CruzinAltitude
Take Off Roll Call Outs
Fri Mar 03, 2006 11:25 am
I have a quick question for any Pilots (or people who know way to much about aviation to not be a pilot). . .
As the flight crew advances an airliner down the runway, what is called out just before "V1 Rotate" and what is called out just after "V1 Rotate?"
Thanks in advance for your responses.
seanp11
RE: Take Off Roll Call Outs
Fri Mar 03, 2006 11:27 am
"V1" and "Rotate" technically are seperate callouts. :p
Perhaps the callout you are talking about is the one for 80 kts. That is when the rudder becomes active.
CruzinAltitude
Fri Mar 03, 2006 11:29 am
Thats true, they are seperate call outs. Im just wondering what is the call out right before, and right after.
CruzinAltitude
Fri Mar 03, 2006 11:32 am
Is it "V1" "Rotate" "V2"?
and if so, what does V2 mean?
onetogo
Fri Mar 03, 2006 11:41 am
Callouts of "airspeed alive" followed by "80 knots ... V1 ... Rotate (some say 'vee are') ... V2" are pretty much standard on all flight decks from what I've seen.
CruzinAltitude
Fri Mar 03, 2006 11:44 am
Great, thanks for the info.
seanp11
Fri Mar 03, 2006 11:47 am
V2 is the minium safe climbout speed. The aircraft can fly after this speed.
Goldenshield
Fri Mar 03, 2006 11:49 am
V1 = maximum speed that a takeoff may be aborted if an engine is lost.
Vr = speed at which rotation should occur
V2 = minimum flight safety speed. This is the minimum speed that will allow the aircraft to climb out on one engine.
There are many, many other V speeds as well, but that's not the scope of this thread.
[Edited 2006-03-03 03:50:23]
EssentialPowr
Fri Mar 03, 2006 12:09 pm
The call outs also vary greatly from company to company.
On the 727 and ERJ for ex, V1/Vr were/are typically the same number - unless a V1 reduction is made. This would be due to a contaminated runway, for example, in which an earlier decision speed helps mitigate the probability of executing a rejected take off.
cheers-
CosmicCruiser
Fri Mar 03, 2006 12:15 pm
Quoting EssentialPowr (Reply 8):
That's true, we just make the 80kt call, V1 and rotate, no V2 call in the MD-11.
Goldenshield
Fri Mar 03, 2006 12:27 pm
V speeds are figured from performance tables set by the manufacturer. I've never heard of 'airline specific' speeds.
EssentialPowr
Fri Mar 03, 2006 1:20 pm
Goldenshield, here are 2 examples...
Embraer certifies and flys the ERJ in the landing config at the top of the white arc for an approach speed. Most ERJ operators in the US add 5-10 kts to this value for their ref and target speeds. This varies from airline to airline. Cont EXpress, before the XJT days, was white arc plus 10 for both values (which were separated by 5 kts). About 3 years ago, they went to "white arc" plus 5 kts due to the fact that 5 kts makes a big diff for a transport category a/c in terms of landing distance, which corresponds to revenue. Because these values were published in FAA approved manuals, the new values had to reapproved by the FAA, but are certainly airline specific.
goboeing
Fri Mar 03, 2006 1:23 pm
Northwest uses:
80 knots
checks
100
120 (if needed)
140 (if needed)
Vee one
Rotate, ## degrees
Positive rate
gear up
Goldenshield
Fri Mar 03, 2006 1:25 pm
Most airlines use Aerodata now anyhow, and since they are FAA approved, it's pretty much irrelevant anymore. :P
Quoting EssentialPowr (Reply 11):
5 knots makes a big difference in terms terms of landing distance, which corresponds to SAFETY.
EssentialPowr
Fri Mar 03, 2006 1:29 pm
The 2nd example is takeoff performance...Boeing never published a comprehensive, reduced thrust takeoff profile for the 727. Why? Because it was fleet specific. NWA had a fleet that consisted of a/c from several manufacturers (Hughes Airwest, Republic, Eastern, etc) with thrust combinations that were too expansive for Boeing to consider. NWA used JT8D-9s, -15s, -17s, and 17 Aprs... and was approved for an Intermix for those engines, meaning an a/c could have 3 different dash types on the same a/c.
If you've followed this so far, then you'll follow the rest. That variation was airline specific, therefore the V speeds were as well. Not a huge difference, but a significant difference...
EssentialPowr
Fri Mar 03, 2006 1:34 pm
Goldenshield,
So now maybe you agree w/ me? What's the biggest gag in the crewroom when the weather's bad?
