CBERFlyer
Landing Aborts/go-arounds
Thu Jul 06, 2006 4:37 am
Yesterday afternoon, I was aboard F9 flight 724, scheduled to arrive into DCA at 4:55 pm. During approach to DCA, a severe thunderstorm cell was just to the north and west of the airport. Needless to say, the ride was rather bumpy, while the plane maneuvered to the downriver approach into DCA. Watching out the window, I could tell we were way too high as we passed the Kennedy Center and the Washington Monument to make it down to the runway, and indeed the pilot executed a go-around.
We then circled back around over Alexandria and Arlington, the retry to river approach. Once again, the winds were apparently too rough, and the pilot executed a second aborted landing.
After this second attempt, the pilot addressed the passengers, and stated that the close-by thunderstorm was causing wind shear conditions and excessive tail winds for a safe landing. He also stated that his primary concern was the safety of the passengers, and that he would "not be pushed by ATC" to land in what in his opinion were unsafe conditions. He stated that we had plenty of fuel, and would circle again for another try, and divert if necessary.
We did indeed circle around over Alexandria and Arlington again for another try at the downriver approach, but for a third time we overflew the airport. The difference this time was that instead of banking to the right over the Alexandria side of the river, we turned towards the left over SW DC, then swung around 180 degrees at only 900 ft of altitude just north of the Woodrow Wilson (I-95/I-495) Bridge, and reapproached headed upriver instead. This time, we were able to land successfully, to clapping and cheering from the passengers.
My question: Is there any sort of "limit" on how many tries a pilot may take to attempt a landing in such conditions? Another passenger commented that the pilot must have been really "p*ssing off" ATC by repeatedly aborting and going around for retries. Is it fully in his/her judgement whether to continue making landing attempts, or to divert elsewhere?
Clipper002
RE: Landing Aborts/go-arounds
Thu Jul 06, 2006 4:43 am
No, there is no limit as to how many missed approaches you fly. He was probably getting a windshear detection on final and aborted the approach. Usually after the second failed attempt, the crew is running short on fuel and will divert. Your flight flight may have been tankering a little extra fuelwhich allowed a 3rd approach. Believe me, ATC does not break anyone's chops over missed approaches.
Rgds,
Ed
Ed
dartland
Thu Jul 06, 2006 5:24 am
Quoting Clipper002 (Reply 1):
Correct me if I'm wrong (haha, like I even need to say that on A.net), but don't some airlines not allow more than 2 approaches? If you miss 2, you are forced to divert.
I believe the rationale is that difficult approaches are taxing on the pilots and the chance for a catastrophic error goes up significantly after each approach. So after 2 misses, they force the pilots to divert where conditions are likely to be better.
IAHFLYR
Thu Jul 06, 2006 5:34 am
Glad to hear you say that, as it is so true especially when weather related. On the flip side of that I will say that we in ATC do ask why on earth a crew wants to fly into this stuff just to not have to go hold or divert, have seen pretty awful thunderstorms that people want to attempt the approach and I ask why??? Thank goodness those few that I have seen do this have used better judgement and aborted the approach anyway.
73G
Thu Jul 06, 2006 5:58 am
Quoting CBERFlyer (Thread starter):
Hmmm, that doesn't seem very realistic. It is solely the responsibility of the PIC to determine whether or not to continue an approach in adverse conditions. ATC's function is to provide current weather information and vectoring when possible. ATC in this case could care less if they wanted to shoot the approach 10 times or divert to IAD or BWI. The only limiting factor in determing the number of approaches an airplane can attempt is fuel. Typically a predetermined amount of fuel, sometimes referred to as a 'bingo fuel' will have been calculated and agreed upon by the captain and dispatcher. Once the fuel level reaches bingo, its time to divert to the alternate.
CBERFlyer
Thu Jul 06, 2006 6:31 am
Quoting 73G (Reply 4):
Well, it is exactly what the pilot said.
I agree that ATC wouldn't "push" a pilot to land in potentially unsafe conditions... that would be contrary to all common sense. I imagine it is more of an airline imperative to avoid diversions.
