JulianUK
Tcas False Alerts Or No Action Needed Alerts?
Sun May 28, 2006 1:48 am
It is an interesting time to debate how many times TCAS indicates a resolution necessary and none was done or needed - is this a rare occurenence or a regular one? It comes on the back of Airbus thinking about allowing the autopilot to resolve the situation so first I would be interested in learning how many times TCAS is yelling at you but you don't do anything, and if so what would the circumstances be when this happens? Any examples would be great.
A3204eva
RE: Tcas False Alerts Or No Action Needed Alerts?
Sun May 28, 2006 3:21 am
Well TCAS will advise of an action when another a/c gets in close proximity to your a/c so if you're not visual with the traffic in question then it is a very good idea to follow the TCAS instruction. However, there are times when you do not need to follow TCAS, such as when on final and you are visual with the traffic and you can see that it isn't a threat.
At airports where CCT traffic are instructed to squawk mode C, the a/c's TCAS can go off quite regularly (which why a lot of airports actually instruct CCT traffic to squawk STBY)
"They have lady pilots......... they're not that good, but they have 'em"
Bobster2
Sun May 28, 2006 3:49 am
In an earlier discussion, I described an incident where two planes where flying in the same direction, one a thousand feet above the over. The autopilot on the lower plane disconnected and the plane shot up several thousand feet before the pilots got control back. The TCAS on the upper plane was telling the pilots to climb, bad advice since the other plane was climbing too, but it all happened so fast the pilots didn't have time to react, so they did nothing which turned out be the best response.
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
Pihero
Sun May 28, 2006 7:36 am
The TCAS has still a few - identified - drawbacks to be addressed by the av community :
- One is the presentation that is not obvious to some aircrews : the number of pilot actions at the opposite of a resolution is worrying.
-Two is the understanding of "Monitor vertical speed" which in general provokes an increase of the said vertical speed instead of a reduction, as the now philosophy calls.
-Three is the system ignorance of a level-off altitude : this condition happens generally wnen two aircraft in a terminal area, the one climbing being cleared to an altitude 1000 ft below the clearance altitude of the descending one.If their inside each other's trigger volume, you have an unnecessary RA. On the other hand, I prefer that solution, supposing an altitude involuntary bust is always possible. Generally, reducing the vertical speed approaching the level-off altitude allows mw to see better.
-Four is the influence of a fast military jet maneuvering in the vicinity.Quite annoying, but again, the pilot has a better SA.
All in all, I find the device very useful and a great boon to air safety. Proper and strict SOPs should deal with any hesitation.
Contrail designer
JBirdAV8r
Sun May 28, 2006 10:53 am
Quoting Bobster2 (Reply 2):
Without knowing any more of the story, it almost seems like this was a good idea to follow the RA and climb, especially if (and it sounds like it would be) the lower aircraft was also equipped with TCAS.
Putting the higher airplane in a climb would slow the convergence rate of the two airplanes. It would also allow for more reactionary time for both crews to take appropriate evasive actions (i.e. initiating a turn) which AFAIK isn't commanded by a TCAS.
If the bottom airplane was also equipped with TCAS, even better--the systems in the respective airplanes would be coordinating with each other.
rendezvous
Sun May 28, 2006 2:10 pm
Well if the above aircraft was told to descend, what do you think would be the outcome?
JBirdAV8r
Sun May 28, 2006 2:19 pm
Quoting Rendezvous (Reply 5):
Boom?
I don't understand Reply 2 either. I'd sure like to see that previous discussion.
[Edited 2006-05-28 07:20:14]
777wt
Sun May 28, 2006 2:44 pm
Speaking of TCAS.
There's an accident which occured where a DHL aircraft and a russian jet that was carrying school children back from a trip.
The russian jet was starting to dive, the TCAS in the DHL was telling them to climb.
But Switerzland ATC told the DHL to go against the TCAS and to dive, was told twice...
The end result? Russian jet was still diving, DHL dived and collied head on with the russian jet.
A while later, one father of the killed school children built a shrine near where the person working the ATC on that day and went out then killed him while he was leaving work to go home.
If the DHL followed the TCAS and disregard the ATC commands, this wouldn't have happened.
Sabenaboy
Sun May 28, 2006 3:13 pm
777WT,
You've got it wrong. It's the russian plane that disregarded his TCAS command by following ATC instructions.
http://en.wikipedia.org/wiki/Bashkirian_Airlines_Flight_2937
When you get a TCAS command (RA), You follow it promptly and correctly. PERIOD.
Sabenaboy
Sun May 28, 2006 5:33 pm
Incorrect the ONLY response is to follow the RA, even if at the max certified altitude and it says climb, you climb.
