musapapaya
Single Aisle Aircraft Climb Rate
Sun Apr 23, 2006 11:56 pm
I would like to post this thread, not for an A vs B war.
Can anyone tell me which of these aircrafts usually have (or able to give) the steepest take off?
Airbus 318, 319, 320 and 321
Boeing 736, 73G, 738 and 739
I always wonder as the 737-400 was famous for its overpowered engine but can anyone tell me whether you think a particular type of plane has a 'relatively' more powerful engine?
William
Lufthansa Group of Airlines
RE: Single Aisle Aircraft Climb Rate
Mon Apr 24, 2006 2:23 am
Quoting Musapapaya (Thread starter):
The one with the lightest fuel, cargo, and passenger payload, they all perform well empty, they all don't perform well when at MTOW on one engine.
I think both the 737-700, and 319 are certified for operations high altitude airports in Nepal, and for operations into Innsbruck which requires a steep takeoff performance.
I think technically the 320 series could go to a higher pitch attitude after takeoff due to the FBW, and they are generally regarded as having a higher initial climb gradient using a higher flap setting.
Ryanair737
Mon Apr 24, 2006 5:42 pm
Well from those that you have listed I would go for the Boeing 736, 73G, 738 and 739. These aircraft generally have no problems whatsoever concerning climb rate. The Airbus 318, 319 and 320 normally have no issues regarding climb rate but the A321 gives off a much shallower climb than the rest. Airbus should have certified some bigger engines on them!  Wink
Ryanair737
LAST FLIGHTS= Ryanair LPL-BGY-LPL - EI-DPS/DWV - MAY 08 // NEXT FLIGHTS= TBC
Grbld
Mon Apr 24, 2006 7:39 pm
Indeed, usually the Boeing have the edge, but on average, it comes down to which thrust rating the engine has.
For example, at my airline, the 73Gs have 24K engines (24,000 lbs of static thrust). At EasyJet, their 73Gs have 20K engines.
This make a WORLD of difference. You'd be tempted to think that our 73G's can climb better by about 20%, but it's much more than that. The climb performance is determined by how much "excess" thrust you have, meaning more thrust than required for level flight. So, if for example you need 16K to maintain speed and leve flight, then EZY's birds have 4K left and we have 8K left, giving about a 100% better climb performance. In practice, this results in us being able to cruise at higher levels, which is beneficial if you make long sectors.
rsbj
Tue Apr 25, 2006 5:42 am
How in the world does climb rate get improved by FBW?! You're kidding, right?
My 737-700W manual states at 150,000lb a climb rate of 4000fpm at SL, 2500fpm at 20,000' and 1500' at 30,000'
For a 110,000lb -700; 5700fpm at SL, 4800fpm at 10,000', 2200fpm at 30,000' and 1500fpm at 40,000.
Parameters are 280/.76, bleeds auto, ISA +5C, and of course, climb power.
The only commercial plane I know of (not including business jets) that can touch it, is the 757. In particular the models with the Rolls 42.5k thrust engines, though 757's with the Pratts are very impressive too.
I can get data for both the 757 and A320, and will post my findings here within the week. I may be able to get data on the CRJ-200 and EMB-145 too, but it may not be as timely.
If you count the KC135R (707) I fly in the Guard as a single isle, then approximately double the climb rate of a 737-700W at 150,000lb for a 160,000 lb tanker.
I fly really fast and take a lot of chances.
113312
Wed Apr 26, 2006 1:51 pm
It will always come down to the thrust to weight ratio. Not only are there different thrust ratings for different engine models, but also derating or reduced thrust used to prolong engine life. Different operators are authorized different procedures for determining reduced thrust for takeoff. Actual climb performance will always be a function of actual thrust in relation to actual weight at the given conditions of temperature and pressure altitude.
If you want to see some real climbing performance, take any plane at its minimum weight, max rated thrust setting, at sea level on a cold day! You should see what a DC10-30 will do with minimum fuel, no payload, and maximum thrust! Trust me, it will outclimb a Lear!
MD-90
Wed Apr 26, 2006 2:29 pm
The MD-90 is no slouch, either.
