darrenthe747
UAL @ NRT
Fri May 26, 2006 1:09 pm
Good evening everybody,
hope you are all well. I was just wondering when United 837 (B744) flys to BKK via NRT, it is supposed to arrive at like 14:15 into NRT and doesn't depart to BKK until 18:35. Does it get tugged over to a hardstand position or does it sit at the gate for 4 and a half hours? That seems like a long time to be idle at a gate using up valuable space. I know in FRA the IAD bird would get tugged over to a hardstand position until it took the SFO flight 5 or 6 hours later.
Darren
All animals are created equal, but some are more equal than others.
Bobster2
RE: UAL @ NRT
Fri May 26, 2006 1:30 pm
Simple explanation. There is a change of aircraft at NRT. Two different flights with the same flight number. They do that because it tricks people into thinking they're getting a direct flight on one plane. I've been fooled by this kind of situation. You have to look carefully at the fine print where it says "change of aircraft".
[Edited 2006-05-26 06:32:42]
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
darrenthe747
RE: UAL @ NRT
Fri May 26, 2006 4:14 pm
oh i didn't think of that...but what aircraft do they use then on those NRT - BKK flights? Where was its originating flight? It must have come from some US location...ORD perhaps?
jocgn
RE: UAL @ NRT
Sat Jun 03, 2006 9:00 am
Hi,
the departing a/c for UA837 to BKK seems to come from UA899 (LAX-NRT) while the 744 from UA837 (SFO-NRT) leaves NRT as UA852 to (again) SFO.
Jo
Users browsing this forum: GloomyDe, Mangs and 1 guest