The only concern I have with TCAS is with eastern block equipment and airspace where some of the equipment does not transmit the altitude in ft, its in meters. I know over a reporting point in Yangon FIR the only way a TU154 and a 744 avoided a collision was by listing to a position report, the situational awareness that the 744 crew avoided a collision. The 744 was at 36000 ft, the TU154 at 11000m, the 744 TCAS did not go off at it was comparing 11000 ft to 36000 ft, TCAS does not transmit units of measure being used.
wing
Sun May 28, 2006 7:03 pm
A TCAS RA and a GPWS in IMC conditions are two scenerios that you react first and think about it later.
Quoting JulianUK (Thread starter):
I think you are thinking of a TA(Traffic Advisory).TCAS does not generate non necessary RA's or pilots doesnt think about the RA's as unnecessary,neither think about it.Because time is very limited in a RA situation.
I experienced a real situation of a RA and the biggest thing I remember was how slow was my airplanes escape rate ,against the speed of intruding airplane's picture getting bigger in my window.
In a traffic advisory however you have more time to locate the target visually and be prepared.And there are some cases that the entire TA is wrong.For example A traffic is climbing to FL 28O,and you are descending to FL 290 toward the same waypoint. TCAS doesnt know what is the altitude written on your FCU ALT window and you continue descent with a rate more than 1000 fpm.It will trigger you a TA even though you know that you willl be levelled with a 1000 feet seperation between each other.So there is no action necessary other than reducing the VS to less than 1000 fpm.I think this is what you are referring to.
TCAS of two airplanes talk to each other and it generates the plane in lower condition a Descent and the plane in the higher condition a Climb.The idea is to seperate airplanes from each other.
In the scenerio you described the lower airplane should have issued a Descent advisory.TCAS doesn't know if the pilots can follow the commands or not but it tels you what to do.Same for the upper airplane they should have climbed,that was the RA given.And I know it happens very fast but there is always time to react.And thats not a violent reaction either.
As a result if that encounter really happened many mistakes added up and coincidently made a correct result(which is the accident not happened) but many times this is not how it ends.
follow me on my facebook page" captain wing's journey log"
Bobster2
Mon May 29, 2006 12:34 am
Quoting JBirdAV8r (Reply 6):
Here's the official incident report:
http://www.aaib.gov.uk/cms_resources/dft_avsafety_pdf_501275.pdf
The main point is that the A340, at the lower altitude, suddenly shot up at 6000 ft/sec and the pilots never heard or saw a TCAS warning because they had higher priority issues to deal with. The A330 pilots were trailing the A340 and saw most of what happened. But they did not have time to respond to TCAS. And the TCAS had no way of knowing where the A340 was going, so TCAS ended up giving contradictory instructions to the A330, first climb, then descend.
JBirdAV8r
Mon May 29, 2006 3:47 am
Quoting Bobster2 (Reply 11):
Appears there's always more than originally meets the eye  Wink Thanks!
Bobster2
Mon May 29, 2006 5:13 am
A vertical speed of 4000 mi/hr? Better change that ft/sec to ft/min.  ashamed
CosmicCruiser
Mon May 29, 2006 5:22 am
Quoting A3204eva (Reply 1):
RA is inhibited below 1000'agl so you shouldn't get anything but a possible TA anytime on final.
rendezvous
Mon May 29, 2006 6:17 am
Yeah, at low altitudes, the displace changes from "traffic" to "TA only" (on Boeing 747-400).
But like has been said, you follow the RA unless you can visually see the other aircraft. If you can't see it, why would you want to second guess or ignore the equipment that is made to help you avoid collisions?
CosmicCruiser
Mon May 29, 2006 7:42 am
Quoting Rendezvous (Reply 15):
That's correct. For us following an RA is MANDATORY unless terrain or wx is an obstacle, for unusual stall or configuration considerations(eg. eng. out), or pilot knows of other non-TCAS a/c that must be avoided.
Bellerophon
Mon May 29, 2006 8:59 am
It appears there are some dangerous misconceptions about TCAS in this discussion.
What is really frightening is that some people think it acceptable to ignore a TCAS RA because they are visual with the traffic. You have no way of being certain that the aircraft you are looking at is the aircraft causing the warning.
Are you certain that you will always correctly identify the threat aircraft and that you will always correctly identify its flight path and how close to you it may come?
Are you willing to bet your life on that?
Ignore a RA because you correctly visually identified the traffic causing the warning and correctly decided it posed no danger and you'll still be around to tell us all just how safe your actions were.
Ignore a RA because you have visually identified the wrong traffic and missed the one actually causing the threat, and you may well not be around to admit you were wrong.
To sum up:
TCAS RA in IMC.................................................Follow the RA, tell ATC.
TCAS RA in VMC................................................Follow the RA, tell ATC.
TCAS RA in VMC, traffic in sight...........................Follow the RA, tell ATC.
TCAS RA in VMC, traffic in sight, not a danger.......Follow the RA, tell ATC.
TCAS RA, contrary to what you think best.............Follow the RA, tell ATC.
TCAS RA, contrary to ATC instructions.................Follow the RA, tell ATC.
