trex8
LD1 Vs LD3 Container
Sun Feb 12, 2006 3:15 pm
so how exactly does a LD1 manage to get more volume than a LD3 if the height and base size are the same????
744rules
RE: LD1 Vs LD3 Container
Sun Feb 12, 2006 3:53 pm
an ld1 container is for 747 lower deck only (if loaded in pairs). the base is indeed the same, but the "nose" is bigger
Glom
Mon Feb 13, 2006 1:57 am
Can't the 777F take LD-1s?
ha763
Mon Feb 13, 2006 1:23 pm
Quoting Trex8 (Thread starter):
The width of a LD1, including the contour (or overhang), is 92 inches, compared to 70 inches on the LD3.
Quoting Glom (Reply 2):
I believe the entire 777 family can take a single line of LD1s in the lower cargo hold. The contoured side need to be pointed inward because the contour of the lower cargo hold is only big enough for the contour of LD3s and LD6s.
Mon Feb 13, 2006 1:38 pm
LD1
This is one good LINK.
regds
MEL
trex8
Tue Feb 14, 2006 8:04 am
thanks to everyone, so its all in the snout!!
Glom
Sat Feb 18, 2006 6:10 am
Quoting Ha763 (Reply 3):
But I thought the asset of the 777F was that it could take them on the main deck like the 747F.
744rules
Sat Feb 18, 2006 6:41 am
Quoting Glom (Reply 6):
LD1/LD3 cannot be loaded on the maindeck of a 747F. Only containers/pallets with a 88x125/96x125 base.
Other uld's are 20ft pllt and 16ft pllt.
Glom
Sat Feb 18, 2006 6:54 am
Quoting 744rules (Reply 7):
Okay, I'm probably confusing names. I remember a discussion a while back around the time of the 777F launch about its potential and conversely any possible competition from Airbus with the A340. Someone said that the 777F could carry a type of container on the main deck that the 747F could as well, but any A340F wouldn't be able to because of the narrower fuselage.
ha763
Sat Feb 18, 2006 9:47 am
Quoting Glom (Reply 8):
That would be pallets built up to the 747 max of 10ft. That and AMJs side-by-side, which DC-10Fs, MD-11Fs, 747Fs, and A380Fs can do. The contour of the A300F doesn't allow for AMJs to be loaded side-by-side and since the A340 and A330 use the same fuselage as the A300, it would be the same.
trex8
Sat Feb 18, 2006 10:26 am
but 10ft pallets on the 777 will need a special contour, you can't put two 10ft high cubes in a 777F identical to those on a 747,
http://www.boeing.com/commercial/777family/pf/pf_freighter_int.html
http://www.boeing.com/commercial/747family/pf/pf_cargo_door.html
[Edited 2006-02-18 02:29:10]
[Edited 2006-02-18 02:31:44]
Users browsing this forum: No registered users and 21 guests
