lenbrazil
What Is The Range Of A Plane Radio?
Tue Apr 18, 2006 2:49 am
What is the range of a plane radio broadcasting on a CTAF/Unicom frequency?
More specifically would it be possible for a transmission from a King Air at 1800 ft / 440 AGL be picked up at an airport (Sky Harbor) at 610 ft 45 – 50 miles away? It may have been snowing at the time.
Len
luisca
RE: What Is The Range Of A Plane Radio?
Tue Apr 18, 2006 2:56 am
It depends on several things, like the conditions of the atmosphere and the altitude of the plane, also the power of the transmitting radio is important.
Quoting Lenbrazil (Thread starter):
More specifically would it be possible for a transmission from a King Air at 1800 ft / 440 AGL be picked up at an airport (Sky Harbor) at 610 ft 45 -- 50 miles away? It may have been snowing at the time.
It is entirely possible.
A good rule of thumb is that the transmitter is line of sight with the receiver you can hear it. I have listened to MLB ATIS from 60 miles away.
If it ain't Boeing (or Embraer ;-)) I ain't Going!
MD11Engineer
Tue Apr 18, 2006 2:57 am
If it is VHF, then it is a direct line towards the electrical horizon (a little bit more than the optical horizon due to different difraction of EM waves at this frequency). So the range depends largely on altitude (up to 2-300 km).
HF (shortwave) transmissions can propogate due to two means:
Ground waves, were the signal follows the shape of earth with increasing loss until it peters out (disappears in the static background noise). This range is usually (depending on the antenna and transmission power) a few hundred kilometers.
Air waves: Depending on the frequency and time of day (solar activity) HF waves can be reflected at the ionosphere layers of the upper atmosphere. They can even (provided the angle of radiation at the transmitting antenna is low) bounce back and forth between the ionosphere and ground, so that HF waves can have a range from between 1000 km and global range.
Jan
[Edited 2006-04-17 19:57:50]
Dtw757
Tue Apr 18, 2006 3:08 am
Oh I would think you should be able to hear an airplane using the CTAF 50 miles away with no problem at all. At my local airport KDUH we use a CTAF and I have heard calls being made from as far as 100nm while I was at pattern altitude.
721,2,732,3,4,5,G,8,9,741,2,3,4,752,3,762,3,4,772,3,788,D93,5,M80,D10,M11,L10,100,AB6,319,20,21,332,3,346,388,146,CR2,7,
lenbrazil
Tue Apr 18, 2006 4:38 am
Most of you seem to be saying it's possible, how probable is it (definate, probable, possible)? Remember I'm asking about plane to airport not plane to plane. For those of you familiar with Northern Minn the plane in question would have been a few miles east of Eveleth the nearest airport with the same CTAF is Sky Harbor just SE of Duluth.
Len
JetCaptain
Tue Apr 18, 2006 4:57 am
Theoretical VHF reception range (nautical miles) is equal to 1.23 times the square root of the altitude (above the receiver). I presume you mean the aircraft was at 1800 feet above sea level ?
Then 1800 - 610 = 1190 feet above Sky Harbor
Reception range equals = 1.23 times (SQR 1190) = 42 nautical miles (48 statute miles).
JC
[Edited 2006-04-17 21:59:09]
[Edited 2006-04-17 21:59:55]
timz
Tue Apr 18, 2006 5:05 am
By "theoretical" you mean "assuming the earth is a sphere"-- right? In this case the aircraft was 440 AGL so we can't be sure the terrain between it and the airport would allow a line of sight. But presumably the airport antenna is not at ground level, and its height adds a few miles too.
jspitfire
Tue Apr 18, 2006 5:14 am
Quoting JetCaptain (Reply 5):
JC
I was just trying to post this exact reply, but the tread was moved here from the Civ Av forum, so you beat me to it. Just one small correction, however, it was actually recently changed to 1.25 instead of 1.23, not that it makes too much of a difference.
