yanksn4
Auto Land System Control From Ground
Fri Jun 23, 2006 1:14 pm
just had a little discussion with a friend about auto land systems and terrorism. Does anyone know if there's a system being developed to where ground control could take the controls of the pilot and land the plane safely before a sept. 11 would be repeated? thanks.
2013 Airports: EWR, JFK, LGA, LIS, AGP, DEN, GIG, RGN, BKK, LHR, FRA, LAX, SYD, PER, MEL, MCO, MIA, PEK, IAH
n8076u
RE: Auto Land System Control From Ground
Fri Jun 23, 2006 1:26 pm
If "ground control" could take over, then what's to stop the terrorists from doing so as well, without even having to get near the airport or the aircraft? Or instead of taking over a couple aircraft, take over the control center and crash 100 aircraft.
From a technical standpoint, this sort of remote control override would be more useful with something like, oh, let's say an A320 or any fly-by-wire type of aircraft where the pilot can be taken out of the loop. With something like a 747/757/767, the pilot can always override the autopilot with the controls, unless that was somehow modified as well.
Conspiracy theorists would say that capability is already there.  Wink
Chris
Don't blame me, I don't work here...
PolymerPlane
Fri Jun 23, 2006 1:34 pm
You might as well fly the plane from the ground. Save some pilot salary
PP
One day there will be 100% polymer plane
reins485
Fri Jun 23, 2006 1:59 pm
Quoting PolymerPlane (Reply 2):
And they can outsource it to India.  Wink
Alex
David L
Fri Jun 23, 2006 7:20 pm
Quoting N8076U (Reply 1):
I'd assume such a system would prevent anyone in the aircraft from regaining control otherwise it would be a bit of a waste of time.  Smile
But, as has been said many times before, there are too many problems with the concept and perhaps even the need... at the moment.
Fri Jun 23, 2006 8:58 pm
How would you convince the Pax to Ride in them  Smile
regds
MEL
avioniker
Fri Jun 23, 2006 9:48 pm
There is a system in existence but as with any autoflight system there must be, and is, a provision allowing manual override by a pilot in the cockpit.
I don't believe the system is currently installed in any aircraft in passenger or revenue service.
redcordes
Fri Jun 23, 2006 10:22 pm
Systems/programs that could initiate, from the ground or aircraft, an irreversible emergency landing at a nearby suitable airport are probably rather easily done with modern technology. Unfortunately, a would-be hijacker could preempt this system by threatening against its use in the first place.
"The only source of knowledge is experience." A. Einstein "Science w/o religion is lame. Religion w/o science is blind."
Fri Jun 23, 2006 11:12 pm
Well, we've all seen Die Hard II  Wink
On a non-FBW aircraft, I assume you could install motors strong enough to override the pilots. And I don't think "more useful" is an appropriate word. Something like "more practical" maybe?
Quoting Avioniker (Reply 6):
That would make the system useless at preventing 9/11 style takeovers.
I think the money would be better spent elsewhere, for example in better security as opposed to the politically induced ineffectiveness in the US now. See here for an example (The Kuwait Airport section): http://www.keepandbeararms.com/information/XcIBViewItem.asp?ID=2459. If most Americans could just get over their opposition to body searches (yes, they are VERY effective if done properly) and these were made mandatory, things might improve in my mind.
Here'�s the punchline of the article:
How long did this take? Not much longer than it takes to read about it. How good was it? I've never felt safer in an airport, and this was technically a war zone. How expensive was it? Not very, and certainly cheaper than replacing the World Trade Center.
Would this have stopped the attack? Perhaps. Perhaps not. Would it stop many other incidents? Yes. Does it intrude on American privacy? Not much.
It is efficient, it is polite, it is secure. For those reasons, the FAA obviously won't embrace it.
avioniker
Sat Jun 24, 2006 12:03 am
I have to agree totally with Starlionblue.
I went through FRA a couple of weeks ago, and because I was enroute to the US went through security searches three times. None of the searches delayed me more than 30 seconds and they were VERY thorough. Much more so than the 15 to 25 minute delays I experienced in ORD the same day.
It isn't so much the Americans' attitude about searches as the searchers' attitudes about having power over someone making the general public feel intimidated by a two digit IQ.
Just one man's opinion mind you...
 Smile
Users browsing this forum: 744lover, diverted, Google Adsense [Bot], litz and 12 guests
