ba757gla
Contrail Horizon To Horizon? What Distance?
Sat Jun 17, 2006 9:35 am
when i see contrails how far would be overhead to horizon and horizon to horizon? i dont really understand compilcated answers.
MrChips
RE: Contrail Horizon To Horizon? What Distance?
Sat Jun 17, 2006 11:10 am
Assuming you are on featureless ground at sea level and with the aircraft at the ubiquitous cruising altitude of 37,000 feet, a contrail will be about 545 miles long if it stretches from one horizon to the other.
[Edited 2006-06-17 04:12:31]
Time...to un-pimp...ze auto!
Bobster2
Sat Jun 17, 2006 11:26 am
What is the formula for figuring this out?
I'd like a general equation using the observer's and the airplane's altitudes, and of course the diameter of the earth.
Extra credit: Can you take into account the fact the airplane's apparent position on the horizon is not the true position because of light refraction in the atmosphere?
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
Newark777
Sat Jun 17, 2006 11:28 am
Quoting Bobster2 (Reply 2):
I've done it before, just draw a diagram and start using geometry.
If you want to get into some hardcore physics.  Wink
Harry
flymatt2bermud
Sat Jun 17, 2006 11:34 am
I think the ultimate contrails are the Shuttle going directly into space! Better view from an aircraft. It is a sight most enthusiasts will never forget. Distance (?) to the moon!!
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward" Leonardo Da Vinci
Bobster2
Sat Jun 17, 2006 11:51 am
Quoting Newark777 (Reply 3):
I can draw a diagram if the observer is at sea level. I can't figure out how to do it when the observer is at some arbitrary height above sea level.
In the first case it's a simple right angle triangle equation. The second case involves angles that I can't figure out.
Can you give me a hint? Or better yet, the answer?  Smile
Bobster2
Sat Jun 17, 2006 1:04 pm
Quoting Bobster2 (Reply 5):
I may have figured it out. If the observer is above sea level you have two right angle triangles, just add them together.
lehpron
Sat Jun 17, 2006 5:43 pm
Quoting Bobster2 (Reply 6):
Are you assuming flat level ground or taking into account Earth's curvature?
You can exaggerate your diagram as long as you state all/any assumptions you plan to use with it.
David L
Sat Jun 17, 2006 7:05 pm
As a starter, here's how to calculate the distance to the horizon:
http://www.wolfram.demon.co.uk/rp_horizon_distance.html
To get the maximum distance to a point at the same height above the earth's surface as the observer, just double the distance to the horizon. Obviously there's more to it if the target (contrail) is at a different height to that of the observer. It's a starter, as I said.
 talktothehand
redcordes
Sat Jun 17, 2006 7:38 pm
Better check your math and atmospheric conditions. If you could see a 545 mile long contrail (and it would have to linger for an hour which would be unusual) the visibility would have to be 270 miles. No way. Assuming that you could only see a contrail to a point 10 degrees above the horizon, the angle the contrail is viewed would be 80 degrees each way from the observer. The tangent of 80 is 5.67, which gives the ratio of the distance the contrail can be seen in each direction to the distance the aircraft is above the earth. Therefore, if the aircraft is at 36,000 ft. (about 7 miles) the length of the observed contrail as described would be about 5.67 x 7 x 2, which is about 80 miles. Sound reasonable? A way to check this would be to measure the time the aircraft is in view, assuming a speed of 500 miles/hr. Should be about 10 min. Assuming 42,000 ft (8 miles) the distance would be about 90 miles and in view almost 12 min. Check it out.
[Edited 2006-06-17 12:48:03]
[Edited 2006-06-17 12:49:37]
"The only source of knowledge is experience." A. Einstein "Science w/o religion is lame. Religion w/o science is blind."
David L
Sat Jun 17, 2006 8:58 pm
Quoting David L (Reply 8):
Actually, to get the theoretical horizon to horizon distance you'd work out the distance to the horizon for an observer at height h, do the same for a point at, say, 6 NM altitude, add the two together then double the result.
OK, now we can start getting "real"...
Quoting Redcordes (Reply 9):
SlamClick
Sat Jun 17, 2006 9:49 pm
Ahh, you must live on the eastern seaboard.
Visiblity on that order is common out west. The limits to the visibily in the western states is almost always the distance to the horizon. I've been able to see the top of Mount Hood, near Portland Oregon from FL330 over Twin Falls Idaho. The setting sun was behind it and it was clearly visible. Far more than 270 miles.
David L
Sat Jun 17, 2006 10:04 pm
Quoting SlamClick (Reply 11):
But not much chance of that where the thread starter lives.  Sad
SlamClick
Sat Jun 17, 2006 10:07 pm
You must keep in mind that the contrail is curved. That is, it is a constant height above a curved earth surface called sea level.
