phxplanes
Question About Air Starts.
Mon Jul 03, 2006 2:47 pm
Like the title says I have some questions about air starts. First how does the pilot know they will need an airstart. Why do you need an airstart, what happens to need it. Finally what exactly does the air start machine do (obviously blows air into the engine) but more technical.
Sorry the question might be a little choppy but thank you in advance for the answers.
n685fe
RE: Question About Air Starts.
Mon Jul 03, 2006 3:01 pm
Aircraft engines are started using an air driven starter that receives pneumatic pressure from the apu. If the bleed system on the apu or the entire apu is on deferral then an alternate source of air pressure is needed. When a new crew receives the aircraft they review the log book, any deferrals will be noted in the log book with a deferral sticker next to the apu start switch. Need more details?
psp. lead by example
KAUSpilot
Mon Jul 03, 2006 3:09 pm
Quoting Phxplanes (Thread starter):
You know you will need an airstart if your APU is inoperative. Normally the APU provides the air needed to start the engines, however, if it isn't working, then you will need an airstart cart. Some military aircraft always need an aircart start, as the they don't want to or can't use the batteries to start the engines and aren't equipped with APU's (the T38 comes to mind).
The airstart cart really doesn't do a whole lot more than blow air into the engine. The Airstart hookup is plumbed into the air turbine starter via a "starting control valve". This valve regulates the pressure supplied to the air turbine starter (ATS). The ATS in turn converts the pneumatic energy from the pressurized air into driving torque for engine gas generator spool acceleration up to the self-sustained speed during the starting cycle. Air exhaust from the turbine is discharged into the engine nacelle compartment. There is not a significant difference in the start sequence between using the APU as a pneumatic source vs. an airstart cart, at least on the aircraft I fly.
We must start the #2 engine on my aircraft first if we are using an airstart cart, since the hookup is on the right side of the aircraft and it is plumbed into the #2 engine's ATS. After starting the #2 engine, the airstart cart is disconnected.
To start #1 after an aircart start, we do what's called a "crossbleed start", meaning we run the #2 engine up to 83% N2, open the bleed air valve and crossbleed, and start #1 using bleed air provided by #2. Special caution must be exercised during this procedure so as not to damage nearby aircraft or ground equipment with jetblast.
Hope this helps.
n8076u
Mon Jul 03, 2006 3:34 pm
One other thing, is some older aircraft didn't even have APU's, like the DC-8 (some had them added later, but the majority didn't), so every start would require the air cart/truck to be hooked up, and one engine started at the gate before pushback. Once pushed back, the bleed air from the one running engine would be used to start the remaining ones.
Chris
Don't blame me, I don't work here...
EMBQA
Mon Jul 03, 2006 7:27 pm
To answer your questions-
The APU won't start....APU failure....you go find the Air Start Cart....it's an APU and produces the air needed to start the aircraft engines when the APU won't work.....nothing technical about it, the plane just gets its air from a second source.
GEG
Tue Jul 04, 2006 12:59 am
Roughly how much air pressure is required for the start?
-Dan
I have no idea what I'm doing...
n685fe
Tue Jul 04, 2006 2:12 am
GE-CF680C2A5F
General-The starting system of the CF6-80C2A FADEC engine utilizes pressurized air to drive a turbine at high speed. The turbine turning through a reduction gear applies a torque to the HP shaft, thus driving the engine. The air which is necessary to drive the starter is supplied by either : - the APU - crossbleed from the second engine - a ground power unit. The starter supply is controlled by a starter shuf-off valve pneumatically operated and electrically controlled. In case of failure, the valve can be opened manually. Engine starting is controlled from ENGINE START panel, located in the center of the overhead panel. For each engine, the illumination of the blue OPEN legend integral with ENGINE START/START 1 (2) pushbutton switch indicates that the start valve is open. The starting sequence may be interrupted at any time by placing ENGINE START selector switch in OFF position. This ignition selector switch also controls the ignition system and enables selection of one of the two ignition systems (A or B), or both at the same time or a dry motoring to be carried out with CRANK selected. A switch in the N2 speed indicator causes the starter valve to close when the N2 speed exceeds 45 %. The starter centrifugal cluth then disconnects the starter turbine and gears from the output shaft and allows the turbine to stop rotating.
Air Supply-The air necessary for starting comes from the duct connecting engine bleed and the pre-cooler via a 4 in. dia. duct. This duct is attached to the engine bleed duct just before the precooler inlet. Through operation of the crossfeed valve and APU bleed valve, the air necessary for the starter is supplied by either : - crossbleed from the other engine - the APU and in that case, all the air bled from the APU is used for starting - an external source able to supply a pressure between 25 and 55 psig (maximum permissible pressure in the duct).
n685fe
Tue Jul 04, 2006 2:56 am
PW JT8D-217C
Same theory. Minimum pnuematic duct pressure 36 (±5) psig.
phxplanes
Tue Jul 04, 2006 3:35 am
Thanks guys for all your responses, I didnt know that the apu doesnt work sometimes.
thank for the answers.
