azstagecoach
Drinking Water: Real Problems, Real Solutions
Sat Mar 25, 2006 1:45 am
First off, this is my very first post on a.net, and I am thrilled. I love this place!
We know the drinking water is a serious problem, and that "bring your own water," while practical, is not the long-term solution. Now I know there are plenty of threads about drinking water on planes, consisting mostly of advice not to drink the water. This thread is more specific, hence the placement in tech/ops. The goal is to get actual, bonafide potable water for drinking on planes, and for me, that would mean I could actually drink the coffee again too!
So three questions:
(1) will the new EPA regs solve the problem?
(2) if not, what WILL solve the problem?
(3) have there been any actual, reported incidents of serious illness due to drinking the water on airplanes? (not the same as "a friend of a friend...)
Any info would be greatly appreciated. Thanks!
azstagecoach
hangarrat
RE: Drinking Water: Real Problems, Real Solutions
Sat Mar 25, 2006 2:42 am
Actually, I never really knew there was formal advice against drinking the water on airplanes. I always took it as a common sense thing, as I'd no sooner drink water from the lav than I would from a Greyhound station bathroom.
As for things like coffee, the water has been boiled so it shouldn't be a concern. Are there concerns about other contaminants? Please elaborate.
Spell check is a false dog
KELPkid
Sat Mar 25, 2006 4:04 am
Quoting HangarRat (Reply 1):
Boiling only kills pathogens, and IIRC, the minimum boil time to guarantee all pathogens and spores are really dead is 30 minutes. Boiling will not eliminate contaminates, such as lead or arsenic (arsenic is a common problem in groundwater in the Southwestern USA...).
I'd hope the airlines start taking care of this themselves, as it would be expensive if the EPA had to get involved...it wouldn't be hard for each airline to hire an environmental engineer and make sure that the "potable" water system was maintained to a minimum standard (by creating, and having the ground crew, adhere to standards, such as is already done with the fuel system. When was the last time an airliner crashed due to fuel contamination  Wink ).
Dalmd88
Sat Mar 25, 2006 6:38 am
Potable water systems are periodiclly disinfected. I've either done it or seen it done on most of the letter checks I've worked on. I think it was about two years ago the FAA got real concered about the quality of the water and we started constantlly doing water samples. The result I saw was our proceedure fro disinfecting the tanks was improved. After about a year of the new proceedure the rate of testing has dropped. That tells me the quaility is pretty good. Some of the guys I work with would never touch the coffee on the planes, but I think it is safe. I think the water tastes better than some of the bottled stuff coming off the Europe originating flights. That Vittel crap from France is the worst.
Tornado82
Sat Mar 25, 2006 6:43 am
Quoting Azstagecoach (Thread starter):
I'm not speaking for all planes, but at least on the ERJ, the coffee pots are filled by using a gallon-or-so reservoir filled with bottled water. This reservoir is in one of the stowage areas of the galley. When you walk into the plane, you are practically staring right at where the reservoir is. Therefore, you can at least drink the coffee on an ERJ.
eilennaei
Sat Mar 25, 2006 7:11 am
Although not directly applicable in an a/c, this might give you an idea.
You can feed water from any odd natural source in and get safe water after filtration. The microfilter only lets small (water) molecules through.
http://www.scan-water.com/
http://www.adlux.fi/public/eng/pdf/Test%20results%20eng..pdf
Bobster2
Sat Mar 25, 2006 7:54 am
The drinking water issue was first raised by The Wall Street Journal in November, 2002.
http://www.mindfully.org/Water/Airline-Water-Safety1nov02.htm
This is what motivated the EPA to take action.
Note that almost all airlines have an official policy of using only bottled water for drinking. However, flight attendants have admitted to using tap water when the bottled water runs out.
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
kaddyuk
Sat Mar 25, 2006 8:45 am
Quoting KELPkid (Reply 2):
Doesnt mean that fuel ISNT contaminated... The A346 weekly has a function to operate the fuel drain ports to get rid of water that has settled at the bottom...
Granted that fuel contamination is small, but it still exists...
I Have done the steralization of the water system. And even though i know i've done the job correctly, i cant guarentee that the handling company has steralized the water they put on the aircraft properly. That is why i choose to drink bottled water on the aircraft. Better still...
