miamiair
SAS MD-80 Maintenance Base?
Fri Mar 10, 2006 10:46 pm
Does anyone know where SAS has their MD-80 base?
I have to travel there to inspect a component and the company that has the component will not know that answer for a while. Any help would be greatly appreciated.
aogdesk
RE: SAS MD-80 Maintenance Base?
Fri Mar 10, 2006 11:47 pm
Not sure about the MD Overhaul base, I can check when I get into the office, but heres a few contacts:
http://www.sastechnicalservices.com/wwwSTS/default.asp
My apologies if you've already got those.
Cheers!
B727230
Sat Mar 11, 2006 5:16 am
Stockholm and Copenhagen are MD-80 homebases in Scandinavian Airlines. Heavy maintenance on the MD-80 used to take place in Oslo, I'm quite sure it still is like that. Since ARN and CPH are also used for maintenance, you would probably be successful contacting either of these STS branches.
Wieder in die Sonne fliegen
Sat Mar 11, 2006 6:23 am
Quoting Miamiair (Thread starter):
Direct flights to Stockholm (ARN) from the US are with SAS, from EWR, SEA, ORD. Otherwise connect through the usual suspects: HEL, LHR, FRA, CDG, CPH.
CPH is easier.
mikkel777
Sat Mar 11, 2006 6:33 am
Quoting Starlionblue (Reply 3):
Not from SEA to ARN, only SEA-CPH.
SAS had their MD80 main maintenance base at OSL, I did part of my master thesis there some years back.
Sat Mar 11, 2006 7:38 am
Quoting Mikkel777 (Reply 4):
Oops. Brainfart. You are of course correct.
FBU 4EVER!
Sat Mar 11, 2006 8:07 pm
Heavy Maintenance on SAS' MD-80/90's and Spanair MD-80's is still being performed at OSL even though none are operationally based there.They fly out of ARN for SK.se and CPH for SK.dk.
"Luck and superstition wins all the time"!
Users browsing this forum: gloom, MSN [Bot], WIederling and 1 guest
