A342
772 Being Operated To/from 28m Wide Runway?
Fri Mar 10, 2006 6:29 am
I cannot quite believe this, but it appears UU regularly operates 772s to DZA (Dzaoudzi, Mayotte), an airport with a 1929x29m runway. What strikes me isn´t the runway length as the flight only goes to RUN (1416 km away), but rather the width of the runway. 28 meters ! Is that enough for a widebody, let alone a 772 ?
Maybe runway has been enlarged, but 2 sources state this runway dimension.
Here´s a pic, not at DZA though, but the capture says the aircraft goes to DZA:
Photo © Mickael Payet
Here are the sources for the runway dimension:
http://gc.kls2.com/airport/DZA
http://www.worldaerodata.com/wad.cgi?id=MF75763
The last source may have a bug though: It says at DZA there is only avgas available, but actually jet aircraft fly there.
The flight can be found on Amadeus.
Happy posting !
Exceptions confirm the rule.
A300605R
RE: 772 Being Operated To/from 28m Wide Runway?
Fri Mar 10, 2006 8:17 am
The space between left and right maingear on a B777 is 10,97m.
If runway and taxiway are strong and turnpaths are wide enough, there is nothing against a B777 on a 30m runway.
http://www.boeing.com/assocproducts/aircompat/acaps/777rsec2.pdf
http://www.boeing.com/assocproducts/aircompat/acaps/777rsec4.pdf
300 319 320 321 332 733 734 735 738 753 763 F27 M83
A342
Sat Mar 18, 2006 7:52 pm
Quoting A300605R (Reply 1):
Thanks for your answer.
However, isn´t there a minimum runway width for every aircraft (except emergencies) ?
For example, the A380 needs 45m width+shoulders, a total of 75 meters, or better, 60m+2 shoulders 7,5m wide each.
Isn´t the minimum runway width for a 777, which I believe is a category E aircraft, 45 meters ?
Sat Mar 18, 2006 11:50 pm
Quoting A342 (Reply 2):
Isn�t the minimum runway width for a 777, which I believe is a category E aircraft, 45 meters ?
Well, the 380 has four engines and the 777 has two. So no outboards on the 777 that can FOD. Ergo more narrow runway is fine as long as there are no obstacles.