Jason
lenbrazil
Tue Apr 18, 2006 5:15 am
So 42 nautical miles is a best case senario? according to airnav.com it's 46.1 nautical miles so it would have been just out of range? They also say it's 37.1 from DLH to EVM the plane had been talking to Duluth ATC were they going out of range?
timz
Tue Apr 18, 2006 5:24 am
No, nobody knows whether there actually was a line of sight in this case, since nobody knows about the terrain between. Could be a bit better, could be a bit worse. And in any case you have to apply the formula twice, once for the aircraft and once for the ground antenna height.
JetCaptain
Tue Apr 18, 2006 8:50 am
>> So 42 nautical miles is a best case senario? <<
Not necessarily, but under normal conditions with typical equipment it should be close. How high was the receiving antenna ? A good exterior antenna 30 feet above the gound would add about 7 nautical miles to the reception range.
JC
lenbrazil
Tue Apr 18, 2006 9:49 am
Sorry if I’m being a bit dense but wouldn’t increasing the height of the transmitter reduce the range? Let’s suppose it’s 30 feet off the ground that would place it at 640 ft. ASL so it would be 1800 – 640 = 1160 Sq. root = 34 x 1.25 = 42.5 (or x 1.23 = 41.8).
But let’s suppose the receiving antenna did add about 7 miles the maximum would be 49 miles but could be less.
If the plane was 44 – 46 miles from Sky Harbor people at that airport might have its transmissions but then again might not depending on terrain weather and other factors correct?
I have no idea what kind of antenna the have there, other than getting in touch with them how could I find out?
Len
JetCaptain
Tue Apr 18, 2006 1:29 pm
>> Sorry if I’m being a bit dense but wouldn’t increasing the height of the transmitter reduce the range? <<
No it increases it. You need to consider the reception range at each location, then add them together.
range = (1.23 times (SQR 1190)) + (1.23 (SQR 30))
which is the same thing as saying 1.23 times (SQR 1220)
Terrain could be a factor, but in this case there doesn't appear to be any that would impact the line of sight between EVM (elevation 1378') and DYT (elevation 610').
So I'd say it "could" have been theoretically possible if they had a good antenna and radio at DYT, but the signal would probably have been weak, and the squelch would have had to be turned down or off on their radio.
So what exactly are you getting at anyway ? I'm guessing something to do with this ?
http://www.ntsb.gov/publictn/2003/AAR0303.htm
JC
Mir
Tue Apr 18, 2006 4:24 pm
Sky Harbor is a little airport with a little FBO that caters to small GA planes. At bigger FBOs that serve the more corporate crowd, each FBO may have its own radio frequency that pilots can call in on to tell them that Mr. Executive will be arriving in thirty minutes, so have the Mercedes waiting and make sure the air conditioning is set to 72 degrees. You're not going to find that at DYT - there will be a little radio in the FBO, and people will listen to it if they're in earshot, but more often than not they'll be out working on something else on the airport - it's small enough that they can pause what they're doing and help out if they see someone taxiing in. According to Airnav, DYT only gets 38 operations per day on average, so whoever works at the FBO probably has a lot of free time on their hands. I'd put money on DYT having no fancy reciever, and I'd also put money on them not hearing the transmissions that you refer to.
-Mir
Pihero
Tue Apr 18, 2006 6:33 pm
Come on, guys !
The initial formula was wrongly used : 1.23 x SQRT (A) gives a rough estimate of the line-of-sight distance [i.e]the distance to the apparent horizon[/b]. and that's the effective transmission/reception range of any given station antenna
Now, another station is bound to the same earth curvature limitations, governed by the same formula.
That means that you'll have to add-up the two ranges in order to find the maximum distance at which the two stations could talk to each other
In the initial problem, D max = 1.23 x SQRT (1800) + 1.23 x SQRT (610),
or 1.23 x [SQRT (1800) + SQRT (610) ]
so, 1.23 x [42 + 25 ]---->1.23 x 67 = 82.4Nm
Quoting JetCaptain (Reply 12):
That must be a typo...Right ?
Contrail designer
JetCaptain
Tue Apr 18, 2006 10:24 pm
No it wasn't.
This is wrong because 1800 feet is the altitude of the aircraft above SEA LEVEL, you need to use the altitude above GROUND LEVEL. And 610 feet is the elevation of the DYT airport, where above ground level would be 0.