Feed me Vodka & Apple Juice anytime! :P
CFIjames
Sat Mar 25, 2006 9:09 am
I used to work on the ramp in Salt Lake City. We had a portable potable (say that 10 times fast) water tank. I can remember seeing a slight slimy layer of algae forming in there after sitting out in the desert sun for days on end. I know it got cleaned now and then, but it was not exactly Evian. (evian=naive) The potable water hoses at another gate were nothing more than glorified garden hoses taking tap right from wherever the airport gets its water. What i dont know is when/if the potable water tank on the airplane EVER gets cleaned, and I'm sure it would need to be cleaned often, given the fact that it never gets completely empty (even on winter RONs, it was emptied, but that moist little biosphere must really harbor bacterias and other nasties)
Now you have to think about this for a second, and draw your own conclusions. Usually there is one ramper assigned to do the water and LAV on the planes after the bags have been brought to the bag claim. Rules say that you always do the water first, then lavs after, but Im sure this doesnt always happen. I'm sure that not everyone wears the latex gloves while doing the lavs, they might just use the regular "bag throwing" gloves that they already have on. This is just BAD. I insist on bottled water, or no water at all. (although i like Kaddyuk's suggestion. Just bring me a rum and coke.)
There are 3 simple rules for making a perfect landing every time. Its a shame that no one knows what they are.
kaddyuk
Sat Mar 25, 2006 10:08 am
Quoting CFIjames (Reply 8):
Its part of an A check... I'm not sure which ones... But i know its not every check...
They do get cleaned and filtered but i refuse to drink water on an aircraft that has not been boiled previously...
pilotpip
Sat Mar 25, 2006 11:45 am
Another issue that you guys aren't bringing up has to do with the water source itself. Have you ever really watched how poorly those hoses are maintained and handled?
DMI
Bobster2
Sat Mar 25, 2006 1:10 pm
Quoting Pilotpip (Reply 10):
Right. The other issue is the FDA. The OP specifically asked about EPA so I didn't bring up the FDA.
The FDA has rules but very few inspections, not enough resources to inspect the airport water sources and food catering often enough.
The FDA is responsible for the ice brought on the plane. If you're afraid to drink the coffee, you should also be afraid to put ice in your soda.
The basic rules are don't drink the water, and don't order the fish.
JAGflyer
Sun Mar 26, 2006 12:42 am
I have clearly seen FA's filling up jugs of water in the Y galley and then serving it to pax in the Y cabin. Of course, the J cabin gets the DASANI bottled stuff. I don't drink water on planes so I don't really worry.
Support the beer and soda can industry, your recycle old airplanes!
longhauler
Sun Mar 26, 2006 12:52 am
I recently flew a trip YYZ-SJO-YYZ. On the way north, the Flight Attendants were reporting that the passengers were complaining about the water ... both from the lavs, and in the coffee. (same source). They said it smelled like diesel fuel.
Upon investigation, we found that they serviced the aircraft from a water tank that previously held jet fuel!!!
Until the problem was rectified it became policy NOT to uplift drinking water from anywhere in Costa Rica. It took about 6 weeks.
[Edited 2006-03-25 16:53:59]
Tristarsteve
Sun Mar 26, 2006 1:54 am
Our airline has a team of hygiene inspectors. They turn up every year and take samples from the water supply, the water trucks, and the aircraft. Our trucks have a cleaning schedule where the tank is emptied every week, cleaned and refilled. All the water trucks are filled from a special tap, that is outside my office! We actually drain the aircraft water tanks every night, and fill them up fresh in the morning. I have always drunk aircraft tea and coffee, do it every day, and so do our crews. Never noticed any ill effects.
Reading these and other posts, perhaps airlines in the Americas should take water more seriously.
hangarrat
Sun Mar 26, 2006 3:19 am
I guess when you get down to it, you're taking luck of the draw where ever you go. An eighth-grade girl discovered you're better off drinking from the toilet in most fast food joints:
http://abcnews.go.com/GMA/OnCall/story?id=1641825&page=1
Sun Mar 26, 2006 3:40 am
Quoting HangarRat (Reply 15):
Yet another reason not to drink ice with a little soda as the Americans do. Big grin The drink is already cold. Why do you need ice?
Sun Mar 26, 2006 6:26 pm
I would advice the same too.  Smile
Quoting DALMD88 (Reply 3):
Neither would I.
Out here All the Operators offer packaged drinking water.The potable water is used only at the basins.
regds
MEL
Sun Mar 26, 2006 10:34 pm
Quoting HAWK21M (Reply 17):
Neither would I.
The coffee has been boiled right? Should be pretty safe from pathogens. I don't drink it because it tastes bad, but that's anothe matter  Wink
azstagecoach
Mon Mar 27, 2006 7:39 am
Thank you for the responses.
(1) Has anyone actually become sick from the water?
(2) TristarSteve (Reply 14) sounds like his airline has a strict program to ensure water safety. Has anyone heard of other airlines doing this?
