KELPkid
Where's The 400 HZ "hum"?
Thu Feb 23, 2006 6:19 am
Hi,
anyone remember the not-so-distant past, where in-flight PA announcements and airliner radio transmissions often featured the familiar 400 Hz "hum" in the background? (presumably from the 400 HZ AC electrical bus...).
Either I'm going deaf at the 400 Hz level, or this once familiar airline aviation sound has disappeared? (presumably due to better electronic filtration...)
Anyone know the answer?
RE: Where's The 400 HZ "hum"?
Thu Feb 23, 2006 6:48 am
Quoting KELPkid (Thread starter):
I think you answered your own question there  Wink
timz
Thu Feb 23, 2006 7:54 am
I just heard it a couple days ago-- some sort of WN 737 I think it was.
prebennorholm
Thu Feb 23, 2006 8:00 am
If someone has a cure, then please come here and repair SAS's MD'80's.
After 25 years of 400 Hz hum it would be nice to hear what they want to tell us before take-off and landing.
I used to assume that they want to tell roughly the same thing as they tell on their Airbusses.
I always wondered how a plane can be certified for flight with such a lausy PA system. What if there was something important to tell the pax?
Thu Feb 23, 2006 8:51 am
Quoting Prebennorholm (Reply 3):
Yell. Incomprehensible but you can try to get your point across with volume.  Wink
Buzz
Thu Feb 23, 2006 10:23 am
Hi KelpKid, Buzz here. Maybe i'm going deaf also.... i don't hear it so much.
Lst time i really noticed it was when i was wearing a headset and let the dangling cord get close to the External Power cord, it transmitted reasonably well into the headset.
g'nite
sccutler
Thu Feb 23, 2006 12:10 pm
...I always figured that, when I fly in some of the airspace known for being more "hostile" (ORD Approach comes to mind), I could improve the quality of service if I had a tone generator overlaying a slight 400hz on my audio when transmitting.
I could be the first Bonanza with a 400hz AC bus, and CSD!
...three miles from BRONS, clear for the ILS one five approach...
MX757
Fri Feb 24, 2006 4:56 am
Quoting Starlionblue (Reply 1):
He did. Most new aircraft have better filtering (Shielding) then older ones.
Here is something a little off subject. If you take a multi-meter into an E&E bay of an aircraft, powered up of course, and set it on Hz you will pick 400 Hz with the leads hanging in free air. The 757 is the best to do it in.
Is it broke...? Yeah I'll fix it.
cancidas
Fri Feb 24, 2006 11:55 am
when you plug in 400hzand a ground comm headset you're nearly microwaving your brian....
"...cannot the kingdom of salvation take me home."
A/c train
Fri Feb 24, 2006 9:14 pm
improved cable screening, radio filters and checking static wicks is what rids radio interference.
Users browsing this forum: lightsaber, midexjet and 2 guests