In this case the reception range from the aircraft will vary depending on the direction because the ground is not level in this area. The ground rises as you go from south to north. The elevation of DYT is 610 feet while the elevation of EVM is 1378 feet. However it is a fairly constant rise and would not impact the field of view from an aircraft that is 422 feet above EVM (1800 feet ASL).
To get the reception range to the south in the direction of DYT you need to consider the relative altitude between the aircraft and ground in that direction. ie: 1800 - 610 = 1190 feet above GROUND LEVEL. The 42 nautical miles in the first example would be correct looking from the aircraft towards DYT to the south (if the receiving antenna is at ground level).
Yes that was a typo.
I would agree that this is probably the more "practical" answer. In my experience little FBO's don't have the greatest radio setup and would have the squelch turned up to block out weak signals. But with good equipment and the squelch turned off I'd say it could be possible.
JC
KELPkid
Wed Apr 19, 2006 12:34 am
Don't forget, too, that a King Air is most likely to have "big" airplane radios that run off the 400 Hz AC bus, and are more powerful (i.e. the radio has a higher output wattage) than your typical GA aircraft radio...
 stirthepot
JetCaptain
Wed Apr 19, 2006 12:54 am
Yeah but on the other hand in this particular case the antennas were probably iced up and the aircraft was out of control in a 90 degree bank with the antennas possibly pointed away from DYT.
JC
[Edited 2006-04-18 17:57:03]
SlamClick
Wed Apr 19, 2006 1:46 am
Quoting Jspitfire (Reply 7):
The geometry has not changed. Probably someone started teaching 1.25 instead of 1.23 because anyone can do the 'one and a quarter' math in their head.
My nephew is a container ship captain and he says maritime use is 1.17 X the square root of your height above the sea. Perhaps that accounts for the bending of light by the increased water vapor in the air just above the sea, I don't know.
The 1.23 is probably not going to work for PHX though, as there are mountains in every direction within the distance he stated.
JetCaptain
Wed Apr 19, 2006 1:55 am
The last time I checked the earth hasn't changed shape, so the 1.23 factor hasn't changed. He's not talking about the Sky Harbor in Phoenix, he's talking about Sky Harbor, KDYT, in Minnesota (near Duluth).
JC
SlamClick
Wed Apr 19, 2006 3:04 am
Quoting JetCaptain (Reply 19):
Well, my mistake. (that's why they call this forum "tech/oops"
I agree. 1.23 is the proper constant for the formula. I just meant that in mountainous terrain it might not be reasonable to expect the full service volume on radio reception.
Pihero
Wed Apr 19, 2006 4:43 am
JetCaptain,
The formula used is just theoretical.
It takes into account the altitudes -MSL - of both the transmitter and the receiver.Obstacles do not come in it, and neither does the terrain slope. That's for local conditions only.
Earth curvature line-of-sight has MSL as level zero. Just imagine you're standing on the shore, watching the ships roll in and a friend of yours is in the near-by light tower.There is a yellow rubber dinghy on the horizon, coming towards you.Who is going to see it first :You or your friend ?
Now if that dinghy has a mast, how much farther will you be able to see it before you spot the dinghy underneath ?
That's what the maths say, and nothing else.
If I take your understanding of the formula further,an aircraft flying at Mt Everest altitude will never receive a transmitter held by an alpinist who's just made the top, right ? (because the "height" of the aircraft would be zero).
First you reinvent Mathematics, then you come out with a flat earth theory...
Well done, sir!
Contrail designer
lenbrazil
Wed Apr 19, 2006 5:18 am
http://www.ntsb.gov/publictn/2003/AA...3.htm
Yes, this is regarding the Wellstone crash.
Conspiracy theorists esp. the author of a book called "American Assassination" make much of the lack of a distress call.
As a layman it seems to me and to pilots on this and other forums that an SOS call would have been unlikely, the pilots who had only flow together 4 times and had no CRM would have been unlikely to have made one trying to save the plane first and a drop from 440 ft. AGL after a stall at 76 KCAS wouldn't give them much time.
