terryb99
Delta's Proposed Outsourcing
Fri Feb 10, 2006 6:33 am
Was reading an older thread, which I can't reply to any longer;
Delta To Hire Out More Of Its Work (by DL787932ER Jan 24 2006 in Civil Aviation)#ID2566972
Was curious if Delta was keeing their engine shop and their landing gear overhaul shop.
Terry
Dalmd88
RE: Delta's Proposed Outsourcing
Sat Feb 11, 2006 5:25 pm
The landing gear shop and all of the engine lines are staying in house at this time. Cuts are being made at outstations and mostly the ATL hangar floor. ATL Hangar is cutting 107 AMTs and another 50 Avionics positions. We are losing 85 lead positions in ATL including shop positions. ATL line is also cutting a bunch of positions, I can't recall the numbers. We do have the option to demote to 180 new Mechanic Helper positions at about a 40% pay cut. Looks like most are taking the furlough. They will then have to hire off the street for the helper positions.
We also have the option of transfering to open slots at our most expensive stations:SFO,LGA,JFK,DCA,BOS, and a few others. Most ATL guys will not move.
[Edited 2006-02-11 09:27:52]
dl757md
Sun Feb 12, 2006 12:46 am
Here are the numbers after voluntary furlough's and retirements
ATG 245 BASE MAINTENANCE UTILITY EMPLOYEE 1 1
ATG 246 ENGINE AVIATION MAINTENANCE TECHNICIAN 1
ATG 247 ENGINE MAINTENANCE INSPECTOR 1
ATG 248 BASE AVIATION MAINTENANCE TECHNICIAN 5
ATG 248 BASE LEAD AVIATION MAINTENANCE TECHNICIAN 1
ATG 271 ENGINE MAINTENANCE UTILITY EMPLOYEE 1
ATG 276 ENGINE MAINTENANCE UTILITY EMPLOYEE 1 1
ATG 281 ENGINE AVIATION MAINTENANCE TECHNICIAN 2
ATG 282 ENGINE AVIATION MAINTENANCE TECHNICIAN 2
ATG 282 ENGINE MAINTENANCE UTILITY EMPLOYEE 1
ATG 287 ENGINE MAINTENANCE UTILITY EMPLOYEE 1
ATG 288 ENGINE AVIATION MAINTENANCE TECHNICIAN 5
ATG 288 ENGINE MAINTENANCE UTILITY EMPLOYEE 1
ATG 289 ENGINE MAINTENANCE UTILITY EMPLOYEE 1
ATG 299 ENGINE AVIATION MAINTENANCE TECHNICIAN 2
ATG 301 ENGINE AVIATION MAINTENANCE TECHNICIAN 2
ATG 311 ENGINE MAINTENANCE UTILITY EMPLOYEE 1 3
ATG 380 BASE AVIATION MAINTENANCE TECHNICIAN 8
ATG 380 BASE LEAD AVIATION MAINTENANCE TECHNICIAN 2
ATG 380 BASE MAINTENANCE UTILITY EMPLOYEE 1
ATG 381 ENGINE AVIATION MAINTENANCE TECHNICIAN 1
ATG 382 BASE AVIATION MAINTENANCE TECHNICIAN 18
ATG 382 BASE LEAD AVIATION MAINTENANCE TECHNICIAN 2
ATG 383 BASE AVIATION MAINTENANCE TECHNICIAN 11
ATG 383 BASE LEAD AVIATION MAINTENANCE TECHNICIAN 2
ATG 390 COMPONENTS AVIATION MAINTENANCE TECHNICIAN 3
ATG 391 COMPONENTS AVIATION MAINTENANCE TECHNICIAN 3
ATG 391 COMPONENTS LEAD AVIATION MAINTENANCE TECHNICIAN 1
ATG 392 ENGINE AVIATION MAINTENANCE TECHNICIAN 1
ATG 392 ENGINE LEAD AVIATION MAINTENANCE TECHNICIAN 1
ATG 401 ENGINE LEAD AVIATION MAINTENANCE TECHNICIAN 1
ATG 401 ENGINE MACHINIST 1
ATG 401 ENGINE MAINTENANCE UTILITY EMPLOYEE 1 3
ATG 401 ENGINE TECHNICIAN HELPER 2
ATG 402 ENGINE MAINTENANCE UTILITY EMPLOYEE 1
ATG 420 BASE AVIATION MAINTENANCE TECHNICIAN 4
ATG 420 BASE LEAD AVIATION MAINTENANCE TECHNICIAN 1
