krisyyz
Can You Make A A330 Out Of A A340?
Sat May 06, 2006 12:51 am
I’m sorry if this has been discussed before. I have a two part question regarding the A340/A330.
I realize that the A340 was made for long-haul ops before big engines like the GE90s where developed. That is why the A340 has the 4 CFM engines at 30K thrust instead of 2 engines at 80K or so. I’m still not clear as to how 4 engines at 30-35K thrust is still enough to take the A340 into the air, when the A330 has 2 x 72K thrust and is a significantly lighter plane. Do the less powerful CFM’s create the range for the A340? Do 4 weaker engines burn less than 2 70-80K engines?
In theory, if one was to remove the engines, some fuel tanks and modified the flight deck, could a A340 frame be turned into an A330?
Thanks, KrisYYZ
SlamClick
RE: Can You Make A A330 Out Of A A340?
Sat May 06, 2006 1:12 am
Quoting KrisYYZ (Thread starter):
I would assume that the wing would have to be modified more than the 'frame' as the 330 wing has only two pylons and the 340 has four. These pylons are not just an external feature but must be carried and braced within the wing structure. Likewise, wiring and plumbing must match.
My guess would be a resounding 'maybe' but it would be cheaper to scratch-build one.
Flight deck mods should be rather easy: Unscrew and disconnect throttle quadrant, drop in new one. Same with the fuel levers just below it. Most of the rest of it should be software changes. A CRT or LCD display doesn't care if it is showing 2-engine, 4-engine or reruns of Gilligan's Island.
RichardPrice
Sat May 06, 2006 1:29 am
Quoting SlamClick (Reply 1):
Actually the A330 wings are almost identical to the A340-300 wings, and its one of the features lauded in the tanker bid - it makes additional wing mounted refueling pods very easy as no structural modifications have to be made to the wing due to the outer engine mountpoints.
The A330 also retains the central main gear bay.
I doubt it would be financially viable, but I see no reason why it couldnt be done.
Mir
Sat May 06, 2006 1:30 am
Remember that twins are always going to be overpowered compared to quads, since one engine has to be powerful enough to take the plane off the ground at MTOW at a certain rate of climb all by itself. Not the case on a quad.
So that's what they do in cruise!  biggrin
-Mir
A319XFW
Sat May 06, 2006 2:31 am
From a systems point of view:
The fuel tanks would have to be changed, as the A340 is designed for 4 engines, so has got 4 feed tanks etc, so you'd have to move tank boundaries around, change pumps, pipes, valves etc (as different rotor-burst zones) .
You'd also have to change all the wiring and hydraulics coming off the outboard engines and have it all going into the inboard one (don't exactly know the set-up of EDP's and generators on A330/A340).
For the landing gear, you'd have to remove the CLG and possibly change the pintle pins etc on the attach points (for example, the A321 LG is not interchangable with the A320 LG as the attach points are beefed up)
Interesting question you've set though!
Sat May 06, 2006 3:25 am
It has the bay, but IIRC there's a small fuel tank there on the 330.
Quoting Mir (Reply 3):
Beat me to it. Big grin
As A319XFW says, very interesting question. The aircraft can be thought of as 1.5 type in many ways since they are so very alike.
My wild guess is that it would be about as easy to go either way.
A342
Sat May 06, 2006 4:19 am
No, more fuel with a higher MTOW. On shorter flights the A333 burns less.
But if you were going to convert an A343 into an A333, you'd have to lower the MTOW because of the reason stated in reply 3. And there goes your range advantage.
As it has already been stated, maybe you could do it, but it makes no sense.
Exceptions confirm the rule.
Sat May 06, 2006 4:35 am
I realize that the A340 was made for long-haul ops before big engines like the GE90s where developed. That is why the A340 has the 4 CFM engines at 30K thrust instead of 2 engines at 80K or so. I�m still not clear as to how 4 engines at 30-35K thrust is still enough to take the A340 into the air, when the A330 has 2 x 72K thrust and is a significantly lighter plane. Do the less powerful CFM�s create the range for the A340? Do 4 weaker engines burn less than 2 70-80K engines?
As Mir was explaining, a twin needs more power because worst case engine out scenarios (on take-off) are based on one engine failing. If one engine fails on a quad, you have three left. If one fails on a twin, you have one left. So that one has to be as powerful as the three on the quad, all other things being equal (which they aren't, but anyway).
If you do the math, you will find that a twin needs 50% more total power than an "identical" quad. Consequently, each engine on a twin needs to be twice as powerful as on the "identical" quad.
krisyyz
Sat May 06, 2006 4:37 am
great info, thanks!!!
A319XFW
Sat May 06, 2006 4:43 am
Quoting Starlionblue (Reply 5):
I don't think that's the case - it's got a 'basic' centre wing tank.
texfly101
Sat May 06, 2006 6:59 am
They do have a commonality that could enable the switch to a twin. The proposed KC-30 tanker is an A330 fuselage mated to an A340 wing. The outer two pylon points are being used as hose and drogue refueling points in addition to the flying boom on the rear of the fuselage. The other switch, i.e. going from 4 to 2 engines is possible and has been proposed in a lot of different aircraft like the 707, DC8 etc. The GE90 was originally tested on a 747 and if memory serves me, there were proposals for twin engine 747 and tri engine 747 when the twin aisles big bodies were originally being designed. But usually the economics aren't there. An older fuselage design accompanied by a new wing is rarely viewed with enthusiasm. But thats just my view.