Later it occured to me that even IF one of the pilots had made a distress call it's unlikely anyone would have heard it. They were on the EVM CTAF frequency and the only person at EVM went outside to 'do some chores'. The closest airport that uses the same frequency is Sky Harbor so I wondered if it was possible that the call would have been picked up there. That from what I gather here is theoretically possible but unlikely.
Other factors to consider is that the plane would have been about 135 degrees behind the plane and it was heading towards the ground at (approx) 26 degrees. I said the plane was at 1800 ft. ASL but that was before the plane stalled, if the call presumably would have been made only after stall so the altitude probably would has been less.
I imagine line of sight could have been a problem. The plane was only about 440 feet AGL and 1300 feet above Sky Harbor and about 269170 feet (44.3 nautical miles) away. Unless the terrain suddenly dropped off near Eveleth chance that the LOS would have been blocked is quite high.
One more question (OK 2) doesn't the FAA or FCC space airports that use the same frequency so that one won't pick up broadcasts intended for the other*? If not for example wouldn't a plane clicking on the lights at one turn on the lights at another as well?
*If there is a rule regulating this please let me know.
JetCaptain
Wed Apr 19, 2006 6:00 am
Pihero,
Your boat on the ocean logic doesn't work here because RADIO WAVES CAN NOT PASS THROUGH THE GROUND, airplanes are flying over the GROUND here, not the OCEAN, therefore you have to take this GROUND into account, and use the height above GROUND and not above sea level as a reference. Again 42 nautical miles from my first example is correct. Your answer that the reception range is 82 nautical miles is ridiculous.
In the Everest example the maximum reception distance between an aircraft at say FL350 and an Alpinist at the top at 29,000 feet would be about 410 nautical miles. I don't know what you are talking about when you say I think it would be zero !?
JC
Pihero
Wed Apr 19, 2006 6:20 am
What do you make of this statement then ?
Quoting JetCaptain (Reply 15):
You converted the airplane altitude - 1800 ft - into a height over the airfield - 610 ft-. and you come out with height = 1190 ft, which is correct, value upon which you base your computation,
Or am I seeing things ?
Therefore, following this kind of logic, an airplane at 29,000 ft is at 0 ft AGL, relative to Mt Everest ---> 1.23 x SQRT (0) = 0 Nm.
Quoting JetCaptain (Reply 23):
And as I'm only human, neither does my vision.
Contrail designer
JetCaptain
Wed Apr 19, 2006 7:05 am
This is correct, but only for the area behind the mountain below 29,000 feet, this area is blocked by the mountain therefore reception range is equal to 0. Are we on the same page now ?
JC
JetCaptain
Wed Apr 19, 2006 7:17 am
Lenbrazil,
It sounds like you have a pretty good handle on the reception issue.
I don't know what distances the FAA uses when pilot controlled lighting is involved ? On the eastern seaboard there are a lot of smaller airports were the CTAF frequencies overlap. But it's been awhile since I've flown around in small aircraft, so I'm not the expert. A couple of times on a nice clear summer weekend afternoon flying over the northeast US at FL410 I've tuned up 122.800 to hear what it sounded like. Talk about a busy frequency from that altitude, I was probably listening to almost a 100 airports at once.
JC
[Edited 2006-04-19 00:27:48]
Mir
Wed Apr 19, 2006 8:19 am
Quoting Lenbrazil (Reply 22):
Airports certainly can (and do) share CTAF frequencies. In fact, it's good policy not to click on the airport lights from too high up, as you'll turn on the lights at surrounding airports. You'll hear planes at other airports all the time when on a CTAF frequency, which is why starting and ending your radio calls with the airport you're at is so critical.
I think the reason the FAA doesn't try to set up CTAF frequencies so that they are exclusive to one airport in the area is that while it may help those on the ground, those in the air will be able to hear a much wider range, and thus it isn't really practical unless they want to seriously increase the number of CTAF frequencies.
-Mir
timz
Wed Apr 19, 2006 8:32 am
Assuming no refraction, the actual figure would be between 1.22 and 1.23, so presumably they decided to allow for some refraction.