The only time a TCAS RA should not be followed is when to do so would immediately and obviously endanger the aircraft. That's going to be a judgment call for the Captain on the day.
A TCAS RA is a serious warning, which may require immediate action. You could potentially be as little as twenty seconds or so away from a mid-air collision.
The system is not infallible, but it has already saved aircraft. It is a real benefit, especially in those remote, or poorly controlled, parts of the world.
Please, let's not start second-guessing a last ditch warning system.
Bellerophon
NW747-400
Mon May 29, 2006 11:21 am
Although it had its teething problems, TCAS has been a valuable tool and has prevented midair collisions. There are 4 typical levels of TCAS advisories, the following are specific to a CRJ:
Level 1: "other traffic" - aircraft within 40nm of the aircraft and within +/-2700 feet, depending on what setting the crew is using
Level 2: "proximate traffic" - aircraft within 6 nm and 1200'
Level 3: "traffic advisory or TA" - aircraft within 40 seconds of possible collision. A TA will not generate a conflict resolution for the pilot to follow on the CRJ; however, it will in other aircraft...the B744 offers a resolution for a TA i believe. Following a TA from the TCAS can result in the pilot being violated by ATC because it is not considered an emergency situation
Level 4: "resolution advisory or RA" - aircraft within 25 seconds of a collision. A warning is issued to the pilots and a vertical escape path is defined on the VSI. Pilots must maneuver the airplane to stay within the green arc on the VSI. If in RA is issued by the TCAS, the resolution maneuver takes priority over any ATC instruction. An Aeroflot aircraft actually collided with a DHL aircraft because the Aeroflot pilots followed ATC instruction rather than the RA issued by the TCAS.
So in response to your question, the TA is a "no action needed" alert unless the captain feels otherwise. I've never had a false RA, but if you are going to disregard one you better be well aware of the situation because a collision is usually imminent.
rendezvous
Mon May 29, 2006 5:47 pm
Bellerophon, yeah after thinking about it I completely agree with you.
DC-10Tech
Mon May 29, 2006 6:22 pm
Quoting CosmicCruiser (Reply 14):
Flap position is also monitored by the TCAS computer so that it does not give an RA instruciton that the aircraft is not configured to perform.
[Edited 2006-05-29 11:25:35]
Forums.AMTCentral.com
DC-10Tech
Mon May 29, 2006 6:32 pm
Quoting NW747-400 (Reply 18):
I'm not aware of this feature in TCAS. TA's are advisory in nature only, there is no conflict resolution generated from a TA. A target within the threshold will generate the TA 'traffic, traffic' alert, if an impending collision is detected, then a Resolution Advisory will be generated.
NW747-400
Mon May 29, 2006 7:59 pm
I also forgot to mention: an RA can give commands that an aircraft is not capable of performing. That is one fault of the system.
Mon May 29, 2006 10:06 pm
TCAS says Climb/Descent......Just Follow the Instructions.
True Warning or False is not Important.
regds
MEL
DC-10Tech
Tue May 30, 2006 1:44 pm
Quoting NW747-400 (Reply 22):
By regulation, it is not supposed to. This is why rad alt and flap position are fed to the TCAS computer and why alerts are inhibited below (appoximately) 1000ft AGL.
flymatt2bermud
Fri Jun 16, 2006 5:14 am
While on downwind visual approach we had two RA's flying into Naples, Florida one sunny afternoon created by small aircraft in our vicinity. These occurred within 30 seconds of each other and were caused by two separate aircraft. Just because you see traffic does not guaranty the traffic you see is the one your TCAS is warning you about. We promptly followed the commands on both occasions. The passengers were NOT impressed (or should I say from the cockpit it appeared I was being starred at by a barn full of owls) but the aircraft was safe.
All things considered we plan to follow the RA's immediately and ask questions later.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward" Leonardo Da Vinci
skyman
Fri Jun 16, 2006 8:24 am
Quoting Sabenaboy (Reply 8):
Sabenaboy
I agree with you on all points. Thanks for linking the Ueberlingen story so I don't have to write it down again. I'm a bit surprised that the story didn't seem to be a big deal in the USA? Can anybody confirm that?
Quoting Bellerophon (Reply 17):
Bellerophon
 checkmark
Quoting HAWK21M (Reply 23):
Quoting FlyMatt2Bermud (Reply 25):
FlyMatt2Bermud
 checkmark
If it is a TA ask ATC. If RA follow TCAS.
Fri Jun 16, 2006 4:56 pm
What Type Aircraft.
regds
MEL
flymatt2bermud
Fri Jun 16, 2006 8:26 pm
Quoting HAWK21M (Reply 27):
What Type Aircraft
We were in the Challenger 604 shown below. The other aircraft were both single engine Cessnas.
Big version: Width: 1536 Height: 1036 File size: 360kb
Users browsing this forum: emnunez and 1 guest
