MesaMXORD
Here Is How You Get A CRJ-200 From SFO-HNL
Wed Jun 14, 2006 10:26 am
Here it is. Now that BOMBA released it I can show. Here is the 1st GO! Airplane and the ferry tank install
Big version: Width: 853 Height: 637 File size: 1593kb
Big version: Width: 800 Height: 600 File size: 313kb
Best part is I get to go (no pun intended) and work out there for a month. What a bummer huh?
MESA - fighting common sense one day at a time
airwave
RE: Here Is How You Get A CRJ-200 From SFO-HNL
Wed Jun 14, 2006 10:43 am
Woah.
I'm guessing you have to (dis)assemble the tanks inside; they don't look like they're very manuverable otherwise. How much fuel do they each hold?
Airwave  eyebrow
When you do things right, people won't be sure you've done anything at all.
MesaMXORD
Wed Jun 14, 2006 11:26 am
Airwave [/quote]
There are 6 total you can't really tell in that pic they go out okay
airwave
Wed Jun 14, 2006 2:03 pm
Ahhh, ok, thanks!
Airwave  eyebrow
flyf15
Wed Jun 14, 2006 3:23 pm
Well, based on the cargo capacity of the CRJ-200... the tanks shouldn't be more than about 210 gallons each based on my calculations, increasing total fuel capacity by around 60%. But, that assumes they took off at normal MTOW, I suppose chances aren't 0 that they got a waiver and were able to take off heavier than MTOW.
AirWillie6475
Wed Jun 14, 2006 5:14 pm
What are the 2 seats there for?
ilikeyyc
Wed Jun 14, 2006 8:15 pm
Where and how do the aux. fuel tanks connect to the fuel system? Do they just drain into the center tank? Do they get spliced into a line? Do they have their own pump or ejector? curious minds want to know.
Quoting AirWillie6475 (Reply 5):
I would guess they are there because whatever they can fit on the airplane is something they don't have to pay to ship to hawaii.
Fighting Absurdity with Absurdity!
litz
Wed Jun 14, 2006 10:32 pm
Quoting Airwave (Reply 1):
It looks like each "tank" is actually 3 seperate sections, six total.
I would guess that's so they can rotate each one sideways and take it out through the overwing exit (not sure you could maneouver that out the front door w/the galley in the way ...) ...
Those are the two seats in the way back next to the lavatory. They're not in the way of the tanks, so why remove them?
 Smile
- litz
YULYMX
Wed Jun 14, 2006 11:36 pm
WOW sure hope they have enough fuel to make it to HNL  Smile
727EMflyer
Thu Jun 15, 2006 12:01 am
Quoting YULYMX (Reply 8):
Well, since the top photo was taken in HNL and (note WP) and they started ops last week, I'd say its a safe bet there was plenty of fuel  biggrin
MesaMXORD
Thu Jun 15, 2006 4:17 am
Quoting MesaMXORD (Thread starter):
Exactly they have that thing loaded to gills with fuel and on the 200 the center tank feeds the wing tanks so those aux tanks gravity feed the center tank and the center feeds the wings, etc.... The vent lines tie into the existing vent system and all is good
Those seats are there exactly for that reason our FEDEX bill was getting up there 24 seat assemblies * 6
aogdesk
Thu Jun 15, 2006 5:17 am
What a bummer huh?
Mesa, we feel your pain. You are real trooper to step in there and take one for the team. Your valor brings a tear to my eye.  Wink
KELPkid
Thu Jun 15, 2006 7:00 am
I'm just wondering how hard the Clearance Delivery controller at SFO was laughing as they issued a trans-oceanic clearance to a flight with the "Air Shuttle" callsign  spin
AirframeAS
Thu Jun 15, 2006 7:30 am
This is the same way HA did with their 717s from LGB to HNL.
777wt
Thu Jun 15, 2006 9:26 am
Quoting AirframeAS (Reply 13):
Photo © James Richard Covington
nudelhirsch
Thu Jun 15, 2006 4:27 pm
Isn't there a regulation about cabin attendance during ferry flights to watch for fire and other problems? That might be the purpose of the seats. Or to ferry the mx crew... Or both combined...
Putana da Seatbeltz!
Ryan h
Thu Jun 15, 2006 6:33 pm
I would be guessing that would definitely be a non smoking flight.
AirframeAS
Fri Jun 16, 2006 7:01 am
Quoting 777WT (Reply 14):
Thanks for the pic!
MesaMXORD
Sat Jun 17, 2006 5:27 am
Just got the good news! The last 200 gets there the day I fly in so I can answer some questions better about the set-up. (granted I wanted to surf not rip out tanks and put the interior back together)
777wt
Sat Jun 17, 2006 10:52 pm
Quoting MesaMXORD (Reply 18):
While you're in it, can you check out if the cabin pressurization has any effect with the aux tanks?
Like as the aircraft is pressurized for high alt. flight, does the vent system allow the pressurization to help push the fuel out of the aux tanks into the center tank?
don81603
Sun Jun 18, 2006 3:07 am
Okay, flame me if you want, but do they need ETOPS certification for a ferry flight from SFO to HNL?
Eagles may soar, but weasels don't get sucked into jet engines.
Sun Jun 18, 2006 6:07 am
Quoting Don81603 (Reply 20):
My guess would be no since this is a one time not in service flight. Just like ferrying a 747 with only 3 engines. You would need some authority to sign off on it though.
777wt
Sun Jun 18, 2006 10:39 am
Not for delivery flights. There's 'Special Flight Permit' for those ferry flights.
Ih8b6
Sun Jun 18, 2006 11:14 am
Wow, neat pic.
So a question: Are these aux tanks tested in the CRJs (and in the 717s for that matter) before they are put into use on the actual mainlaind to Hawaii flights? If so, how are they tested? Do they actually do some type of proving flight first to make damn sure that the tanks in the cabin are going to feed thru into the fuel system?
Over-moderation sucks
MesaMXORD
Fri Jun 23, 2006 4:25 am
Aloha Everyone
Quoting 777WT (Reply 19):
Nope just gravity.
bhill
Fri Jun 23, 2006 11:46 am
Wrong..silly humans..those are warp drive nacells... Wink)
Carpe Pices
ha763
Fri Jun 23, 2006 12:37 pm
Quoting IH8B6 (Reply 23):
The tanks themselves are pressure tested to check for leaks. If you look at the HA 717 pics, you can see it written on the tank. Other than that, the only other test would be to check for leaks in the hoses and connections. There are no mechanical parts to check as the fuel drains from the bottom of the tanks into the fuel system.
Users browsing this forum: Iemand91 and 1 guest
