IFEMaster
757/767 Disintegration Point
Fri Feb 24, 2006 1:55 am
After some short but intense discussion on a now deleted thread yesterday, I started wondering about the physical capabilities and margins for 757s and 767s. So for those who are clued in, I have some questions...
What is the maximum tested airspeed for these types?
What is the maximum tested nose up/nose down angles?
What is the maximum tested bank angle?
What combinations of these were tested (such as a high speed sharp bank while in a nose-down attitude)?
Are prototypes ever tested to the point of destruction?
My curiosity is peaked by learning that a wing fairing detached from the UA 767 that hit the WTC - possibly because of the speed and bank angle?
Delivering Anecdotes of Dubious Relevance Since 1978
RE: 757/767 Disintegration Point
Fri Feb 24, 2006 2:07 am
Quoting IFEMaster (Thread starter):
Analys of the tapes has showed that the planes (or at least one of them) were pushing 400 knots. With that kind of overspeed it seems likely that stuff would start falling off.
On a related note it seems dumb to push overspeed when you can do enough damage with 250 knots. But I guess that wasn't the foremost thing on their minds...
MX757
Fri Feb 24, 2006 4:40 am
Quoting Starlionblue (Reply 1):
Do you know if it was 400 knots IAS or 400 knots GS?
Is it broke...? Yeah I'll fix it.
dw747400
Fri Feb 24, 2006 5:16 am
Quoting MX757 (Reply 2):
It doesn't make much difference at that altitude, unless the winds are extremely high (I don't believe they were).
CFI--Certfied Freakin Idiot
Fri Feb 24, 2006 5:33 am
Quoting Dw747400 (Reply 3):
Sorry should have been clear: I don't know. But as Dw747400 says, the altitude is low enough it doesn't matter much.
Areopagus
Fri Feb 24, 2006 6:46 am
Not that it makes much difference, as Dw747400 stated, but:
If "the tapes" were from the black boxes, then the datum is airspeed. But if "the tapes" are videotapes shot by people on the ground, the datum is ground speed. I believe I read that the speed estimates came from ground video.
Bobster2
Fri Feb 24, 2006 10:28 am
Some excerpts from the NY Times, 2/23/02:
"... new calculations showing that the passenger jet that hit the south tower had been flying as fast as 586 miles an hour, about 100 miles an hour faster than the other hijacked plane."
"The speed of the two planes at impact has been painstakingly estimated using a mix of video, radar and even the recorded sounds of the planes passing overhead."
"... In fact, the United plane was moving so fast that it was at risk of breaking up in midair as it made a final turn toward the south tower, traveling at a speed far exceeding the 767-200 design limit for that altitude, a Boeing official said."
"'These guys exceeded even the emergency dive speed,' said Liz Verdier, a Boeing spokeswoman. 'It's off the chart.'"
"... The M.I.T. analysis, by Eduardo Kausel, a professor of civil and environmental engineering, found that the United plane was traveling an estimated 537 m.p.h., while the American plane, the first to hit, was traveling 429 m.p.h."
"The Federal Bureau of Investigation said the government's analysis put the speeds at 586 m.p.h. for the United flight and 494 m.p.h. for the American one."
"... Flying a Boeing 767 straight ahead at 1,000 to 1,500 feet would not be too difficult, even at more than 580 m.p.h., and it would most likely not threaten the structural integrity of the plane, a half a dozen pilots and a Boeing spokeswoman said."
"But accurately turning the plane at that speed and maintaining the proper pitch, or up and down movement, is difficult, the pilots said, particularly for a novice pilot, and turning at that speed would have put excessive stress on the plane."
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
Mich
Fri Feb 24, 2006 2:40 pm
Quoting Bobster2 (Reply 6):
What are the g loads at this point of a airplane 762, at or above structural integrity ..?
Fri Feb 24, 2006 10:47 pm
Quoting Mich (Reply 7):
Approved G loads in clean configuration are on the order of +2.5 to -1.0. Certification is 50% more, so +3.75 to -1.5.
My guess is that we're not so much talking about snapping the wings as about stuff ripped off from the wings. But that's just a guess.
BTW Thx for the research Bobster2.
[Edited 2006-02-24 14:47:47]
aeroweanie
Sat Feb 25, 2006 3:04 am
586 mph is 509 KTAS, which at Sea Level is M=.77
From the 767 TCDS (A1NM):
Airspeed Limits: VD = 420 KCAS to 17,854 ft/.91M above 23,000 ft, linear variation between these points.
As KTAS = KIAS (which is more or less KCAS) at Sea Level, they were in excess of the dive speed for the aircraft. However, aircraft are designed with a 50% safety factor on loads (Ultimate Load = 1.5 * Limit Load).
Users browsing this forum: sulzerjan and 1 guest
