andz
744 Thrust Reverser Positioning Sensors
Mon Jul 10, 2006 5:15 am
I recently flew SAA JNB-LHR on a 744. We taxied out and stopped, then the Captain came on and said there was a technical fault with No 2 thrust reverser sensors and we might need to return to the gate. Laudair sprang to mind and I commented to the F/A sitting opposite me that I was happy to return to the gate for a reverser problem!
Anyway back the gate we went, the Captain was on the P/A explaining that they couldn't determine the position of the reverser which could compromise our take off performance and the aircraft in the air. He explained everything in layman's terms which I thought was pretty good, saying the quickest fix was to lock it out which would take about half an hour.... 20 minutes later we were on our way on a smooth and uneventful flight.
Anyone got any similar stories? Is this a common occurrence? The aircraft was ZS-SAK which has Rolls-Royce RB-211s.
Photo © Russell Collins
kaddyuk
RE: 744 Thrust Reverser Positioning Sensors
Mon Jul 10, 2006 7:39 am
Quoting Andz (Thread starter):
Thrust reversers when we have problems with them and we're in a rush are normally locked out. Its not a fix as such, but the aircraft can be dispatched with one thrust reverser Inoperative.
There are many different interlocks that prevent the T/R from being deployed in flight, many of them introduced because of the Lauda Air crash.
Its a fairly simple procedure to lock a T/R out and can be done inside 20 Minutes (I've never really timed myself though).
n8076u
Mon Jul 10, 2006 11:25 am
Quoting Kaddyuk (Reply 1):
I agree, this seems to always happen when you don't have time to actually fix it, and the aircraft is already loaded.  Wink
The P&W powered 747-400s we had at UA weren't particularly troublesome at least compared to the 747 classics we had.
After the Lauda Air crash, the newer 747-400s UA had came with "sync locks" which physically prevented the reverser actuators from turning, should one somehow activate in flight. The 767-300's had these as well. Older 747-400s were retrofitted with this feature at overhaul. Sync lock operation was checked at every "B" check (1000 hrs. between B checks if I remember right). The gaps on the reverser actuator proximity switches were also checked at "B" checks.
Chris
Don't blame me, I don't work here...
liedetectors
Sun Jul 16, 2006 3:30 am
Theoretically, you can lock out all the T/Rs and dispatch b/c the T/R is not an essential item.
If it was said by us, then it must be true.
n8076u
Sun Jul 16, 2006 3:57 am
Quoting Liedetectors (Reply 3):
Theoretically, yes. But the reality is that according to the MEL on the 747-400 only one reverser can be inoperative. If you have two inoperative, you're not going anywhere.
Chris
kaddyuk
Sun Jul 16, 2006 6:30 am
Negative, you can lock out both t/r on one engine... however you can't lock out more than one t/r not on the same engine...
n8076u
Sun Jul 16, 2006 8:46 am
Quoting Kaddyuk (Reply 5):
Yes, both reverser halves on one engine must always be locked out together.
Now, it "may" be possible to get a one-time ferry permit and fly a 747 with two reversers inop, so theoretically it is "possible" but never, ever on a revenue flight.
Chris
kaddyuk
Mon Jul 17, 2006 3:50 am
Quoting N8076U (Reply 6):
You'd need a Permit to Fly from the CAA and a NTO (No Technical Objection) from the Manufacturer I guess as you'd be operating outside the MMEL.
