Oykie
Quieting The MD-80
Thu Apr 13, 2006 7:06 pm
Aviation Fleet Systems (AFS) and Pratt & Whitney have joined forces to get noise reduced on their JT8D-200 powered MD-80 named QuietEagle. This system has recently been certified by the FAA and meets Stage 4 and ICAO Chapter 4 noise standard requirements.
Noise levels are reduced by as much as 6dB and first units will be delivered in May.
According to the company, European operator's could save up to 2400 euros (2930$) pr trip versus operating a new-generation aircraft of similar size.
My question is the following: Does this system reduce the fuel consumption so it will increase the range and enhance the operating efficiency or is the only benefit that the plane gets the noise reduced?
Does this MD-80 use less fuel pr hour than a 737NG or A320, or is it just short European flights?
Any thoughts and comments are appreciated.
Dream no small dream; it lacks magic. Dream large, then go make that dream real - Donald Douglas
CHRISBA777ER
RE: Quieting The MD-80
Thu Apr 13, 2006 7:24 pm
I read somewhere AA are looking at a combined winglet/re-engine package for their mad dogs.
Cant remember if it was a IAE V2500 or the Rolls on the 717, or if it was a CFM56 though.
What do you mean you dont have any bourbon? Do you know how far it is to Houston? What kind of airline is this???
TheSonntag
Thu Apr 13, 2006 7:31 pm
Reducing noise by 6db is a lot. I wonde how they will do that. I would doubt that this system reduces the fuel consumption, though, because in that case, I would guess this would have been done much earlier. Most likely the contrary is true, other hush kits also tend to increase the fuel consumption.
IL76
Thu Apr 13, 2006 8:52 pm
Quoting OyKIE (Thread starter):
Probably has nothing to do with fuelburn...
Instead of investing in a new aircraft, with this hushkit you can continue flying the MD80, even in noise-resticted airports. Landing fees are also lower for quieter airplanes (in AMS for example).
tavong
Thu Apr 13, 2006 9:43 pm
Quoting IL76 (Reply 3):
Agreed also the lease costs are much smaller in MD-80s than in newer planes (See NW and the DC-9s)
Gus
SKBO
Just put me on any modern airliner and i will be happy, give me more star alliance miles and i will be a lot happier.
Oykie
Fri Apr 14, 2006 4:26 am
Thanks for the answers everyone!
Quoting CHRISBA777ER (Reply 1):
I wonder if they have figured out the cost of acquisition is higher than the benefit. I guess the future oil barrel prize will determine that. Both PW6000 and RR-715 has been talked about here on A.net.
Quoting TheSonntag (Reply 2):
Reducing noise by 6db is a lot. I Wonder how they will do that. I would doubt that this system reduces the fuel consumption, though, because in that case, I would guess this would have been done much earlier. Most likely the contrary is true, other hush kits also tend to increase the fuel consumption.
According to the article it says the installation includes a front fan case, a 16-lobe mixer, a muffler and tabbed nozzle.
Not sure what all this means, but I hope it makes sense to you TheSonntag  Smile
N911ME
Mon Apr 17, 2006 11:38 pm
I'd like to see some BR715s on an MD-80. I don't know if this is common in the industry (though it has little, if anything, to do with noise abatement), but YX sometimes intermixes JT8D-217s and JT8D-219s on their MD-80s (I believe the MD-88s mainly) if they need an engine change and a replacement 217 is not available.
They have SOPs that govern the operation of aircraft with the mixed powerplants due to the 219's increased thrust capability - pretty cool stuff.
access-air
Tue Apr 18, 2006 2:36 am
The simplest solution is to re-engine the MD-80s with the engines that are on the MD-90......Then you would have an istant Stage 4 aircraft. The only problem is that with some of the more stringent European rules, Hushkitted Aircraft are less likely to be welcomed even tho they meet noise regulations. Example: Europeans were not willing to accept a Stage 2 hushkitted plane to Stage 3 standards fly, altho they ended up letting them fly anyway. I say as long as the plane is airworthy and can do the job who the heck cares how much noise it makes. Had it not been for the stupid noise regulations there would be an active and very productive fleet of BAC One Elevens still plying the skies in Europe. Now they all sit rotting away in Africa...
Oh well, thats just how I feel about it.
Access-Air
Remember, Wherever you go, there you are!!!!
Oykie
Wed Apr 19, 2006 6:33 am
Quoting Access-Air (Reply 7):
Wouldn't that make the MD-80 the heavy in the rear? The MD-90 has a stretch in order to compensate for the weight of the V2500 engines.
pilotpip
Wed Apr 19, 2006 2:37 pm
Quoting N911ME (Reply 6):
They are already the same engines. From what I understand it's a matter of turning a couple screws and changing the data plate.
DMI
N911ME
Mon Apr 24, 2006 9:26 pm
Quoting Pilotpip (Reply 9):
They're not the SAME engines. I stand corrected, but the -217C is identical to the -219 except for its -217A ratings and operating limits. It also has a nearly 1,000 lb. thrust difference.
jeb94
Tue May 09, 2006 4:01 pm
When intermixed the -219 is trimmed to the -217 ratings so you loose power. YX did it with the -7s and -9s of the DC9s as well. You loose performance this way. The 88s take a significant performance hit when this is done. This is done exclusively to get the airplane in the air when the proper engine isn't available and must be changed out as soon as possible based on flight schedules and availability of a suitable engine.
