Argonaut
Boeing 767-300 Cabin Window Pattern
Thu Mar 02, 2006 3:41 am
My questions concern the gaps in the otherwise continuous cabin window pattern observable on all Boeing 767s, especially just ahead of the wing.
Next week I will be travelling by Air New Zealand 767-300ER on a trans-Pacific flight. My seat assignation is in row 13. The first question is: in that row, am I doomed to a "non-viewing" window seat? (BTW, don't you just love that oxymoron?)
Although I've flown in plenty of 767s before, this will be my first time on an NZ example. As we all know, every operator has a different seating layout, particularly in this area of the cabin---so my previous experience with other airlines' 767s means little. To find out the NZ 763 cabin configuration, I've checked all the sources I can find; the most helpful has been SeatGuru, which seems to indicate that everything will be just fine and I won't be staring at a blank wall after all. But is it true?
My second, more general question is: why are those windows omitted anyway? I have always believed it was because there were extra frames at those stations in the fuselage structure. Is this correct?
Thanks for any help.
'the rank is but the guinea stamp'
CCA
RE: Boeing 767-300 Cabin Window Pattern
Thu Mar 02, 2006 4:33 am
Quoting Argonaut (Thread starter):
The reason there are no windows at those positions is due to "riser ducts" these are ducts that feed the air from the Air Con packs under the center wing to the ceiling where it's distributed throughout the A/C.
It differs on A/C types the 767 for example the air leaves the packs going fwd of the center wing tank and up into the rear of the fwd cargo where it enters a mixer unit, from there it's fed to the risers. As you can see the 777 has blank spaces as well.
Photo © Islam Chen
Photo © Red-Phoenix AirPics
There is no window frame at these points it's just the skin as the frame if installed would take up to much space.
The 747 has 3 risers each side the air leaves the packs rearward and goes up in the fwd part of the wheel well it then goes into the mixeror air plenum on top of the center tank, from there it's fed to the risers. As you can see the A330 has one fwd of the wing it's possible it may have one aft of the wing as well.
Photo © Andreas Muhl
Photo © Nick Onkow
[Edited 2006-03-01 21:11:21]
P1 in A330, A340, A346, B742, B744, B748.
Argonaut
Thu Mar 02, 2006 8:01 am
Thanks for explaining so clearly. Now I have the picture.
BTW, by "frames", I really meant fuselage frames (or hoop frames, as some call them) to which stringers and skin are fastened, rather than window frames, but that doesn't affect your answer.
Thanks for taking the trouble, and for hunting down illustrations too! Much appreciated.
hmmmm...
Thu Mar 02, 2006 9:36 am
Well yes you are doomed. Simply by the mere fact that you are in row 13. I don't know of anyone who has sat in row 13 and actually made it to their destination. I'm not saying it's not possible. I'm just saying I don't personally know of anybody.
An optimist robs himself of the joy of being pleasantly surprised
CCA
Thu Mar 02, 2006 7:43 pm
Found some more pics, you can see the risers in the first pic, this is from the SCA (Shuttle Carrier) though so the huge frames between doors 3 & 4 arn't on standard 747s.
Photo © Jack Hannen
Photo © Mario Nonaka
Photo © Nick Onkow
Photo © Tomislav Muic - CroSpotterTeam
Photo © Je89 W.
Tod
Fri Mar 03, 2006 12:51 am
737NG have one riser on each side forward of the wing.
http://i30.photobucket.com/albums/c325/tod_work/AS73G_2.jpg
Old 737 don't because they use a whole bunch of little ducts that route around the windows instead.
Tod
Argonaut
Fri Mar 03, 2006 1:44 am
Quoting Hmmmm... (Reply 3):
Well, naturally I broke into a cold sweat when I saw the seat allocation.  crossfingers  Yikes! Then I remembered...
...I'd done it before! And survived! So from now on, you do know of at least one person who has made it. Of course, I might have passed into an alternate dimension on the journey... worried ...
But no way will you get me to stay on floor 13 in a hotel. I'm not that crazy.
Tod
Fri Mar 03, 2006 2:52 am
Quoting Argonaut (Reply 6):
Did it in Paris and survived.
I'm not that crazy.
I think it was why I actually ate Corsair Y class meals two days in a row and live to tell about it.
Tod  Wink
Users browsing this forum: 1337Delta764, egnr, manilaflyer and 1 guest