EMBQA
Tue Jul 04, 2006 11:08 am
Quoting GEG (Reply 5):
It's not really pressure more then it is volume.
flymatt2bermud
Tue Jul 04, 2006 4:01 pm
We typically only require a aux ground air start when the airstart cart is not available. It's Newton's law.
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward" Leonardo Da Vinci
Tue Jul 04, 2006 5:53 pm
Its normally reffered to as the Pneumatic Jet Starter unit.
In case an Aircraft has an Unserviceable APU,or APU that has an u/s Pneumatics.The Pneumatic Jet Starter is used.
Depending on the Requirement of Airflow as per Engine to be started.The Unit can be of a certain Capacity,with Two hoses.These hoses attach to Ground connectors of the Aircraft.
The Pneumatic Jet Starter is almost a Truck mounted APU.The Pneumatic Supply is used to Crank the Pneumatic starter mounted on the Engine & crank it to achieve necessary Start.
regds
MEL
undehoulli
Tue Jul 04, 2006 11:51 pm
The aircraft I fly requires 12 PSI for starting the engines, either from the APU or from an air cart. I've never had to use an air cart, and I usually see around 35 PSI from the APU.
Weather Modification Rocks!!!
Wed Jul 05, 2006 12:23 am
Quoting Undehoulli (Reply 12):
12psi.
Which Aircraft is this regarding.
regds
MEL
charlienorth
Wed Jul 05, 2006 2:35 am
A-320 with CFM56 >25 psi, someone asked about APU's breaking,some seem to die if you look at them wrong!They're real susceptible to shutting down at low oil levels,there was an airline I worked on-call for,CRJ's,Maint control would call about a failed APU and often we would service the oil level and the thing would then operate normally,the sad thing was it usually just out of a line-check,pressure switches are another high failure item,apu door rigging seemed to be a problem on the 737/200,speaking of APU's anyone up for a APU flow control valve on a 727?
Work hard fly right..don't understand it
undehoulli
Wed Jul 05, 2006 11:05 am
Quoting HAWK21M (Reply 13):
12psi.
The Dornier 328JET.
nonfirm
Wed Jul 05, 2006 5:56 pm
We use the air start cart or (huffer) as we call it for any Eng start the the whole apu is on Mel or the pneumatics system is inop.If the electrics on the apu is inop then we use apu air but ground power to complete the start then a cross-bleed to start the opposite Eng.We also only start the # 1 Eng at the gate because the huffer is on the r/h side of the a/c due to the pluming and safety for the ground crew.  airplane
UAL Bagsmasher
Fri Jul 07, 2006 7:59 am
The CRJ-200 APU is probably worth more in scrap metal than as an APU. Well, maybe not that bad, but close. I guess it's good job security though. I second the motion about bad pressure switches. They go bad all the time, and leak oil more often than not.
twal1011727
Fri Jul 07, 2006 8:50 am
Quoting FlyMatt2Bermud (Reply 10):
Could you tell us what the difference between the two are?
Last time I checked their one in the same.
KD MLB
fr8mech
Fri Jul 07, 2006 8:55 am
Quoting TWAL1011727 (Reply 18):
I believ what he's saying is: they only need an airstart cart when their airstart cart is unavailable. And I believe he means Murphy's Law.
Fri Jul 07, 2006 5:13 pm
Quoting Charlienorth (Reply 14):
You mean the Microswitch on the Door.Right.
Quoting Undehoulli (Reply 15):
12psi.
The Dornier 328JET.
What type APU.
regds
MEL
flymatt2bermud
Sat Jul 08, 2006 10:17 pm
Quoting Fr8Mech (Reply 19):
Sorry folks I was just trying to add a bit of levity to the thread with both remarks. But really when we are places such as Timbuktu it seems the thing wants to start hotter or slower just to get under my skin.
n8076u
Sun Jul 09, 2006 3:52 am
Quoting FlyMatt2Bermud (Reply 21):
Don't be sorry, I think at least a few of us got what you meant to say.  Wink
Chris
Sun Jul 09, 2006 4:12 am
No need to apoligize.We understand what you meant.
Cheers and keep the Info flowing.
regds
MEL
NZ8800
Sun Jul 09, 2006 7:51 am
Is this (airstart cart) the same thing used to start a turboprop like the SAAB 340?
Or are they started electrically?
How high do you have to run the engine (always port, I think) on the SAAB to before you can start the other one?
MDZWTA ~ Mobile Disaster Zone When Travelling Abroad
twal1011727
Mon Jul 10, 2006 4:40 am
Quoting NZ8800 (Reply 24):
The SAAB 340 is an electrically started engine..Since the A/C does not have an APU it has to have a 28volt DC ground power unit.
