wardialer
Checking The Tops?
Thu May 04, 2006 2:23 am
How and where can I check the cloud tops ove on my area? Right now its very overcast and the ceiling is about 1,800 feet overcast ABove Ground Level. So is there a site that I can check the tops?
Also, do the cloud tops are measured in Above Sea Level or Above Ground Level?
xjramper
RE: Checking The Tops?
Thu May 04, 2006 3:56 am
Usually checking the UA's will be your best bet. Where online other than DUATS, i dont know.
XJR
Look ma' no hands!
Ralgha
Thu May 04, 2006 4:04 am
I just called ATC and asked if they knew. Just don't do it all the time (if you're using a phone).
Users browsing this forum: B2468, Dt91c and 1 guest