Quoting SlamClick (Reply 18):
That's nautical miles, right? The 1.23/1.25 is statute miles.
timz
Wed Apr 19, 2006 9:34 am
Assuming no refraction, and assuming the WGS84 spheroid, the figure for statute miles is between 1.22 and 1.23, depending on where you are on the spheroid.
JetCaptain
Wed Apr 19, 2006 9:39 pm
Yes, except it is NAUTICAL miles.
JC
SlamClick
Wed Apr 19, 2006 11:47 pm
Okay, here's how you really do it.
1. Find the distance, in feet, from the center of the earth to the radio transmitter site. Multiply this distance by itself. This is called A-Square.
2. Find the distance from the center of the earth to your airplane. Multiply it by itself. This is called C-Square.
3. Subtract A-Square from C-Square. The result of this is called B-Square. The square root of this is the distance, in feet, at which you could expect to receive the radio station. It corresponds to a tangent across the surface of a spherical earth from your height above it.
If you are closer to the center of the earth than the transmitter site it may complicate the arithmetic somewhat. On the other hand if you are flying lower than the radio site, perhaps math is not your biggest problem at the moment.
I'd advise a quick peek out the window to resolve that last matter.
timz
Thu Apr 20, 2006 10:13 am
Quoting JetCaptain (Reply 30):
So now you know not to trust your source. You can do the Pythagoras for yourself and confirm that 1.22-1.23 is the range for 5280-foot miles. Assuming no refraction, that is.
bhill
Thu Apr 20, 2006 12:31 pm
Lenbrazil..I dont' mean to digess from your original question regarding commonly used freqencies, but with all of the "smarts" being built into airplanes nowadays...why not just use all of the other aircraft "zipping" around the Earth 24 hours a day to pass radio traffic as relays? I remember a discussion with Boeing folks complaining about "free flight". i.e let the airplanes computers "talk" to each other about seperation, altitude; for traffic management..at cruise, mind you for better flow control...
Carpe Pices
JetCaptain
Thu Apr 20, 2006 9:21 pm
Hmmmmm. Every source I've ever seen has used .....
1.23 for nautical miles
1.41 for statute miles
2.28 for kilometers
As just one example, the website below is using 1.23 for NAUTICAL miles:
http://www.naval.com/sight/index.htm
Have they all been wrong !? Now I'm confused ? Can some mathematician type explain just what factor/units are really correct, in plain language, so someone dumb (lazy) like me can understand ?
I've tested it while flying numerous times (receiving the ATIS) and the 1.23 factor using nautical miles has always been very accurate.
JC
[Edited 2006-04-20 14:24:26]
timz
Fri Apr 21, 2006 12:55 am
Quoting SlamClick (Reply 31):
You can see that explanation needs work-- if transmitter height equals receiver height, reception range comes out zero.
Quoting JetCaptain (Reply 34):
2.28 for kilometers
Like I said, it's 1.22 to 1.23 for statute miles assuming no refraction. Apparently they all assume some refraction, which no doubt is sensible. It's surprising they all assume the same amount, tho. As I recall Bowditch uses 1.144 for nautical miles, and you saw that 1.17 above.
[Edited 2006-04-20 18:00:59]
bond007
Fri Apr 21, 2006 1:08 am
 scratchchin
I don't think so.
Jimbo
SlamClick
Fri Apr 21, 2006 1:21 am
Quoting Bond007 (Reply 36):
I don't think so.
Okay. What do you think?
SlamClick
Fri Apr 21, 2006 1:43 am
Here's what I mean:
The circle (1) is the earth.
The radio transmitter is on the surface at A
Your airplane receiver is at Q
The line PQ is your height above the transmitter.
The line QA which is a tangent is the line-of-sight distance from that height.
Your vertical height has been exaggerated for clarity but mostly because I didn't draw the picture.
timz
Fri Apr 21, 2006 2:53 am
Good-- a diagram. Now all you need to add is another radial line, angled downward from the center of the earth ("downward" on the diagram, not on the earth), below line OA, to the transmitter that's at some specified height above the surface, on that same tangent.
Then you've got two right triangles, O to A to receiver and O to A to transmitter. Apply Pythagoras to each triangle to get the A-to-receiver and A-to-transmitter distances.
All assuming no refraction.