Quoting Dartland (Reply 2):
Hahaha... ain't that the truth!  Smile
DualQual
Thu Jul 06, 2006 6:34 am
Nope, only limit is how much gas you have to keep trying before you have to divert. And you still have to arrive at your divert with proper reserves. 2 is generally the magic number because of how much gas you have, how far the alternate may be, and usually if you don't get in on the second shot things won't improve enough to make it worthwhile to try again (ceiling usually). In this case the factor was the wind. If it is a windshear event it is usually short lived making a couple extra approaches worthwhile. Also, since we are talking a localized event BWI and IAD would have made good alternates and are close. If it is really bad weather with low clouds you may have to go further (PHL, JFK) to find a suitable alternate which requires more fuel and fewer chances to try the approach.
There's no known cure for stupid
Gib
Thu Jul 06, 2006 8:34 am
I'll second CBERFlyer on that! As I said on another thread, if friggin' Chuck Yeager himself was stating fact on an a.net board, numerous arm chair aviation 'EXPERTS' would pick the post apart in a matter of minutes.
Thu Jul 06, 2006 9:09 am
Quoting Gib (Reply 7):
Well, Chuck Yeager is notorious for being an Airbus basher. Big grin
As has been said, ATC and pilots are pros, there is no pushing. It should also be noted that a missed approach is the safe option, not some sort of emergency manoeuver.
cptspeaking
Thu Jul 06, 2006 1:23 pm
I think you're right for instrument approaches in the soup, but in a situation like this where hard IMC isn't the limiting factor, but rather winds/wind shear, which can go or stay at any time, I wouldn't think they would be forced to divert. Yes, instrument approaches to minimums can be EXTREMELY stressfull, especially when you're at the end of a long day and just want to get down, but when you're on a visual approach and have plenty of fuel for a few more chances at a good, smooth, and safe approach and landing, I wouldn't divert after just 2 trys.
Your CptSpeaking  wave
...and don't call me Shirley!!
aaden
Sun Jul 09, 2006 1:27 pm
on average does anyone know how many times a pilot will have to execute a go around in his or her career as an airline pilot?
rendezvous
Sun Jul 09, 2006 2:03 pm
AAden - probably many many times.
Ralgha
Sun Jul 09, 2006 3:00 pm
Unfortunately, that's not true, but it is quite rare. I've heard, first hand, a pilot get ripped apart by Norcal Approach for missing an approach (for real, not practice) into Napa County (pretty sure that's the airport). The pilot had botched the approach somehow, and elected to go missed rather than try to salvage a bad situation (good choice), and ATC proceeded to lay into him about going missed when he had stated that he was going to do a full stop landing. I felt like saying something, but I didn't.  sorry
That's not ATC's function.
Quoting CBERFlyer (Reply 5):
Quoting Starlionblue (Reply 8):
Unfortunately also not true, especially on the pilot side. Most of the time whichever party is getting pushed doesn't give an inch though.
ThirtyEcho
Sun Jul 09, 2006 5:13 pm
My own personal limit, in 46 years of flying, has been no more than two go-arounds or missed approaches at any one time. Something is very wrong if the second attempt at putting the wheels on the pavement goes haywire. The tendency to push a bad situation or bust minimums goes up geometrically on that third attempt.
Better to get out of Dodge to a hold or to the alternate.
flymatt2bermud
Fri Jul 14, 2006 1:05 pm
As stated, there is no limit unless an air carrier has a specific guidelines or a pilot has his own limitations. I believe experience should drive the call. If you can plainly see the conditions contributing to your windshear are moving on through, you might loiter around a bit provided you haven't called BINGO. I am based in Bermuda, the closest alternate is 1:30 on a good day. We typically carry an hour of loiter fuel (on top of alternate and reserve) but I think I would just keep an eye on things instead of attempting approach after approach. Situational awareness is key here.
[Edited 2006-07-14 06:06:35]
"When once you have tasted flight, you will forever walk the earth with your eyes turned skyward" Leonardo Da Vinci
trojanAE
Fri Jul 14, 2006 7:47 pm
Pardon my ignorance, but just to clarify, is there a set quantity of fuel for go-arounds? Because, surely, if there is enough fuel to power up, reach a safe altitude, and fly to an alternate, and perform a power-on approach there, there is plenty of fuel to perform more missed approaches? Additionally, how does a pilot decide when to hold and when to divert? Depending on the conditions preventing his landing? Thanks in advance!  wave
"My soul is in the sky." -William Shakespeare
Fri Jul 14, 2006 8:42 pm
Quoting TrojanAE (Reply 15):
Enough fuel is carried for 2-3 landing attempts at the destination, flying to an alternate after the attempts, and 2-3 landing attempts at an alternate. This varies depending on conditions and route. Then there is taxi fuel and final reserve so you are unlikely to run out of fuel while trying to land. It has happened in a couple of cases, but the blame has been placed firmly on the crew for not monitoring the fuel situation. I seem to recall a DC-8 in the Pacific Northwest and some non-US 767 (?) at JFK.
