Web
What Is The 'Fin' Underneath The ERJ-145XR?
Sun Apr 23, 2006 2:41 am
I've noticed the ERJ-145XR has a 'fin' underneath the wingbox, while the -145ER & LR don't. What is it and what purpose does it serve?
Photo © Danny Fritsche - Airplanespotters
Photo © Steve Brimley
EssentialPowr
RE: What Is The 'Fin' Underneath The ERJ-145XR?
Sun Apr 23, 2006 3:32 am
In the event of a wheels up landing, it's designed to prevent the ventral tank from contacting the ground.
3MilesToWRO
Sun Apr 23, 2006 6:09 am
You mean it's supposed to carry whole airplane belly-landed? I dare to doubt. If there is a tank in this place, much better protection would be a strong but flat shield.
I'd rather think this part is some antenna. (antenna, or aerial? You know, the part for radio waves)
EssentialPowr
Sun Apr 23, 2006 6:19 am
As I said, it's a skid to protect the tank.
-The XRs do have a ventral tank in this location
-A "strong, flat shield" as you put it, would transfer damage and friction heat to the ventral tank much more severely, and faster, than a belly skid.
jamesbuk
Sun Apr 23, 2006 6:35 am
Quoting 3MilesToWRO (Reply 2):
3MilesToWRO
Dude this company would've spent millions developing this one bit, doing months of research and development also testing and this is the best possible place and shape for this part!!
Rgds --James--
P.s. Sorry if i seemed to come across arrogant i just couldnt think of another way to phrase it!!!
[Edited 2006-04-22 23:51:48]
You cant have your cake and eat it... What the hells the point in having it then!!!
3MilesToWRO
Sun Apr 23, 2006 6:52 am
Quoting EssentialPowr (Reply 3):
Well, if this is attached to some kind of "safety cage" under this tank, it can work as such a bumper. Otherwise this skid would crumble into the tank under the weight of a plane - this vision was why I doubted  Smile
citationjet
Sun Apr 23, 2006 7:06 am
Quoting 3MilesToWRO (Reply 5):
Cessna calls these skid rails. They are designed to protect the fuel tank in the event of a wheels up landing. They are not designed to crush or crumble, but rather to wear away as it scrapes along the concrete runway.
You can see the skid rails on the following Citation 525 and 750 aircraft:
Photo © Tony Marlow
Photo © Jason Knutson
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,737,738,739;741,742,743,744,747SP;752,753;762,763;772,773.
jamesbuk
That would be to large and be very unaerodynamic, The one currently made on the aircraft are probably strengthened massively to cope with the loads of a landing so not to crumble into the fuel tank.
Rgds --James--
EssentialPowr
Sun Apr 23, 2006 12:40 pm
Well, if this is attached to some kind of "safety cage" under this tank, it can work as such a bumper. Otherwise this skid would crumble into the tank under the weight of a plane - this vision was why I doubted [/quote]
Engineers are a pretty savy bunch, right?
Maybe we need to define what a skid is? Guess so...
corey07850
Sun Apr 23, 2006 1:04 pm
It looks like there's also a small vent tube or antenna attached to it as well... Can anyone confirm whether or not it has a dual purpose?
troubleshooter
Sun Apr 23, 2006 3:39 pm
Quoting Corey07850 (Reply 9):
The small "tube" is the fuel line shroud drain. It is installed on all ERJs. The same goes for the skid. The only difference is that they had to redesign it for the XR version. All ERJs have this device between the main landing gears to protect the fuselage (and the fuel tanks) in the case of a gear-up landing.
Photo © Radoslaw Idaszak (EPGD Spotters)
This job sucks!!! I love this job!!!
EMBQA
Sun Apr 23, 2006 5:36 pm
Quoting Troubleshooter (Reply 10):
Correct. All ERJ's have a belly skid plate. The standard ERJ's is much smaller and maybe 8" tall. The 145XR is about 16" tall. This, as said above is designed to support the fuselage and protect the belly tank in the event of a gear up landing. What you are seeing is also not the actual skid plate, but the areodynamic fairing for it. The actual skid plate is a very heavy 'I' beam construction. Trust me..it's stout and dosn't move. I've smacked my head into it a few times doing lower belly inspections.
troubleshooter
Tue Apr 25, 2006 10:35 am
Here´s a quote from my maintenance training notes describing the purpose and the design features of the keel ski. Unfortunately I can not upload a picture.
KEEL SKI
The keel ski is a structure installed on the outer side of the landing
gear compartment bottom, at the airplane center line.
It is a protection for the wing structure against retracted landing gear
landings.
It has a longitudinal keel machined from AL 7050-T7451 plate. A
titanium plate on the lower part of the ski permits the necessary
strength in the ground contact areas.
MD-90
Wed Apr 26, 2006 2:40 pm
There are also similiar fins that help control stall behavior.
Niki Lauda's Lear 60 is a good example, and so is the Piaggio P.180:
Photo © Mario Andreya
Photo © John Kelley
wingscrubber
Wed Apr 26, 2006 5:42 pm
Quoting MD-90 (Reply 13):
These are completely different; the belly skids serve no aerodynamic purpose, these examples you give as you state are for in-flight stability.
Resident TechOps Troll
Sun Apr 30, 2006 12:00 am
You are referring to Ventral fins.Those would be more aft.
This looks like a Keel beam skid.
regds
MEL
Web
Mon May 01, 2006 7:11 am
Thanks all for your insight. Now for another ERJ question: What are the yellow 'rakes' on the wings for?
Photo © Andrew Morrell
EMBQA
Mon May 01, 2006 7:53 am
[quote=Web,reply=16]What are the yellow 'rakes' on the wings for?
For smacking your head into and causing intense pain and bad words to come out of your mouth..
They help direct the airflow over the aileron.
Mon May 01, 2006 9:14 am
Quoting Web (Reply 16):
They are called vortilons and direct airflow as EMBQA says. The color is purely there to warn rampers. Apparently they're pretty sharp.
MD-90
Tue May 02, 2006 5:34 pm
They help maintain airflow during a stall.
Some planes absolutely have to have them, like the Berkut:
http://www.berkut13.com/inflt01.jpg
KBGRbillT
Mon May 08, 2006 7:59 am
Quoting HAWK21M (Reply 15):
Also known as strakes.
MD-90
Fri Apr 30, 2010 5:53 am
Since we're resurrecting old threads this week...wow that was quite embarrassing to completely misunderstand the question.
A342
Fri Apr 30, 2010 9:57 am
I would have guessed that those fins under the tail help to maintain directional stability in case of an engine-out situation during takeoff (remember, the XR has substantially more powerful engines than the standard version).
Exceptions confirm the rule.
flybaurlax
Fri Apr 30, 2010 6:09 pm
Quoting A342 (Reply 22):
I would think that it's too small to affect the stability in an engine out situation. It's also placed relatively close to the engines, and being so small I just can't see that really being of any help.
Boilerup! Go Purdue!
Users browsing this forum: Apprentice, kurtverbose, N415XJ and 2 guests
