amberair732
Approach Speed With/without Winglets
Thu Jun 15, 2006 7:35 am
Hello everyone. This may have been discussed before, but I can't find it so please point me in the right direction if it has. Here goes.
Having spent a lot of time at BLK recently - it's opposite my house - I have noticed that the FR 738's which land here appear to have a slower approach speed if they have winglets.
Could any of our experts out there tell me if the extra lift provided by winglets on a 738 ( or any other aircraft ) would be sufficient to produce a noticeably slower approach speed or for that matter take off speed, or have I been sat in the sun for too long.
saturn5
RE: Approach Speed With/without Winglets
Thu Jun 15, 2006 8:22 am
Quoting Amberair732 (Thread starter):
most likely the case. Big grin
777wt
Thu Jun 15, 2006 9:31 am
It's only a few knots slower the most.
CO had a problem with CAT III autoland with their 752 after addition of APB blended winglets and during flight testing. It was 'floating' a bit longer during flare, an solution has been used to fix the float. I do not know what the solution is.
cptspeaking
Thu Jun 15, 2006 2:02 pm
Quoting 777WT (Reply 2):
I was under the impression that US part 121 carriers were prohibited from CAT III approaches...is it the specific airlines that restrict them, the FAA, or what? That or am I way off on this one?
I know there are CAT II and III certified approaches (and airplane, for that matter) in the US, but I've never heard of or seen them in use, especially by a US carrier.
Your CptSpeaking
...and don't call me Shirley!!
EssentialPowr
Thu Jun 15, 2006 2:11 pm
Quoting CptSpeaking (Reply 3):
Waaaaaaayyyy off. A 777 for any US airline is capable of a SINGLE ENGINE Cat 111.
The winglet versions of the 737 are easier to land, ie they will float a bit at idle, Vref +5 from 20 feet Agl or so...
cptspeaking
Thu Jun 15, 2006 2:22 pm
Quoting EssentialPowr (Reply 4):
I realize they are capable, as well as almost any other model (737, 767, A320, yada yada yada...), but are they allowed? If so, why do so may flights get diverted for low level fog or other limiting weather?
I saw a video on flightlevel350.com of a Swiss A340 on a CAT III autoland that was pretty sweet...you see the spoilers deploy and then see the runway edge lights barely appear.
Your CptSpeaking
EssentialPowr
Thu Jun 15, 2006 2:28 pm
Yes.
IAHFLYR
Thu Jun 15, 2006 9:57 pm
Quoting CptSpeaking (Reply 5):
I can't think of an airline with aircraft that are certified for CATIII ops that don't use them. There is an issue of crew training and currency for sure so that could acocunt for some diverts but for the most part not to big an issue.
Most diverts at IAH due to low vsby is due to the crew not being qualified fot CATIIIB and the RVR being less than 600'....but that just doesn't happen more than a few months out of the year.....some of it could be they get all balled up in a holding pattern with aircraft that are not CATIII able and the center for whatever reason can't get them out of it before they have no more gas to hang around.
There are other reasons for diverts such as flow rates at the airport going to hell if the fog wasn't forecast and a much lower arrival rate has to be put in place. Or, the airport has departure runways that are dependent on arrivals not missing an approach or you'll might have 2 airplanes in the same place, one departure and the other a missed approach. IAH is a good example of an airport that can take about 130 arrivals an hour but can't get departures out in low weather conditions due to having to protect for the missed on 27 crossing the 15 complex.
But back to the original post.....: Smile winglets on the 800's I hear do make them easier to land but don't change the ref speed from around 155 kts on the 800's with flaps 30.....but folks sure don't like following them on final too close.
[Edited 2006-06-15 15:00:20]
cptspeaking
Fri Jun 16, 2006 10:51 am
Quoting EssentialPowr (Reply 6):
Yes.
Quoting IAHFLYR (Reply 7):
I see...thanks for the explanation, now I know!  Smile
Your CptSpeaking