Mon Mar 27, 2006 8:44 am
Quoting Azstagecoach (Reply 19):
No idea. But just looking at those meals makes me sick. Big grin
AvionicMech
Mon Mar 27, 2006 9:23 am
We have had passengers become sick from drinking the water onboard, but that was nothing to do with the aircraft but the water that was put onboard in Brazil I think it was. It was reported by the crew before the plane even arrived back in the UK and before the aircraft flew again the entire syetm was cleaned and dis-infected and new water filters installed through-out the aircraft.
zizo6
Tue Mar 28, 2006 3:54 am
why do we need potable water ? i have been told that it is not for drinking !!!
Tue Mar 28, 2006 4:15 am
Quoting Zizo6 (Reply 22):
The term "potable" means "suitable for drinking". And when I fly, I like to drink water. It's the hands down best way to prevent dehydration.
Bobster2
Tue Mar 28, 2006 8:49 am
How could you know if passengers became sick from the water? Food poisoning illnesses usually take 24 hours or more to begin symptoms. You would have to find all the sick people to confirm that they all had the water in common (and none of them had the fish Big grin ), plus laboratory testing (stool samples, yuck!) to confirm the pathogen and trace it to the source.
The most widely documented cases of food poisoning on planes resulted from infectious people with open sores or other gross contamination working for the food catering companies. It's hard to find any documented and proven reports of people getting sick from water.
On one episode of the "Betty in the Sky with a Suitcase" podcast, a flight attendant confesses to brewing a pot of coffee without noticing that there was a dead mouse in the pot. She discovered the dead mouse only after serving the coffee to passengers.
Wed Mar 29, 2006 12:18 am
Quoting Starlionblue (Reply 23):
Isn't Packaged Bottled 125ml water distributed out there.
regds
MEL
Wed Mar 29, 2006 12:52 am
Quoting HAWK21M (Reply 25):
It depends. In the US it's mostly bottled poured into glasses. On long haul it's sometimes little bottles.
kaddyuk
Wed Mar 29, 2006 1:27 am
Quoting Starlionblue (Reply 26):
I'd rather go thirsty than drink aircraft water, its high in chlorine to kill the germs and often comes out cloudy... It tastes like soap and probably isnt as good for you as they try to make you belive...
KELPkid
Wed Mar 29, 2006 4:10 am
regds
MEL
In the US, the 1/2 liter (16.9 Fl. Oz) bottle is much more common...larger sizes are available, all the way up to the 1.5 liter monsters that I used to stick about 2-3 of in my backpack when I'd go desert hiking  Wink
The airlines typically use water supplied by their soft drink vendor, which are bottled in whatever size the vendor chooses to use (and I don't have one of them handy at the moment, I don't drink soda, and it's too expensive to drink from the vending machine here at work).
727EMflyer
Fri Mar 31, 2006 6:25 am
Surprise, water is nasty stuff! Appearances can be deceptive though because sometimes the algae and slime that make you squirm are the same things that make water fine to drink! On board submarines, my day job, we have tanks to store our potable water and tanks to store our sewage. Periodically they both need to be opened up for inspection, cleaning, maintenance etc. Guess which one smell better inside.... the sewage! The potable water tank is coated with a slime that is probably related to algae somehow. It occurs naturally, but never the less, it gets cleaned out whenever the tank is opened. Afterwards the water has a distinct metallic taste, like drinking from a garden hose.... can't wait for the slime to grow back!
Point is, drink the water. Its fine.
azstagecoach
Fri Mar 31, 2006 1:46 pm
Quoting Bobster2 (Reply 24):
they all had the water in common (and none of them had the fish ), plus laboratory testing (stool samples, yuck!) to confirm the pathogen and trace it to the source.
This is exactly the problem though. Even when EPA tests the water they are testing for fecal coliform levels, which merely suggest the presence of other pathogens, so it doesn't acually prove there are things in the water (other than coliform). Seems like the airlines get a free pass then.
Quoting 727EMflyer (Reply 29):
Very interesting. So the slime is harmless, but makes the tank smell worse than sewage?! Strange if true.
Fri Mar 31, 2006 11:05 pm
Quoting Kaddyuk (Reply 27):
I can accept that. But on the other hand dehydration is no picknick either. I could drink soda, but the amount of sugar in soda (or juice) is way above acceptable for my taste to drink 2 liters on a long haul flight.
Fri Mar 31, 2006 11:30 pm
Tod
Sat Apr 01, 2006 12:01 am
As long as your body is used to it.
Very similar to drinking the water in a foreign country. You can't always drink what the locals can.
Tod
eilennaei
Sat Apr 01, 2006 8:24 am
Algae require light to grow so they can't be alive long in a closed tank. I'd think bacteria and yeasts are to blame.
zizo6
Mon Apr 03, 2006 3:36 am
We use Pallin test to check on chlorine level.
although the refill point is the same but we get different readings from time to time and from unit to unit .
Users browsing this forum: sharles and 1 guest