So draw two concentric circles, an inner and an outer one. The inner one is the surface, the outer one is my 'orbit' above it. Draw a straight line across them just touching the inner circle represents line-of-sight. Now you can do the geometry and it is fairly simple.
Easiest way, though is to take the accepted formula and double it. It goes like this:
Distance to the horizon in nautical miles is 1.23 times the square root of your height above the surface in feet.
So I am flying at 35000' and my calculator says the square root of 35K is 187.08
187.08 X 1.23 = 230.1 nautical miles.
So I can begin to see you 230 nautical miles away. That means you can see my contrail pop up over the horizon at that distance. It will remain in view, if I pass directly over your head until I get that same distance off in the other direction, or 460 nautical miles. That is about 529 statute miles.
Of course the only time you would have me in sight that long is if I flew in a straight line directly over the top of you. The fact is I am more likely to have a closest point of approach some miles distance from you. That will shorten the actual distance you can see my contrail. This is because the area of sky you can see is actually a circle with you at its center. If I just fly across the outer edge of that circle you will not be able to see my contrail for very long.
I'd guess that most of the times I saw this phenomenon back in the days of big recips flying at high altitude, most of the contrails were many miles distant and rarely over a hundred or two miles of actual trail seen.
David L
Sat Jun 17, 2006 10:20 pm
Quoting SlamClick (Reply 13):
Much better than my 3 stage effort, especially since the observer is likely to be as near as dammit to sea level. SlamClick strikes again.
timz
Sun Jun 18, 2006 7:32 am
SlamClick didn't mean to suggest that the calculated horizon distance was the farthest one could see-- mountains can of course be seen farther, sticking up beyond the "horizon".
Like I said before, Mt Hood wouldn't stand out from there, compared to the closer peaks. It might be hidden by them.
SlamClick
Sun Jun 18, 2006 11:40 am
Quoting Timz (Reply 15):
Not only that but on numerous occasions I have seen the moon close to the horizon in the western states.
redcordes
Mon Jun 19, 2006 5:40 am
I hate to quote myself, but this method might be the best after all is said and done. This would be real and take all variables into account. I got money that says in most locals you won't see an aicraft at cruise (contrails) in view for more than 15 min. (probably less, particulary in the thread-starter's location). Slam you got any cash?
timz
Mon Jun 19, 2006 8:52 am
Quoting Redcordes (Reply 17):
You mean in most locales it's never clear enough-- maybe so, but I suspect the original question assumed clear air and an unobstructed view. If binoculars are allowed there are plenty of hilltops from which you can easily spot a contrail coming toward you, 150+ miles away, on a clear day. (Won't be so easy if it's crossing your line of sight, tho.)
On a clear day here in California, we can just barely make out Mt Lassen (10000 ft high) from Mt Diablo (3800+ ft high)-- that's 180 statute miles. Think we could see a 747 contrail above Mt Lassen?
redcordes
Mon Jun 19, 2006 7:24 pm
The thread-sarter is on the ground in the U.K. He asked about his typical observations, not somewhere on a hilltop in California with binoculars. He also said he doesn't understand complicated answers. Heck, many nights here in New England the visibility is over 250,000 miles--because the moon is visible! Additionally, when the visibility is extremely good, the contrails are extremely small.
SlamClick
Tue Jun 20, 2006 12:40 am
Quoting Redcordes (Reply 19):
True, and it would only be polite of the thread starter to come back and let us know if he got an answer that satisfied his curiosity.
My answers addressed only the geometric possibilities under perfect conditions plus a couple of empirical observations.
Hell no! If I'd wanted cash on hand at this point of my life I'd never have devoted my life to aviation.
I think your fifteen minutes would be on the short side but then I've spent most of my life in the western US and have that frame of reference.
I cannot give your theory a fair test for several reasons. I live above five thousand feet. This makes prime contrail country only about thirty thousand feet above me, making the theoretical distance to the horizon a mere 213 nautical miles away. Further, I live in a valley of the Great Basin. Hills and mountains rise a thousand feet above me only a mile away, and three thousand feet above me only seven miles away. This shrinks my sky considerably.
David L
Tue Jun 20, 2006 12:55 am
Quoting SlamClick (Reply 20):
I would have thought so, too.
I live 30 to 40 miles away from him and, if it weren't for the clouds, the visibility would probably be close to Redcordes' "10o above the horizon" scenario today (no hills bigger than that in the area), which is about as good as it ever gets here.
Users browsing this forum: BravoOne, Nean1, zmiko and 1 guest
