MSYYZ
How Long Between Long Haul Flights..
Wed Mar 29, 2006 1:30 am
I am just wondering , is there a recommendation from Airline Manufacturers regarding how long should a long-hauler stay on the ground between 2 long haul flights ? Or it depends on the Airline's operation policy ?
Another question , is it a normal procedure for Airlines to use a long-hauler on a short-haul high density route between 2 long-haul flights ?
Any answer is much appreciated .
A346,A343,A342,A332,A333,A310,A300,AB6,A319,A320,A321,B741,B744,B777,B767,B732,B735,B727,B707,B757,MD80,F-70,E-170,B738
747luvr
RE: How Long Between Long Haul Flights..
Wed Mar 29, 2006 1:40 am
In order to give the a/c a 'rest'?
jush
Wed Mar 29, 2006 2:05 am
Quoting 747LUVR (Reply 1):
He might mean something like engine cool down or so. Can't imagine anything else.
Can't give you any answer though only that engines are cooling down in descent already cause they're quite a long time almost idle.
jush
There is one problem with airbus. Though their products are engineering marvels they lack passion, completely.
MSYYZ
Wed Mar 29, 2006 2:19 am
That's exactly what i mean .
Wed Mar 29, 2006 2:31 am
Quoting MSYYZ (Reply 3):
There's really no need for a rest. That is, the requirements for fueling, catering, unloading and loading of cargo and pax will in almost all cases exceed any need for a rest. The only thing I can think of is brake cooling time, but with new carbon discs it's not a problem unless maybe you just rejected a take-off.
The other reason for a "rest" is maintenance.
LTU932
Wed Mar 29, 2006 6:50 pm
Quoting Starlionblue (Reply 4):
I recall the A343 needs lots of brake cooling time, since those brakes are used up much more than the others due to the insufficient reverse thrust those CFM56 produce. Please correct me if I'm wrong on that.
Wed Mar 29, 2006 7:21 pm
Quoting LTU932 (Reply 5):
We have recorded the brake cool down times in our manuals. Can have brake temps at 500 deg 60 minutes before pushback and still will be cool enough for takeoff, they dont get anywhere near this. Outside air temperature was found to have little effect on cool down times, wind speed does.
