I'd venture a guess that the "Reinforcement" is done through using thicker gauge metal during the build up of the wing, rather than the use of doublers or extensive use of extra structure. That would give added strength without as much weight or loss of internal volume. Keep in mind this is only a guess.
Poitin
Sun Feb 05, 2006 1:28 am
Isn't the skin thickness more on the -800? I read that somewhere, but no reference.
Quoting Sinlock (Reply 4):
I read somewhere the skins are slightly thicker, but I have no reference for that.
Now so, have ye time fer a pint?
Users browsing this forum: 7673mech, Mr AirNZ, rjsampson, twinotter and 1 guest