David L
Fri Apr 21, 2006 2:55 am
Quoting Pihero (Reply 14):
This sounds remarkably like the way maximum radar range is calculated at sea. In that case you assume (not unreasonably) that the horizon is at sea level and there are no significant obstructions. You use the transmitter's height above sea level to calculate the distance to the horizon and you do the same for the receiver. Add those two distances together and you get the maximum transmitter to receiver range. This, of course assumes that the transmitter's signal is strong enough to be detected by the receiver (a separate issue).
Quoting SlamClick (Reply 38):
SlamClick, it looks to me that the QA line represents the aircraft's line of sight distance to the horizon (definitely a "tangent" issue). If you continue the QA line down into the lower, right quadrant you can place the receiver anywhere on that part of the line at, say, point B. Thus, QA gives you the aircraft to horizon distance and AB gives you the receiver to horizon distance. Add them together and that gives you the theoretical maximum range between transmitter and receiver, ignoring refraction and Mount Everest getting in the way.
Is this what we're talking about? I'm going to feel so dejected if it isn't.
SlamClick
Fri Apr 21, 2006 4:25 am
Quoting David L (Reply 40):
Which I assume to be, on a smoothly rounded earth to be the same line-of-sight we use for radio reception.
Man I hope so! Hey! Maybe if I'd been able to cut-and-paste I'd have done better in geometry.
Quoting Timz (Reply 39):
We had a great discussion of exactly that point once, on the flight deck, while motoring northeast over Twin Falls Idaho. We could see a distant mountain peak in the sunset. We both agreed it was Mount Hood, near Portland Oregon. Somewhere near 400 nautical miles away but with our altitude and the mountain's height . . .
We could not see the rest of the Cascades, not even Ranier. We also could not agree on exactly why that was. Never did the math for the somewhat greater distance. Empirically, Hood was the most distant. Don't know what the math says.
One of many reasons why I so enjoyed my flying career though.
timz
Fri Apr 21, 2006 7:36 am
That does sound unlikely, depending on where you were exactly. There are lots of 7000-9000 ft mountains, closer to you-- even if Mt Hood weren't hidden, it wouldn't stand out among the closer peaks.
David L
Fri Apr 21, 2006 5:38 pm
Quoting SlamClick (Reply 41):
But cut-and-paste in our day involved scissors and glue. I don't know about you but we weren't allowed scissors and back then we hadn't discovered what happened when you sniff glue (although it would explain a lot).
I just wasn't sure if there were two completely different things being discussed. The business about the height of the aircraft above the ground station threw me.
SlamClick
Fri Apr 21, 2006 11:11 pm
Quoting David L (Reply 43):
Yeah, it is really not precisely the height above the transmitter site but the absolute difference between airplane (receiver) altitude and the nominal elevation of the transmitter site - both referenced to sea level.
For my dispatcher students I did a module I called 'the mathematics of flight operations' and I had a two-sided 8.5 x 11 sheet of formulas. We would do problems related to flight planning both with a whizwheel and a pocket calculator until they were comfortable with both. Then they could use whichever they preferrred. I always stressed though, that even if they worked it to twenty seven decimal places the answer was nothing more than an approximation in the real world because there are so many wildcard variables out there.
David L
Sat Apr 22, 2006 12:47 am
Quoting SlamClick (Reply 44):
Calculator Syndrome! If you have to work out each decimal place yourself you tend to think about how many are relevant.  Smile
timz
Sun Apr 23, 2006 6:42 am
Supposing you were at 41000 ft at 42.5 N, 114.5 W, and assuming no refraction, you would see
Steens Mtn 181 nm in azim 274 degrees
Strawberry Mtn 214 nm in azi 302 deg
Rock Creek Butte 210 nm in azi 313 deg
Sacajawea Peak 204 nm in azi 325 deg
All of those would reach about a half-degree higher than Mt Hood, which would be 356 nm in azi 301.4 deg.
SlamClick
Sun Apr 23, 2006 7:54 am
Quoting Timz (Reply 46):
Well if I can't see Three-Fingered Jack I'm not going up there!
Users browsing this forum: Mr AirNZ, RRTrent, zaphod42 and 15 guests
