777DadandJr
777 Wake Tubulence Question
Wed May 24, 2006 4:49 am
While returning to IAD on Sunday aboard a UA 777, I was listening to channel 9. There was an RJ second in line to land behind us, and ATC warned them of the wake turbulence from the 777 in front of them.
My question is this:
How long does the wake turbulence last? Must the separation be farther in this scenario?
Thanks in advance!
Russ
My glass is neither 1/2 empty nor 1/2 full, rather, the glass itself is twice as big as it should be.
RE: 777 Wake Tubulence Question
Wed May 24, 2006 6:35 am
Quoting 777DadandJr (Thread starter):
The normal separation is about two minutes. This varies widely depending on the conditions. Wake vortices sink and dissipate slowly.
In this particular case, you have a huge disparity in size between the planes. The effect of wake turbulence (and any other kind of turbulence) is dependent on the mass of the object affected and the intensity of the turbulence. If you have a large aircraft with big wings generating lots of lift, the wake vortices will be correspondingly large. Another 777 following after it could ride it out easily since its mass can absorb the bumps (inertia is your friend), but a much lighter RJ might face serious problems.
That's one of the reasons ATC cares about the plane type. So they can adjust out the separation accordingly.
skyman
Wed May 24, 2006 8:00 am
Here is a wake turbulence seperation list from Germany:
Heavy to Light 6NM
H to Medium 5NM
H to H 4NM
M to M 3NM
M to L 3NM
L to L 3NM
Otherwise aircraft are effected when flying less than 2 min behind the aircraft at ssame level or less than 1000ft below.
IAHFLYR
Wed May 24, 2006 11:25 am
In the US here is what the controller handbook requires unless the second aircraft is on a visual approach following the preceeding:
WAKE TURBULENCE APPLICATION
e. Separate aircraft operating directly behind, or directly behind and less than 1,000 feet below, or following an aircraft conducting an instrument approach by:
NOTE-
Consider parallel runways less than 2,500 feet apart as a single runway because of the possible effects of wake turbulence.
1. Heavy behind heavy- 4 miles.
2. Large/heavy behind B757- 4 miles.
3. Small behind B757- 5 miles.
4. Small/large behind heavy - 5 miles.
f. TERMINAL. In addition to subpara e, separate an aircraft landing behind another aircraft on the same runway, or one making a touch-and-go, stop-and-go, or low approach by ensuring the following minima will exist at the time the preceding aircraft is over the landing threshold:
NOTE-
1. Small behind large- 4 miles.
2. Small behind B757- 5 miles.
3. Small behind heavy- 6 miles.
The vorticies are supposed to sink at around 1,000' per minute but most US approach controls with RADAR don't use the minutes for separation they use the mileage rule.
EssentialPowr
Wed May 24, 2006 1:24 pm
IAHFLYR knows his stuff...so my question, what 737 model causes you guys the most problems?
Cheers- formerjlincolndood...askhimhowstheracekar!
(your guys' label, our namesake!!)
skyman
Wed May 24, 2006 4:51 pm
Quoting EssentialPowr (Reply 4):
Was that question for me? If so I don`t quiet get it. In Germany approach also allmost only uses milage seperation due to the high traffic. Other things wouldn`t be practicable. So IAHFLYR must be an approach controller since he noes everything so good by heart. Or he had the handbook around. biggrin
We don`t really have big problems with the B737 but if you want to know the B737-200 allmost doesn`t fly here anymore due to the old engines. For noise abaitment rules and high fuel flow as well. Personally I like the B737-800 the best . A modern aircraft with a very good climbing performance.
IAHFLYR
Wed May 24, 2006 10:12 pm
I know nothing and can prove it....just watch your TCAS for abit!!!  Smile
.65 is always available but thanks for the kudos, and after that comment what you think you're gonna get direct REDOC or something special?
Hey he says the rackar is excellent and I will pass along a howdy to him today when I see him.
That model question for me or for SKYMAN??
Users browsing this forum: bbschraube, Horstroad and 1 guest