Information is gathered from ATIS, ATC, dispatchers and own impressions to decide whether to hold and wait for better weather. Note that you are not allowed to paint yourself into a corner. That is, you MUST divert if you reach the point where you only have fuel for flying to the alternate and landing (with go-arounds) there. If the alternate is an hour away, you could theoretically loiter at the destination for that hour. But even if you "know" the weather is going to be fine in 20 minutes, you MUST divert.
CosmicCruiser
Fri Jul 14, 2006 11:28 pm
I'm sure it sounded good to the pax.
Quoting Ralgha (Reply 12):
If he stated he was making a full stop ldg he probably was just doing some instr. trg and this was to be the last of several apps. Afterall you don't fly from A to B and announce this will be a full stop ldg. When he missed that may have not only caught the controller off guard but possibly created a potential conflict. It's good you didn't say anything.
Quoting Starlionblue (Reply 16):
Let's just look at dom. requirements..fuel to dest. plus fuel to alt. plus 45 min.(let's not muddy the water with "in still air", taxi, etc blah, blah) Nowhere does it say enough fuel for 2 or 3 attempts..sorry.
That's not correct. That fuel is just the min. required fuel for the flight. I can waste it all at the dest if I choose. 99.9% of the time it would be prudent NOT to do this and go to your alt. but that's a decision I make along with dispatch. I can remember a situation where EWR was down to one runway(a disabled jet had closed the other one) and we had held 3 times enroute before getting close. About 100mi out we were slowed and eventually had to extend the slats and flaps increasing fuel burn. When we finally reached the terminal area I was told we were now no.18 or 20 for ldg. I'm thinking it will be at least 30 min. more and with any other glitches EWR has no rny so I make the prudent choice to go the alt. for fuel and return. A co. jet which was ahead of us elected to press on to the ldg. using his "alt" fuel and landed.
Sat Jul 15, 2006 12:35 am
Quoting CosmicCruiser (Reply 17):
Well, 45 mins is probably enough to get you to an alternate + try a few times. I was just trying to give an example. Thx for corrections.
Well, at EWR you have several alternates within 10 minutes of flight. What I meant was that you are not allowed to get yourself in a situation where you cannot divert. but I may be wrong.
Bellerophon
Sat Jul 15, 2006 1:45 am
...What I meant was that you are not allowed to get yourself in a situation where you cannot divert. but I may be wrong...
Sorry, but sadly you are, as CosmicCruiser has already posted.
Under JAR-OPS, under certain circumstances, it is quite legal to commit to a destination, and use all your alternate fuel in getting there.
Whether this is prudent is a command decision to be made on the day, having reviewed all the relevant circumstances.
In the vast majority of cases, it won't be.
However, diverting to an alternate does not guarantee an end to your fuel problems, and it is quite possible to end up in a worse situation than you were in at your destination!
Consider the case where the weather is deteriorating at your (single runway) alternate but improving at your (multi runway) destination.
It may be safer to burn your alternate fuel in the hold, in order to accept a lengthy traffic delay at your destination - where you know aircraft are getting in, and other runways are available - rather than diverting to your alternate, where the weather could drop below minimums whilst you are en-route, or a landing incident close the only runway.
No one dispenses with an alternate lightly, but sometimes, just sometimes; it may be the safer option.
Best regards
Bellerophon
Sat Jul 15, 2006 2:53 am
Quoting Bellerophon (Reply 19):
Wow. I stand corrected then. Thank you Bellerophon and CosmicCruiser.
Ralgha
Sat Jul 15, 2006 7:14 am
He wasn't training, and the controller probably asked him if it was going to be a full stop. Very common around here with GA airplanes, because the controllers don't know if they're going to want to practice or not. Pilots don't often volunteer the information, especially if they're not training.
Regardless of who said what about a full stop, the controller was way out of line given that it was an unplanned missed approach initiated because of an unsafe situation. If the missed approach caused a conflict, then ATC screwed up, not the pilot.
[Edited 2006-07-15 00:15:48]
Users browsing this forum: dakotasport, P3Orion and 1 guest