Slcpilot
Wed Apr 26, 2006 3:40 pm
Climb rate is a very little consequence to the operators of Part 121 aircraft. It doesn't make a difference safety wise how fast an aircraft climbs.
What matters is climb angle!
That being said, all the airliners listed are operated in such a manner they climb at a sufficient angle to clear obstacles by a prescribed amount given an engine failure at the worst possible moment.
Quoting Rsbj (Reply 4):
I think the poster may have an arguement here with respect to climb angle. I suspect the procedure for avoiding terrain in an Airbus product is 1- full power 2- pull full stick aft. FBW may fly the plane at an optimum angle of attack more accurately than a human can.
SLCPilot
What follows I found on the internet (I believe everything I read there, heck, why would somebody go to the effort of typing it out if it weren't true!)...
Here is a rough reproduction of a chart from FAR 25.
Required Climb Gradient Number of Engines: 4 3 2
Flight Condition:
First Take-Off Segment 0.5% 0.3% 0.0%
Second Take-Off Segment 3.0% 2.7% 2.4%
Final Take-Off Segment 1.7% 1.5% 1.2%
Enroute Climb 1.6% 1.4% 1.1%
Approach Segment 2.7% 2.4% 2.1%
Landing Segment 3.2% 3.2% 3.2%
The flight conditions are as follows:
First Take-Off Segment is with the critical engine inoperative, take-off thrust, landing gear extended, flaps in take-off position, V = Vlo, and weight that exists at the time gear retraction is started (essentially the take-off weight).
Second Take-Off Segment is similar to first segment climb except that gear is up, V = 1.2 Vs, and the altitude is 400 feet above the ground.
Final Take-Off Segment also has one engine inoperative, but the others are operating at maximum continuous thrust rather than at take-off thrust. The altitude is that achieved when transition to enroute configuration is accomplished (flaps, slats, gear up) or 1500 feet (whichever is higher). Speed is 1.25 Vs at the weight at the end of the take-off segment.
Enroute Climb also requires one engine out, although there are requirements for two engine-out performance of 3 and 4 engine aircraft. One may choose a favorable speed, and an altitude that is sufficiently high to clear obstacles.
Approach Segment is again with one engine out and take-off thrust. Gear is up. Flaps are retracted a bit to increase stall speed by 10% above the stall speed with landing flap deflection. With this flap setting the airplane is flown at V = 1.5 Vs at the landing weight.
Landing Segment is the only case with all engines operating. Gear is extended, flaps in landing position, V = 1.3 Vs and thrust that is available 8 secs. after the throttle is moved from idle to take-off thrust position.
I don't like to be fueled by anger, I don't like to be fooled by lust...
Slcpilot
Wed Apr 26, 2006 3:46 pm
Musapapaya,
I am sorry for the long winded reply that didn't answer your question. From anecdotal evidence, the 757 is often regarded as one of the steeper climbing and more overpowered single aisle aircraft.
A person providing you the correct answer will back it up with facts and the source of their data.
Respectfully,
SLCPilot
speedracer1407
Wed Apr 26, 2006 3:52 pm
I'll hazard a guess:
FWB planes like the A320 series might be able to optimize pitch attitude better than non-FBW. So all things equal, the Boeing pilot might be forced or inclined not to ride the envelope on takeoff, whereas the Airbus pilot might be able to do so without fear of stalling.
It's also my guess that, relative wieghts and power being equal, if the Airbus can utilize its FBW to achieve greater initial climb rate, basic physics will catch up with it, and the Airbus pilot will have to reduce the rate of clime before speed deteriorates.
Just a guess based on what I've read around here; I'd like to know what Zeke thinks about it....or anyone else.
O
Jan Mogren
Wed Apr 26, 2006 4:29 pm
Quoting Zeke (Reply 1):
707 and 727 were common at Kathmandu, no problem. Are you thinking of Paro, Bhutan?
Malmö Aviation operates their BAe's there and they are no rockets.
/JM
AeroPresentation - Airline DVD's filmed in High Definition
Wed Apr 26, 2006 6:21 pm
I was answering the question, i.e. angle of climb. It is possible with the Airbus FBW to go immediately to MAX AOA (windshear recovery) and hold it to give the steepest takeoff . Hence my comments "I think technically the 320 series could go to a higher pitch attitude after takeoff due to the FBW, and they are generally regarded as having a higher initial climb gradient using a higher flap setting." which is all addressing climb gradients.
