jumbojim747
When Is A Job Just Too Big?
Fri Feb 24, 2006 11:36 pm
When is a job just too big for Maintanace that maybe the manufacturer of the aircraft is called in.
On a wing and a prayer
longhauler
RE: When Is A Job Just Too Big?
Sat Feb 25, 2006 12:07 am
Usually the the main structure and strength of the aircraft is compromised.
Much like the SkyService B767 in the Caribbean, or the CP B767 in YHZ.
corey07850
Sat Feb 25, 2006 1:15 am
Quoting LongHauler (Reply 1):
Indeed....
CO had a 777 suffer a pretty bad tailstrike last year which required Boeing to come in and make the repairs. Apparently the entire tail of the aircraft was removed so that the rear galley was visible. Boeing was very strict about having no pictures taken as well...
aogdesk
Sat Feb 25, 2006 1:23 am
Yeah, anything less than severe structural damage can be accomplished using inhouse resources. It may require bringing in expertise or specifically tasked teams (sheetmetal/composites, engine change crew, etc) for field service, but most larger airlines have the skills within the company. Smaller operators may have to contract to larger airlines (UA Services as an example) to get those serious problems fixed.
miamiair
Sat Feb 25, 2006 1:45 am
I would not agree with this statement.
The aim of the Structural Repair Manual is to provide repair data and instructions to restore the airplane to original strength. There are times when the manual limits the repair and then says "Contact Boeing..." Even in those cases, Boeing can provide repair instructions and an 8110-3.
We have replaced major structural elements of the aircraft, such as the FS 820 fittings on the 707, lower 41 on 707s, rear spar chord on a 727, tail strikes on 757s. I remember having Douglas sent a team to replace the trunion fitting on a DC-8, after observing, we did it ourselves after wards.
It is a matter of data and resources. Obviously the manufacturer will have a field engineer when the damage is significant that can have several engineers available to assist in the matter. Also bringing in the manufacturer's team costs BIG BUCKS!
If it is a recovery, the manufacturer has teams and is better suited to recover an airplane than a repair station or an airline.
TimT
Sat Feb 25, 2006 1:48 am
NWA had a MLG tire on a DC-10 come apart in Bombay a few years ago. It took out the flap and a good part of the wing structure in the flap area. Boeing went in and fixed that. And NW changed their tire requirements for MLG's.
They had a similar thing with an Airbus- crew misread the T/O trim settings A/C thumped the compass rose at DTW pretty hard. From the outside it didn't look too bad- opened the aft compartment and found it was almost mortally wounded, floor beams broken, stringers twisted, just lots of bad things. They had Airbus come fix that one.
A319XFW
Sat Feb 25, 2006 2:18 am
Sometimes MRO's can write their own repair instructions if they are authorised by the local authorities. For instance Air Canada sometimes did repairs when the damage was outside limits of the SRM, but justified by comparison etc. In most cases this was done and additional/more frequent inspections demanded and the damaged repaired at the next major check.
SFOMB67
Sat Feb 25, 2006 5:31 am
Quoting TimT (Reply 5):
In my own experience, I have found that the airline engineers are more and more moving away from from this, and letting BACO take the responsibility. I'm not sure if it's lack of experience and knowledge on the engineers part, or their managers/company that don't want to shoulder the responsibility. We used to have engineers that would write repair specs period, then we had repair specs that would require BACO approval (sometimes these would end up being permanent, sometimes good for a time limit, ie. next c-ck), then we had to get BACO approval up front. I also experienced repairs (such as limits on boring T/R hinges to clean up corrision) that were once approved, no longer being approved. I think a lot of this has to do with liability .
onetogo
Sat Feb 25, 2006 6:43 am
Isnt UAL still waiting for Boeing to come out to Sydney to fix the wing on their wounded B744?
A/c train
Sat Feb 25, 2006 9:34 am
the job is to big when the company/airline decide its to big. Damage to an aircraft may not have a repair in the SRM, this does not mean that they get the manufacturer in to repair it, it means you need to get the manufacturer to approve a repair scheme which you can then perform.
Your companys maintenance control communicate with the big chiefs to decide wether a job is to big.
kaddyuk
Sat Feb 25, 2006 12:05 pm
Its not just the size of the job but also the cost... Can you just imagine the cost associated with the removal and replacement of something as complex as a wing spar or MLG Trunnions...?
There is a point where the job is not economically viable and the aircraft is scrapped... Much like an insurance write-off... Some aeroplanes are worth more being broken up and used for spares...
Stealthz
Sat Feb 25, 2006 2:03 pm
Quoting Onetogo (Reply 8):
Hope not, the 744 was in MEL not SYD so that wouldn't have been a big help!!
BTW N127UA ferried MEL-LAX as UA9923 on Thursday Feb 23
C
[Edited 2006-02-25 06:11:09]
MX757
Sat Feb 25, 2006 2:21 pm
Quoting Corey07850 (Reply 2):
There are a couple of pictures on CO's Tech OP's web site but I would get into some serious s*** if I linked the pic's here. Sorry. You're right it was a big job the entire 48 section (major zone 300) was removed to facilitate replacement of the aft pressure bulkhead. The entire tail was suspended from an overhead crane with the vertical stabilizer removed.
Three years ago CO was involved in the 737-500 EGPWS pilot project modification. The very first -500 EGPWS was accomplished here in MCO. As an avionics tech I was heavely involved in re-wiring the aircraft.
We had engineers and test pilots from Boeing, Rockwell/Collins engineers, FAA rep's, and CO engineers. Basically the job entailed conversion from VOR/ILS recievers to MMR's. Installalation of GPS antenna's. Replacement of the old GPWS system to the EGPWS system. Many other systems required modification also, the IRS, EFIS, autopilot, and FMS all had to be modified. The project took three weeks to complete. It was by far the biggest job I have been involed in to date.
Is it broke...? Yeah I'll fix it.
777wt
Tue Feb 28, 2006 5:36 am
An improper jacking on a 744 at LH maintenance caused the 747 to bend and wrinkle behind the wing, LH built a jig to hold the tail of the 747 and fixed the 747 by removing the damaged part and replacing it with a new section.
An Boeing rep came over to oversee the operation and was impressed that Boeing offered LH an contract for aircraft crash restruction, but LH turned it down.
