joffie
757 / 767 Speedbrake Safety?
Thu Apr 13, 2006 9:02 am
After watching the documentary on the American Airlines 757 which crashed into the mountains in Cali after the crew became confused, it was noted that one of the main causes of the crash was the First officer raising the speedbrakes, but forgetting to stow, or put them down.
My understanding is, airbus planes if the thrust is put to maximum, the speedbrake will automatically lower to prevent drag. On the 757 / 767 and possibly other boeing planes how come this does not happen? Wouldn't it be alot safer if the speedbrakes would lower if max thrust was applied?
I know there are hundreds of safe flights each day, and this is an extremly rare occurance.
thanks
2H4
RE: 757 / 767 Speedbrake Safety?
Thu Apr 13, 2006 9:31 am
Quoting Joffie (Thread starter):
Haven't 757s and subsequent Boeings been modified to do just that?
2H4
Intentionally Left Blank
dc10hound
Thu Apr 13, 2006 12:41 pm
Only if the aircraft is on the ground. Forty percent of travel from the idle stops will cause the ground spoilers to reteract. It's part of the function of GA.
All AAL B757s came from the factory that way.
"Eagles soar. But weasels never get sucked into jet intakes.."
onetogo
Thu Apr 13, 2006 1:42 pm
This is a rather bold statement, especially considering the NTSB concluded that the plane would have impacted terrain regardless of whether the speedbrakes were extended or stowed. Recommend you read the full narrative report sir.
Thu Apr 13, 2006 6:14 pm
LINK
regds
MEL
schooner
Thu Apr 13, 2006 7:29 pm
SOP in my airline is to keep a hand on the speedbrakes whenever they are deployed in flight, the thinking being you are less likely to inadvertantly leave them up if your hand is resting on them!
Cheers.
Untouched and Alive
YYZYYT
Fri Apr 14, 2006 1:27 am
Quoting Onetogo (Reply 3):
hmm. I thought I remembered otherwise, so I re-read a portion of the NTSB report:
see bottom of p 50:
"Results of an initial study of the performance of AA965 following the GPWS warning indicates that if the flightcrew had retracted the speedbrakes second after initiating the escape maneuver, the airplane could have been climbing through a position that was 150 feet above the initial impact point. Therefore, because the airplane would have continued to climb and had the potential to increase its rate of climb, it may well have cleared the trees at the top of the ridge. The study also showed that if the speedbrakes had been retracted upon initiation of the escape maneuver and if the pitch attitude had been varied to perfectly maintain the stickshaker activation angle [35] the airplane could have been climbing through a position that was 300 feet above the initial impact point."
Though, Onetogo is not entirely wrong - the failure to retract the speedbrake was not listed as a cause at all, but rahter only as one of the contributing factors: see section 3.3, this is shown as a contributing factor:
"2. The flightcrew's execution of the GPWS escape maneuver while the speedbrakes remained deployed."
Interesting analysis of the issue, needless to say. Here is a link to the report:
http://www.rvs.uni-bielefeld.de/publ...s/DOCS/ComAndRep/Cali/calirep.html
[Edited 2006-04-13 18:29:01]
YYZYYT
Fri Apr 14, 2006 1:29 am
Quoting Schooner (Reply 5):
report notes as well that Boeing recommends exactly this, but that AA did not include this in its own pilot manuals...
DH106
Fri Apr 14, 2006 1:42 am
Quoting YYZYYT (Reply 6):
Think I disagree - Onetogo seems to say the report implies impact was inevitable regardless of speedbrake position. The report says "it may well have cleared the trees at the top of the ridge" - although the report doesn't commit itself positivley, and the gist is that timely speedbrake retraction and rapid optimum escape maneuver was required, the report certainly doesn't imply impact was ineviable.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
YYZYYT
Fri Apr 14, 2006 2:00 am
Quoting DH106 (Reply 8):
Think I disagree
I know that - I was referring to Onetogo's challenge to this characterization...
My point was simply that the truth (as usual) lies somewhere between the two...
And btw, I'm not taking a run at Joffie either... no matter how good these shows are they have to edit the content of hte NTSB report to make it interesting for the average viewer, and to fit the episode into 50 minutes...
Fri Apr 14, 2006 5:56 am
For every person who sees this as an extra safety feature, you will find another person who thinks it is removing "authority" from the pilot.
In the end, if you don't follow procedure, you're doing something wrong and potentially dangerous, regardless of whether there is an extra safety net.
joffie
Sat Apr 29, 2006 4:20 pm
Some very information there.
I will sure check the official accident report shortly.
I have also read it is policy to keep your hand on the speedbrake lever when you are using them to slow down in some airlines.
If this is an AA policy, the policy was not followed.
Users browsing this forum: AT72 and 1 guest