ATG 421 BASE AVIATION MAINTENANCE TECHNICIAN 5
ATG 421 BASE LEAD AVIATION MAINTENANCE TECHNICIAN 1
ATG 426 COMPONENTS TECHNICIAN HELPER 3
ATG 486 POWRPLNT/PRDCTVTY/ENGMTC/TRNG INSTRUCTOR DEVELOPER 15
ATG 589 COMPONENTS AVIONICS TECHNICIAN 18
ATG 589 COMPONENTS SHOP EQUIPMENT TECHNICIAN 1
ATG 999 BRIDGE_BACK AVIATION MAINTENANCE TECHNICIAN 1
ATG CLN BASE LEAD MAINTENANCE UTILITY EMPLOYEE 1 2
ATG HGR BASE AVIATION MAINTENANCE TECHNICIAN 107
ATG HGR BASE AVIONICS TECHNICIAN 41
ATG HGR BASE LEAD AVIATION MAINTENANCE TECHNICIAN 57
ATG HGR BASE LEAD AVIONICS TECHNICIAN 10
ATG INS QUALITY INSPECTOR 43
ATG LNE LINE AVIATION MAINTENANCE TECHNICIAN 76
ATG LNE LINE LEAD AVIATION MAINTENANCE TECHNICIAN 15
ATG MEC COMPONENTS LEAD AVIATION MAINTENANCE TECHNICIAN 1
ATG MEC COMPONENTS LEAD MACHINIST 1
ATG MEC COMPONENTS MACHINIST 2
ATG MEC COMPONENTS MAINTENANCE UTILITY EMPLOYEE 1 2
ATG PNT BASE LEAD AVIATION MAINTENANCE PAINTER 4
BOS 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 1
CVG 250 LINE AVIATION MAINTENANCE TECHNICIAN 57
CVG 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 13
CVG 250 LINE SUPPLY ATTENDANT 4
CVG 999 BRIDGE_BACK LEAD AVIATION MAINTENANCE TECHNICIAN 1
DFW 206 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 1
DFW 206 LINE TECHNICIAN HELPER 4
DFW 250 LINE AVIATION MAINTENANCE TECHNICIAN 28
DFW 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 3
DFW 477 MATERIEL SUPPLY ATTENDANT 1
DFW 587 GSE GROUND MAINTENANCE TECHNICIAN 3
EWR 250 LINE AVIATION MAINTENANCE TECHNICIAN 13
EWR 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 4
EWR 477 MATERIEL SUPPLY ATTENDANT 1
LAX 250 LINE AVIATION MAINTENANCE TECHNICIAN 6
LAX 477 MATERIEL SUPPLY ATTENDANT 2
MCO 587 GSE GROUND MAINTENANCE TECHNICIAN 1
ORD 250 LINE AVIATION MAINTENANCE TECHNICIAN 21
ORD 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 3
ORD 477 MATERIEL LEAD SUPPLY ATTENDANT 1
ORD 587 GSE GROUND MAINTENANCE TECHNICIAN 6
PBI 250 LINE AVIATION MAINTENANCE TECHNICIAN 14
PBI 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 2
PBI 477 MATERIEL LEAD SUPPLY ATTENDANT 1
PDX 250 LINE AVIATION MAINTENANCE TECHNICIAN 16
PDX 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 2
PHL 250 LINE AVIATION MAINTENANCE TECHNICIAN 14
PHL 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 3
PHX 250 LINE AVIATION MAINTENANCE TECHNICIAN 14
PHX 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 3
PHX 477 MATERIEL LEAD SUPPLY ATTENDANT 1
SAN 250 LINE AVIATION MAINTENANCE TECHNICIAN 13
SAN 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 4
SAN 477 MATERIEL LEAD SUPPLY ATTENDANT 1
SEA 587 GSE GROUND MAINTENANCE TECHNICIAN 2
SEA 587 GSE LEAD GROUND MAINTENANCE TECHNICIAN 1
SFO 587 GSE GROUND MAINTENANCE TECHNICIAN 3
SLC 250 LINE AVIATION MAINTENANCE TECHNICIAN 17
SLC 250 LINE LEAD AVIATION MAINTENANCE TECHNICIAN 4
SLC 250 LINE SUPPLY ATTENDANT 2
TPA 478 MATERIEL LEAD SUPPLY ATTENDANT 1
TPA 478 MATERIEL SUPPLY ATTENDANT 1
Total 796
Users browsing this forum: Faro, OMP777X and 1 guest
