kaddyuk
Cool Things You Can Do With An Aircraft...
Sun Feb 05, 2006 11:29 pm
Well yesterday i was assisting in High Power Assurance and Accelleration checks...
That was SO cool  Wink especially the Accelleration Checks...
30% N1 and then snap the throttles up to Max Thrust and measure the time it takes to spool up... hehe...
Are there any other "Cool" tasks to do on an aircraft?
xjramper
RE: Cool Things You Can Do With An Aircraft...
Sun Feb 05, 2006 11:50 pm
Um...my plane can pratically recover from a spin with no input from either pilot.
I can also go from point a to point b, all while listening to XM radio and looking at the NexRad radar from one screen.  Smile
XJR
Look ma' no hands!
FredT
Mon Feb 06, 2006 12:56 am
Turn the world upside down?
mohamed1
Mon Feb 06, 2006 1:04 am
FLY ..........................................
kaddyuk
Mon Feb 06, 2006 1:28 am
Its more of a "Tasks you enjoy to do at work" for engineers thread lol
VC-10
Mon Feb 06, 2006 1:55 am
Quoting Kaddyuk (Thread starter):
It might be cool by todays standards but by pre-EEC standards it's for wimps.
1. High power run (inc accel chk & Water Injection run) on a BAC One-Eleven,
2. Three-shot plot vibration t/shooting on a DC-10
3. Any Hi-pwr run on a JT9 (waiting for it to surge), breather margin chk on a JT9, holding at TO for 5 mins.
4. Trim run on a JT3D
5. High power run on a VC10
A/c train
Mon Feb 06, 2006 3:11 am
RB211 simualted surge test is quite interesting, take the sense line off the TPU and put your finger over it, try it some time!!
A300 full power runs CF6-80C2 are also interesting !
VC-10
Mon Feb 06, 2006 3:24 am
Quoting A/c train (Reply 6):
They bounce around a lot
AvionicMech
Mon Feb 06, 2006 4:36 am
How often do you have to do this check? We have to do it after every 'c' check I think. Well that is on the RB-211's on our 757's. It is also quite good fun when a new engine is fitted on the wing and run for the first time and still has some inhibiting fluid left in the fuel system and spits nice big flames out the back.  Big grin
fr8mech
Mon Feb 06, 2006 7:12 am
Quoting VC-10 (Reply 5):
I remember having all 4 at TO power because our engineering folks wanted some data on temperatures in the leading edge. About 200,000 lbs of fuel and 4 JT9's at max for 5 minutes. Sweating every second after bleed shift.
Ever do an EVC trim with all the junk hooked up? Especially when you're trying to figure out why the beast keeps stalling?
jeffry747
Mon Feb 06, 2006 7:35 am
Ever wonder what a hurricane feels like? I once drove a tug behind a 747 running at idle. Aircraft somehow did not have its beacon lights on and the tug's interior was loud enough to drown out the sound of the plane, so I did not know the aircraft was running until the thrust was buffeting the tug. Dangerous, but exciting!
C'mon Big B, FLY!
VC-10
Mon Feb 06, 2006 8:25 am
Quoting Fr8Mech (Reply 9):
Yep, even done an EVBC check where you trim the 3.0 bleed as well. It wasn't unknown to hook up all the gear, go for the run & have one of the actuators fail. Another goody (not me) was to select reverse with the mast on!
On one occasion we got the run area tried to trim and nothing happened. The lead fron the trim gear in the cockpit to the engine had broken free where it snaked out of door 3 down the pylon to the engine and had been hanging in the exhaust. Of course it burned through.
bri2k1
Mon Feb 06, 2006 9:27 am
Quoting XjRaMpEr (Reply 1):
So can mine, and it's a C172.
I think the coolest thing any pilot can do with any plane is to make an undetectable transition from flight to rolling out on the runway during a strong, gusting crosswind.
Position and hold
DeltaGuy
Mon Feb 06, 2006 1:53 pm
Let's see...going to go put chalks in when a 767 engine has just shut down, and trying to time how many seconds from shutdown you can stand the blast..I got to like 4-5 seconds after fuel was shutoff to where I could do it..kinda stupid though  conehead
Only other fun I ever had when working on the ramp was shutting down APU's and stuff, and just messing around with the FMS, test switches, and such before I did it...they told me to shut the jet down, but not what to do before it  Wink
DeltaGuy
saintsman
Mon Feb 06, 2006 4:48 pm
I watched the engine nacelle move forwards about 6" when full power was applied. Absolutely amazing.
And rather noisy!
Mon Feb 06, 2006 9:24 pm
Quoting Jeffry747 (Reply 10):
There was a Demo Video showing a Tug passing behind a Engine Running B747 with disastarous results.
regds
MEL
Molykote
Mon Feb 06, 2006 10:16 pm
Trim balance procedure for a RR powered 757. This is known in quasi-slang as a "3 shot plot".