If I remember correctly, the plug receptacle was located on the fuselage behind the right wing.
AA/eagle flew them into MLB back in 1993-1995 before they pulled out too.
Tristarsteve
Mon Jul 10, 2006 4:47 am
Well that struck a chord. I spent many a year on the B737-200 and have lost track of the number of times I hit the APU door to make the APU start! Nearly always worked. I seem to remember you could get it out of R2 door with a pole?
Mon Jul 10, 2006 8:01 pm
Quoting Tristarsteve (Reply 26):
Its the Sequence Microswitch on the Door.Tapping the Door makes the Contact with the Switch to Supply Voltage to the Starter Motor to crank the APU.
regds
MEL
charlienorth
Tue Jul 11, 2006 1:21 am
If I only knew about tapping the door from 2R!!! The 737/200 had a lot of little tricks that senior mechs and pilots could show you!
Wed Jul 12, 2006 1:38 am
Quoting Charlienorth (Reply 28):
That would be Interesting.
regds
MEL
n8076u
Wed Jul 12, 2006 2:55 am
I've seen this done a couple times. Looks pretty funny watching it. Our 737 gates had a bucket-on-a-pole so the fuelers could hand their loading sheets up to the cockpit through the sliding window. That pole had other uses as well, including APU door coaxer.
Chris
Wed Jul 12, 2006 1:44 pm
Quoting N8076U (Reply 30):
Thats a common one.But We use a trestle  Smile
regds
MEL
n8076u
Thu Jul 13, 2006 4:14 am
Quoting HAWK21M (Reply 31):
What's a trestle?
Chris
Thu Jul 13, 2006 7:03 pm
Out here its called a Trestle.Is it a different name out there.
Aircraft Ground Equipment to reach places on the Aircraft Exterior to Enable Mx work.
regds
MEL
n8076u
Fri Jul 14, 2006 5:25 am
Ah, "stairs".  Wink
Chris
AF1624
Fri Jul 14, 2006 6:13 am
Ah. Stairs  Wink
LOL. That one made my day
       Wink
[Edited 2006-07-13 23:14:36]
Fri Jul 14, 2006 4:27 pm
Quoting N8076U (Reply 34):
Ah, "stairs
Is it called stairs even if it of various Heights & sizes.
regds
MEL
n8076u
Fri Jul 14, 2006 5:25 pm
Quoting HAWK21M (Reply 36):
Generally speaking, yes, we'd just call them stairs, sometimes workstands or work platforms. Some we had were fixed-height, but most were adjustable. Some people called them air-stairs as well, as the stairs take you nowhere but into the air.  Wink
Chris
Fri Jul 14, 2006 8:28 pm
Quoting N8076U (Reply 37):
We have the Hydraulically Adjustable type out here.Works well.
regds
MEL
ReidYYZ
Sun Jul 16, 2006 11:15 pm
Now lets suppose you are on the outer reaches of the universe with a bad apu (totally &%$#ED) you come in on the rescue aircraft because the first a/c can't get an engine started. According to some MM's, blasting one engine exhaust at high power into the other may get you the rotation to start. Another way, as used by a former employer, a hose from a jetstart with couplings at each end. One end has a fork protruding at the coupling, hook it up to each a/c. The fork end into the servicable equiped a/c, the other end into the u/s. Fire up the serv. apu (fork holds open check valve at coupling) and the air goes over to the bad pneumatic crossbleed ducting. Does anyone out there still use this method?
Mon Jul 17, 2006 1:55 am
Quoting ReidYYZ (Reply 39):
We Tried it [Cross bleed start from Aircraft Apu to other Aircraft Engine] with Help from Another operator as Grd unit was not Available.
Worked Great.
regds
MEL
N353SK
Fri Nov 24, 2006 2:43 pm
I believe you're thinking of a GPU (ground power unit). I know a lot of BE1900s don't have APUs for weight reasons, so I would assume that the 340 is the same way. The plane can start off of the battery, but it's generally good practice to save stress on the battery and use a GPU. There's really not a good way to tell the difference between an APU and an Airstart. The only real general differences are that the Airstart has a hose while a GPU has a cord, and while a diesel GPU is loud, an Airstart at full speed can probably be heard from the moon.
Fri Nov 24, 2006 11:19 pm
Quoting KAUSpilot (Reply 2):
We normally use a longer hose & do Two starts.More safer.
Normally 40psi.Min 35psi for JT8Ds but Volume will vary per Engine type eg the RB211-535C requires more volume being a Triple spool Engine.
Quoting N353SK (Reply 41):
If the Starter is Electricaly operated.
regds
MEL
Users browsing this forum: bahmed22 and 1 guest