Sat May 06, 2006 8:05 am
Quoting A319XFW (Reply 9):
As per my A330/340 book. Which may be wrong. But anyway that's where I got the info.
ReidYYZ
Sat May 06, 2006 8:19 am
Correct, where the ctr gear would sit is a vast void. Blanking plates cover were the ctr gear doors fit, and above these covers is an empty space. The actual center tank is the center wing section that the wheel wells sit under.
This is how it is actually done on simulators. I had engine run sim training for A330 a few years ago, and there was a 4 engine throttle quadrant sitting in the stowage closet at the back of the sim.
Sat May 06, 2006 8:45 am
Quoting ReidYYZ (Reply 12):
I stand gladly corrected.
longhauler
Sat May 06, 2006 12:20 pm
One hour is scheduled to change one of our A340 sims to an A330, and vv. The thrust lever quadrant, and the overhead panel is changed. The rest is software.
PurdueAv2003
Sat May 06, 2006 5:39 pm
No one has mentioned one major structural difference: the pylon and wing structure. The 340 has four small pylons for the CFM engines. The 330 requires a much heavier pylon for the larger engines and only requires two. If someone were to actually try to covert a 340 to a 330, they would be better off replacing the entire wing structure than to try to remove two pylons and beef up the other two. On top of that, all of the bleed systems, controls, leading edge devices, etc, would all need to be changed. Then again, the whole idea of converting a 340 to a 330 is ridiculous, anyway.  crazy
Ptu = Ftu X Anet (not to be confused with a.net)
A342
Sun May 07, 2006 4:17 am
Quoting PurdueAv2003 (Reply 15):
Only the inner pylon needs to be beefed up I think. The reason is that the A330 outer wing has to endure higher stresses from turbulence than the A340 wing because the A340's outboard engines weight soften these stresses. In turn, there are no special structural differences other than pylon attachments.
I'm no expert on this, please feel free to correct me if I'm wrong.
ReidYYZ
Sun May 07, 2006 7:38 am
Brain fart alert: the wheel wells actually sit under cabin floor BEHIND center wing box. The forward wall of the w/w bay is actually the aft bulkhead of the center wing box, used as a ctr tank or not.
I though of this well after the fact. The pylons installed are engine specific. RR pylons are therefore entirely different in design and manufacture from the P&W and GE ones. The support points at the underside of the wing would be identical, most likely for ease of manufacture. Therefore based on this theory, the attach points would also be identical for the smaller CFM pylon attach points. (Elsewhere there is the thread about re-engining older aircraft: DC-8-70 is an example mentioned. With the new CFM engines, they are strapped to new pylons, not the JT3D pylon with mods done to it.) For the outboard pylon attach points there must be provision for the similar attach point interface on the underside of the wing. One big difference would be the L/E slats. As the O/B pylon sits between two L/E slat surfaces, the slats, at least one maybe both would be different to accommodate the cutout for the pylon upper surface as seen:
Photo © Christian Galliker
The wing structure are identical in size shape etc.... between the A332/3 and A342/3 and up to a certain point, move along the same assembly line where one becomes A34x and the other becomes A33x. That is where the internals differ. To peer inside the L/E of an A33x wing one would find brackets installed that hold nothing, but it would have been a support point for, say, pneumatic ducting for the phantom #1 or #4 engine on a A34x. I have been told in the past that the difference between to two wings, it is a two week time frame from built up to a common point to where they would each be a different wing for the type end products.
Now having said that, I would question:
Quoting Texfly101 (Reply 10):
I could be wrong in some form or another because the fuselage structure is identical. It is the internal 'guts' that differ.
Not neccessarily, due to aircraft manufacturing (A in this case) ideology, it is entirely possible. Financially viable, maybe not so much.
Sun May 07, 2006 8:20 am
Quoting ReidYYZ (Reply 17):
The fuses themselves are identical apart from number of frames, but you get the length difference within type (330 or 340) as well.
N766UA
Sun May 07, 2006 9:46 am
Yep, the wing of the KC-30 is identical to that of the A340. Airbus simply replaced the outboard engines with pods for drogue refueling hoses.
saintsman
Mon May 08, 2006 4:19 pm
On the RAF FSTA aircraft, the wing is a standard A300-200 wing so I see no reason that the KC-30 wing would be different. Externally the wings are the same but internally there are significant differences. For example, why would you need to have the outer engine strenghtening on an A330? Its additional weight that you don't need to carry.
For the pod and pylon fit, there are significant machined fittings attached to Rib 26 and a large fitting on the front spar. The wing under surface is also re-inforced towards the leading edge. Comparing this to something like the KC-10, there is considerably more strengthening required for the A330 wing.
Mon May 08, 2006 8:56 pm
Quoting Saintsman (Reply 20):
The outer engines actually relieve bending moment, so in some ways a four holer can have a weaker wing than a two holer.
texfly101
Tue May 09, 2006 6:57 am
Nope, its as I said. That's the one of the reasons why the Aussies chose the KC-30 over the 767. They felt that it was less risk for the outer two pylon points of the A340 wing to be hard plumbed for refueling points than for the KC-767 wing to be replumbed for hose and drogue points. They felt since the A340 wing already had plumbing for fuel to the outer two pylons, it would be less risk to develop a boom for the A330 fusleage. Add in the cargo capability and they chose the KC-30.
Users browsing this forum: Accidentally, Yahoo [Bot] and 17 guests