"How's the weather at XYZ? Doesn't matter...we GOIN' anyhow!!!"
The airline business is based on $$$....the safety part comes from crews, maintenance, dispatch and ATC, among others...
cheers-
Goldenshield
Fri Mar 03, 2006 9:22 pm
Quoting EssentialPowr (Reply 15):
That's a new one on me. Usually, it's "What can we break to get out of this trip?"
CosmicCruiser
Fri Mar 03, 2006 10:13 pm
Quoting Goldenshield (Reply 10):
I THINK what the post is referring to is what CALLOUTS do airlines use. This would/ could be airline specific. I can say that here we used to call 80, V1, rotate,positive rate AND V2 in the 727; in the MD-11 we don't call V2 because the FMS is going to guide you to V2+10 with all eng and V2 with an eng. out so it's a superfluous call. For app/ldg there are no airspeed calls(for us) except "Betty's" calls at 500', 50, 40, 30, ..etc.
757dc10fltmech
Fri Mar 03, 2006 10:57 pm
Some callouts I have seen while riding as an observer on the DC10-30:
PIC: "Auto throttles on set take-off thrust."
The FE will then watch the throttles and engines to make sure they are at the proper TO thrust setting per the TRC when it is verified the FE calls out: "thrust set"
CAN DO!
Goldenshield
Fri Mar 03, 2006 11:09 pm
Quoting CosmicCruiser (Reply 17):
I think you may be right. It's all a matter of interpretation to what was said.
EssentialPowr
Sat Mar 04, 2006 12:11 am
"The call outs also vary greatly from company to company." That was exactly the point I was making from the beginning.
Cheers-
Ralgha
Sat Mar 04, 2006 3:15 am
Quoting Goldenshield (Reply 16):
Golden's right. It's all about getting out of the trip. Unless it's the last day, then it's all about finishing early.
XFSUgimpLB41X
Sat Mar 04, 2006 4:39 am
We have:
set thrust.... thrust set
80 knots... check
V1
rotate
V2
Positive rate.... gear up
The rest are Flight guidance callouts. Speed mode at V2+10-15, Heading or Nav mode at 400 feet, and the autopilot becomes and option at 600 feet.
Chicks dig winglets.
David L
Sat Mar 04, 2006 5:20 am
Quoting XFSUgimpLB41X (Reply 22):
I presume (with a name like mine I can presume) that's Speed Mode between V2+10 and V2+15, rather than V2-5? (Pardon the ignorance!)
Pihero
Sat Mar 04, 2006 9:03 am
During the takeoff roll it is better to have a quiet cockpit apart from the very important call outs :
Ready to go, the captain announces "Takeoff, V1 is xxx kts"
Once the thrust is set PNF announces "parameters stable"
PF calls out the FMA "Man Flex XX° SRS RWY NAV and A/THR armed "
PNF :
-100Kts (for ASIs xcheck and the signal that from now on we'll only reject for an engine failure or a severe structural damage)
-V1
-Rotate
Contrail designer
EssentialPowr
Sat Mar 04, 2006 10:02 am
In the US it's typically called a "sterile cockpit." Some airlines use "parameters stable" others use "thrust set, xx.x%N1". The takeoff profile callouts will vary with different thrust settings, flap settings, even MELs/CDLs...
cherz
PhilSquares
Sat Mar 04, 2006 10:14 am
The takeoff callouts are really airline specific. For example, on the 744, the calls vary from a few airlines I've been involved with. For instance, some airlines call "hold" and "80 knots" as two distinct calls, while others have it as one call. The V1 and Vr calls are fairly standard and most have no calls after Vr. But again, that's airline specific.
Fly fast, live slow
EssentialPowr
Sat Mar 04, 2006 10:18 am
"The takeoff callouts are really airline specific"
...I think we've made that point!
PhilSquares
Sat Mar 04, 2006 12:07 pm
Quoting EssentialPowr (Reply 27):
And your point is? Judging by the responses, that point, while written, hasn't been made.  Smile
Fly fast, live slow
EssentialPowr
Sat Mar 04, 2006 12:24 pm
I respectfully disagree. Did you take the time to read the entire thread? I think it's been rather well made, with examples, and in fact you restated a comment I made 22 posts ago.
cheerz
PhilSquares
Sat Mar 04, 2006 2:56 pm
Quoting EssentialPowr (Reply 29):
Like I said, judging by the comments, people either didn't read that or just didn't care. I didn't know this forum was restricted to one correct response?
Sometimes, people have to have the same response either repeated verbatum or rephrased.
 Big grin
Fly fast, live slow
Users browsing this forum: Yahoo [Bot] and 1 guest
