taguilo
Jet Engine Start Attempt On Running Engine
Tue Apr 11, 2006 8:06 am
Hi,
I would like to know what would happen on this hypothetical scenario:
(757/67 but I guess is the same for other a/c)
Eng(n) is running at idle or with power. Eng(n) starter switch rotated to GND.
Case 1:
ECU make switch cuts immediately to AUTO, Eng(n) bleed valves are not commanded to close, start valve NEVER opens and APU bleed valve is kept in the current position.
Case 2:
Start valve opens, Eng(n) bleed valves are commanded closed, APU bleed valve, if APU on, is commanded open. As Eng N2/N3 RPM are greater than 50 %, Start switch cuts to AUTO, Start valve closes, Eng and APU bleed valves perform the same as in a normal start.
Case 3:
A mix of Case 1 and Case 2...
Many Thanks
Tom
kaddyuk
RE: Jet Engine Start Attempt On Running Engine
Tue Apr 11, 2006 8:11 am
My Guess is that the ECU is smart enough to realise that the engine is already running and will do nothing but possibly flag a warning message on EICAS (as you refered to the '57).
Perhaps case 1 is the more likely scenario.
I'm also pretty sure that above a certain speed the start motor is physically disconnected from the gearbox and so even if the start valve did open, it would not affect the running of the engine.
dc10hound
Tue Apr 11, 2006 11:10 am
My first thought is why would you want to even do this.
It's sort of like putting your car in reverse a 60 MPH to see what happens...
 Wink
Case 1:
You'll never get the start switch to latch in the GND position.
Once the engine is running at greater than 47% N1, the ground in the DGCU(Dedicated Generator Control Unit) is removed from the latching coil in the start switch. There are enough time delays in the pneumatic valve circuits to keep any of them from closing or opening.
Now if you hold the switch in the GND position, some of the events in Case 2 will occur.
You will also get a Level B STARTER CUTOUT message from EICAS, a VALVE light on the start panel and I would imagine a ruined starter...
"Eagles soar. But weasels never get sucked into jet intakes.."
taguilo
Tue Apr 11, 2006 12:43 pm
Quoting Dc10hound (Reply 2):
Actually I won't, but probably some people that are going to fly my panel eventually will   That's the reason I need to know what I should code to resemble the real stuff as much as possible.
You know, I had a hunch it would be the way you describe, so I programmed a small latch time once switch is rotated to GND and released, after half a second it returns back to auto, firing the typical "clack" sound when reaching the AUTO position. Now I have to program the "hold in GND position" case
Tough work!
Many thanks,
Tom
[Edited 2006-04-11 05:45:29]
777wt
Tue Apr 11, 2006 12:51 pm
Been there, done that in a rental Chevy Colorando pickup truck, had it for a month.
I was excepting to hear gears or clutches grind or see a trail of transmission parts in my rearview mirror, but none of that happened. I shift into reverse and you feel a light braking action, the engine is still doing a high idle at highway speed (1,500 rpm) and adding throttle makes it slow down!
Sometimes I would go into a nearly empty parking lot, shift into reverse and gas it up til it stops then I jam it in park  Wink I like to call this "thrust reverser" Big grin
It was still running when I returned it  Wink
kaddyuk
Tue Apr 11, 2006 9:35 pm
Quoting 777WT (Reply 4):
Abeit it had to be carried into the lot on a pick-up because it had become jammed into park...
Haha!
VC-10
Wed Apr 12, 2006 2:09 am
B757 (RB211)
The Eng Start Sw is held in the GRND position by a holding relay. The relay releases the Sw back to Auto when the Dedicated Generator Unit senses N3 speed >43%.
So th senarios you cite cannot happen, the Start Sw will not hold in GRND.
Users browsing this forum: fr8mech, speedbored, Yahoo [Bot] and 2 guests