The procedure basically involves the installation of known imbalance weights in 3 positions on the fan's hub (behind the spinner cone). The engines are then run up to high power settings with the deliberate imbalance shaking the hell out of the aiplane! The minimum fuel load required to perform this test is quite substantial due to the power available from the 757 engines.
Speedtape - The aspirin of aviation!
wingscrubber
Mon Feb 06, 2006 10:57 pm
Most fun I've had in a plane as a trainee mechanic was probably helping out during a ground-run of a piper aztec, (small game in comparison to the aforementioned aircraft I know) problem was the brakes weren't good enough to stop the aircraft rolling forward when the engines were running at full bore, I was told to put railway sleepers in front of the main gear so the aircraft wouldn't go anywhere...
As for actual flying, doing a stall turn in a bulldog as a cadet or auto-rotate demonstration in a robinson r22, or maybe even being winch-launched in a viking glider, all great fun Big grin
Resident TechOps Troll
VC-10
Tue Feb 07, 2006 12:49 am
Quoting Molykote (Reply 16):
At least on a CF6 you don't have to take the spinner off.
EGGD
Tue Feb 07, 2006 3:42 am
Deicing a PA-28 at 8:30am with temperature in the negative degrees celcius?
goboeing
Tue Feb 07, 2006 4:36 am
Quoting DeltaGuy (Reply 13):
It's chocks!
SkydrolBoy
Tue Feb 07, 2006 12:55 pm
Well its technically not on a real aircraft, but every year we have recurrent training in our simulator. At the end of the session we spend about 15-20mins each taxiing around the airport to practice since we dont get to do it for real very often. The last time I was doing my training I was doing my high speed run down the runway at about 100knots when the sim instructor decided to put another aircraft on the runway infront of me just to make sure I could stop in time. I had full brakes and full reverse and full brakes and barely made it in time. My hands where still shaking for half an hour afterwards.
But my favorite is anytime we get to do trim runs on the 27, when we take all three engines up to full power to check the throttle stagger. Always seems like we are on the verge of breaking loose of the chocks.
ZSOFN
Tue Feb 07, 2006 7:42 pm
Gone up in a Christen Eagle II (as pax) on my stag weekend after a HEAVY night and not chundered everywhere... Big grin
ReidYYZ
Tue Feb 07, 2006 9:17 pm
Quoting SkydrolBoy (Reply 21):
Did that, after a power run in a Tristar. Only got it to 75kts though before the end of the runway came at me.
Wed Feb 08, 2006 12:37 am
I Enjoy Major Maintenance.Especially the Oleo seal changes & Post Mx ground runs.
regds
MEL
LongbowPilot
Wed Feb 08, 2006 3:26 am
AH-64 has a roll rate greater then a F-16
HaveBlue
Wed Feb 08, 2006 5:47 am
Quoting LongbowPilot (Reply 25):
Sounds hard to believe... but if so, I imagine that is just for the first roll right?
Here Here for Severe Clear!
2H4
Wed Feb 08, 2006 6:00 am
How many degrees per second?
2H4
Intentionally Left Blank
LongbowPilot
Wed Feb 08, 2006 6:11 am
One Hundred and twenty seconds trough the entire flight envelope. The F16 cannot match that.
2H4
Wed Feb 08, 2006 6:34 am
Quoting LongbowPilot (Reply 28):
Ha, is that all?
The Extra I've flown does 360/sec.  Wink
2H4
LongbowPilot
Wed Feb 08, 2006 7:01 am
HA, i was comparing it to an F16 though dude... Difference when the aircraft has control surface is 20% the size of the mounted wing or stab. Another thing entirerly when your aircraft has the most responsive fly by wire augmented flight control system. OH, and not to mention what they were designed to do for a job...
2H4
Wed Feb 08, 2006 7:10 am
Quoting LongbowPilot (Reply 30):
Ah, but your wings ARE control surfaces...  Wink
Anyway, I had to give you a hard time, since you fly significantly cooler things than I do.  biggrin
2H4
LongbowPilot
Wed Feb 08, 2006 7:12 am
Quoting 2H4 (Reply 31):
hence the performance. don't hate Big grin
jeffry747
Thu Feb 09, 2006 8:39 pm
Quoting HAWK21M (Reply 15):
Fortunately only the #1 engine was running. If all 4 engines were up and running,
the results would have been like you said;disastrous.
C'mon Big B, FLY!
liedetectors
Wed Feb 22, 2006 12:12 pm
Performance Takeoffs are rather impressive in a Gulfstream. You hold the brakes while you spool up to MTO power. Then let off the brakes. You're in the air rather quickly and taking off like a rocket.
Parabolas in a KC135 are rather fun too.
If it was said by us, then it must be true.
Users browsing this forum: No registered users and 32 guests
