FlyDeltaJets
Runway Numbering
Fri May 19, 2006 10:21 am
How does the grid numbering system work?
The only valid opinions are those based in facts
Cubsrule
RE: Runway Numbering
Fri May 19, 2006 10:31 am
It's easy. Take the compass heading, round to the nearest 10, and lop off a digit. Thus, a runway with a heading of 274 degrees gets rounded to 270, and the runway is 27. Of course, going the other way, the heading is 274-180 or 94 degrees, so the heading going to other way is 9. Left, right, and center (L, R, and C) are simply as you see them, so as you look down the runways, the leftmost one is L. Of course, going the other way, it's right, so if our 274 runway is the leftmost one and is 27L, then the other end is the rightmost, so its 9R.
Where there are more than 3 parallel runways, they are typically numbered in sets. All 5 runways at ATL are parallel, but the north complex is numbered 8-26, the middle 2 are 9-27, and the new runway is 10-28.
superhub
Fri May 19, 2006 11:04 am
Quoting FlyDeltaJets (Thread starter):
What do you mean by grid numbering? Do you mean simply how a number is assigned for a runway? If so, see above post.
Or do you mean earth coordinates?
timz
Fri May 19, 2006 11:15 am
Quoting Cubsrule (Reply 1):
And he means magnetic, not true (usually). And magnetic north moves over the years, so here and there runways have changed numbers.
cptspeaking
Fri May 19, 2006 11:25 am
Quoting Timz (Reply 3):
My home airport (KLHZ) where I got my private license just went from 4-22 to 5-23 this past summer while I was working there...
the FAA shut us down for like 4 days so they could patch and paint the runway
Your CptSpeaking  wave
...and don't call me Shirley!!
ANCFlyer
Fri May 19, 2006 11:50 am
Quoting CptSpeaking (Reply 4):
As did ANC . . .
6-24 is now 7-25.
comairguycvg
Fri May 19, 2006 12:36 pm
Quoting Superhub (Reply 2):
LOL!!!!
Worked at: CV62, RJTA, KNLC, CV63, KNFL, OKAJ, KTRI, CV67, KMGE, KNQX, KVPS, KPIT, KCVG, KTYS, KATL
fiaz
Fri May 19, 2006 1:03 pm
heres an easy way called the " take 2 away add 2"
a runway is numbered 23,,,Now whats the obosite of the runway numbered
well take 2 away from 2 = 0 , 3 + 2 = 5 ...there fore runway 05
samething with 33R 3 - 2 = 1 ,,, 3 + 2 = 5 .......therefore runway 15
hope that helps
ramerinianair
Fri May 19, 2006 1:24 pm
The magnetis deviation is always changing. If you had a runway that was 080 degrees with a +14 deviation, it would be 094 degrees or runway 09. If the deviation changed to +15, then the heading would be 095 or runway 10.
SR
W N = my Worst Nightmare!!!!!
FlyDeltaJets
Fri May 19, 2006 4:05 pm
Ok thanks now I have a little idea of how it works.
I got that term from the article about the new runway it ATL. It said that the runways are numbered using a "grid" system.
scoliodon
Fri May 19, 2006 4:23 pm
Yes, that's the way it works. In DFW there is a set of 18L(36R),18R(36L) and another set of 17L(35R),17C(35C),17R(35L).
As pointed out by other replies this heading is only the magnetic heading and not the true one.
JFK-LGA-EWR-DTW-IND-PHX-CLE-SFO-LAS-SEA-ORD-MCO-MIA-DFW-ATL-CDG-FRA-BOM-MAA-DEL-TRZ-DXB-CLT-CVG-DEN-MSP
alphafloor
Fri May 19, 2006 4:34 pm
Quoting Fiaz (Reply 7):
hope that helps
Interesting, didn't know this before. But this rule only works with rwys from 20 up to 36. For rwys from 01 up to 19 take you must inverse the rule 'add 2 and take 2 away', isn'it ? eg. rwy 16 add 2 to 1= 3 and take 2 to 6= 4 =>rwy 34.
Whatever
alphafloor
Fri May 19, 2006 4:36 pm
... errr.. and rwy 19 ? = rwy 37 ?????
and rwy 01 ???
[Edited 2006-05-19 09:38:15]
Whatever
Boeing747_600
Sat May 20, 2006 12:52 am
Quoting Alphafloor (Reply 11):
A much simpler (and much more logical) rule would be to add 18 if the runway number is less than or equal to 18 and subtract 18 otherwise.
18 comes from the fact that the reciprocal direction is 180 degrees from the direction of the runway number in question.
Olympus69
Sat May 20, 2006 4:37 am
Quoting Boeing747_600 (Reply 13):
This works well for normal people, but for the average A.netter a pencil and paper would be required.  Smile