The text of the first post to me was asking about angle of climb, not rate of climb. Rate of climb means nothing in most jets as most takeoffs are derated/FLEX and dependent on weight, altitude, temperature and cost index (the lower the cost index the steeper the gradient).
The 320 series use very little runway at high flap settings, and have steep climb gradient at high flap settings. The lightest aircraft will always have a higher gradient as its capable of a lower speed.
With only a 17t payload, lots of aircraft can outperform a 737, even the 340. A lot of aircraft around that will carry more than a 737 at MTOW in fuel load alone.
Quoting SLCPilot (Reply 7):
Yes 4 engine aircraft are certified for a better gradient one engine out, however with both engines operating twins will generally have a better gradient. Takeoff data, SIDs etc are based on one engine inoperative.
Quoting SLCPilot (Reply 8):
Yes..correct.
Quoting Jan Mogren (Reply 10):
Yes Bhutan.
ATPs ? Might be slow enough to do a turn and climb out to the east.
Jan Mogren
Wed Apr 26, 2006 6:54 pm
Quoting Zeke (Reply 11):
Nah, those 5 hairdryer things  Wink
/JM
Wed Apr 26, 2006 7:32 pm
Quoting Jan Mogren (Reply 12):
No problem, 5 helicopter engines should make you go vertical  Smile
The are known for pretty good takeoff performance, hear they can get out of some very high temperature airports that other jets just cannot.
Jan Mogren
Wed Apr 26, 2006 7:56 pm
LOL, yeah, a 146 going vertical would be a nice sighting!!
/JM
cptspeaking
Thu Apr 27, 2006 12:56 am
no such thing in my book...  Wink
Your CptSpeaking
...and don't call me Shirley!!
Slcpilot
Thu Apr 27, 2006 5:08 am
Quoting CptSpeaking (Reply 15):
Overpowered - The common technical desciption of this adjective is the ability to exceed Vmo/Mmo in a vertical climb at flight idle.
SLCPilot
Thu Apr 27, 2006 7:31 am
Quoting SLCPilot (Reply 16):
Like the British Electric Lightning? Don't know if it could do that, but pilots were cautioned not to use reheat (afterburner for Americans) for take-off.
prebennorholm
Thu Apr 27, 2006 7:58 am
Quoting Starlionblue (Reply 17):
But then they got equipped with auxiliary fuel tanks all over, to stretch combat radius beyond 100 miles, and things were back to normal.  weightlifter
wing
Thu Apr 27, 2006 5:33 pm
The lower the flaps selected for take off the steepest take off you perform.The same aircraft with 1+F selected can achieve higher initial climb than flap 2 selected for take off.Same goes the 5/15 flap selection on the 737 family.
I wouldnt name it "overpowered" because it is not,but I have to tell you that -400 has the best climb rate until FL280 compared to the others listed in your question.
(ofcourse we have to take the seating configuration into account.A 737400 can be loaded with 174 passengers and full load of fuel can not achieve the same rates as it is configured with business class and 150 econ seating configuration)
[Edited 2006-04-27 10:36:34]
follow me on my facebook page" captain wing's journey log"
jetflyer
Thu Apr 27, 2006 10:43 pm
I was on an A321 which flew from Faro - Heathrow and the field performance was excellent, but the climb was really slow. It seems people say the A321 has "small" engines but actually it has a really high thrust/weight ratio, comparable to a 757, thus the good field performance.
Its climb rate suffers at altitude due to its very high wing loading for its size, just compare it to a 757's which is way lower. I guess its wings just don't "bite" through as much air as a 757s and given its weight it strugles a bit. Just a thought.
Another thing I have a video of a "Go" airlines charter Boeing 737-300 going from Lisbon - Stansted - it's a ITVV cockpit video and the initial climb rate is 4,000fpm, 3,000fpm at 20,000ft and 2,200fpm through 30,000ft. Wow.
[Edited 2006-04-27 15:44:28]
[Edited 2006-04-27 15:46:13]
Users browsing this forum: Arch89U, ClipperYankee, rjsampson and 1 guest
